Old 03-06-2012, 05:27 AM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Seven pin wire question
Here is the blue wires (brakes on truck) and a diagram of the wire hook ups. Can I wire these two blue wires into the places (even though there might be another wire there) and it will work?
The two blue wires are not yet connected...the lights are though.
ID:	152658   Click image for larger version
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 03-06-2012, 05:59 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Billy,
On our 63 Safari the wiring did not match the newer diagrams. Test the male connector on the trailer,(test light) to make sure the brake wire is in the correct position. If not just change it and write down your own diagram.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 03-06-2012, 07:44 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I don't completely understand your question. Robert Cross is right though.
Now tow vehicles and trailer 7 way plugs are industry standard. In 1970 they were not. Blue on your tow vehicle is probably brakes. It is on my Ford. The brake wires on your trailer are probably yellow. Your 7 way trailer plug won't match up with the correct terminal on the truck unless one or the other has been rewired. There are other threads on the topic.
Lumatic is online now   Reply With Quote
Old 03-06-2012, 07:54 AM   #4
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Today's color codes for the 7 wires are different than when the vintage Airstreams were built. You can ignore the colors--what's important is to make sure you wire each function to the appropriate pin. Here's the pinout for the original Airstream connector on the trailer:
Name:	Airstream connector--drawing.jpg
Why are there two blue wires coming out of your female socket on the truck? Are they Both connected to the same pin (pin #2)? There should only be one brake power line coming from your brake controller and this line should go to pin 2. This is the current standard for the 7-pin connector with the old color code, if different, in parentheses:
Name:	bargman 7-pin drawing.jpg
This is another version of the same information. Note that the color code is different than the one pictured in your post (where did purple come from, one might ask?).
Name:	7-Pin wiring.jpg
Zep
Old 03-06-2012, 08:09 AM   #5
Using a connector for the trailer, that has flat blades, is not a very good idea.
One grain of sand, will stop a good connection.
Also, in time, it will corrode, especially on high current terminals such as the brakes, charge line and ground.
Then, it must be cleaned and cleaned and cleaned again and again.
Using the round terminal type connector, never has the same issues, since the terminals are called "aircraft type".
It self cleans every time you connect or disconnect it.
Costs a little more, but beyond comparison, because of it's superiority.
Old 03-06-2012, 10:30 AM   #6
1975 29' Ambassador
Reno , Nevada
re: "Using the round terminal type connector, never has the same issues, since the terminals are called "aircraft type"."
These must be the types used in the trucking industry and as used by Airstream in the 70's? They are much more rugged that the current standard it seems to me so I wonder why it is that the flat blade design became the de-facto modern standard in RV's.
Old 03-06-2012, 10:33 AM   #7
Easy answer.
Because they are CHEAP.
Old 03-06-2012, 12:19 PM   #8
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
If you have to be towed due to a breakdown, the tow truck aint gonna have a flat pin connector. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-14-2012, 05:53 AM   #9
1970 27' Overlander
Well- for an update for you guys (and gals) - I ended up going back to the exact person who built the adapter for another truck I had. He - I found out is the fire marshal for this city. He climbed under my truck and traced through the wires and finally found the brake wire at the rear. He told me he had put some scotch tape around one of the blue wires to tell him which one was the brake wire, and sure enough there was the tape. So he said after a few tests that I can 'mainline' those two wires together and the connection would be made. But I am going back to him one more time this morning to write down what he was saying. But in this photo, this is the place where the blue truck wire showed up at.
Question about mirrors Getahobby Towing, Tow Vehicles & Hitches 47 08-19-2013 09:55 PM
Florida boy with cold weather question mysecondjoy Boondocking 23 09-19-2012 06:35 PM
2008 Interstate 3500 Generator Exhaust Routing Question solar-guy Sprinter and B-van Forum 3 03-06-2012 06:19 AM
Question: Microwave mefly2 General Repair Forum 7 03-04-2012 02:16 PM
Floor Question siox Repairing/Replacing Floor &/or Frame 6 02-28-2012 05:54 PM
