Old 04-29-2014, 03:22 PM   #15
K.C. , Missouri
Interesting new product out that may work to ease this process:
Straptek - Towing
....discussion of it going on over on rv net right now:
RV.Net Open Roads Forum: Towing: Towing with the new Straptek?
gmw photos is offline   Reply With Quote
Old 04-29-2014, 03:59 PM   #16
Drag&Fly
md11flyer's Avatar
1988 29' Excella
Collierville , Tennessee
Send a message via AIM to md11flyer
youtube
Youtube has a couple of excellent short videoshttps:[U]//[U]on how to raise the bars into position. They also suggest your position in relation to the pry bar is critical to reduce the chance of injury. Yes, Yes, Yes, on the gloves. Be safe out there.
md11flyer is offline   Reply With Quote
Old 04-29-2014, 04:39 PM   #17
1976 31' Sovereign
Oswego , Illinois
This is the way that many have stated on this thread how to safely hook up.
Old 04-29-2014, 04:50 PM   #18
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by dprvashon View Post
I just bought my trailer and they sold me an Equalizer WD hitch. To get the bars onto the trailer, he had me, both, use the trailer tongue connected to the TV to raise both vehicles then use the curved 'Snap Up Hook' lever to finish placing the bars on the trailer. The following is from the owner's manual found here:
http://www.equalizerhitch.com/pdf/EQOwnersManual.pdf
"With the tow vehicle still coupled to the trailer, use the tongue jack to lift both vehicles until you can swing the spring arms into place over the l- brackets. If you reach the top of the jack before the spring arms will swing into position, you can use the Snap-up lever to lift the spring arms up and onto the l-brackets. Use the l-pins to secure the spring arms on the l-brackets."
Hope this helps....
I have the cheater in the storage compartment, but I have never used it. I use the tongue jack to lift the whole rig and the bars go in easily. I have started leaving the weight bars in the L-brackets and sliding them in and out of the hitch head. It sure is easy.Click image for larger version
Name:	ImageUploadedByAirstream Forums1398811844.215439.jpg
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-29-2014, 05:15 PM   #19
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I am female and mostly solo. I had my lift bar doubled in length, now I stand back and the extra length makes it easier for me to lift. I also raise my jack as noted above. The long bar is a lifesaver for me. It is total about 40" long.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 04-29-2014, 05:19 PM   #20
Originally Posted by Al and Missy View Post
With the TT connected to the TV, the trailer chocked, the TV brake on and the hitch coupler locked, lift the combination with the tongue jack until you can lift and slide them into place. Then lower the combination until the jack is fully retracted. Reverse to remove bars.
That's it, a lever to lift the bars in place came with my Equalizer hitch but I have never used it. I just couple the hitch and lift the front of the trailer high enough to slide the bars in place.
If you don't have a power tongue jack, quite a bit of cranking is required to lift the front of the trailer.
handn is offline   Reply With Quote
Old 06-16-2014, 06:36 AM   #21
Drag&Fly
md11flyer's Avatar
1988 29' Excella
Just noticed this thread and all good advice. My input is there are a couple of youtube videos that show exactly how this technique of using the jack to lift the coupler works. I cannot agree more with the suggestions to use gloves (work gloves) and stay out of the way of the lifting bar if it should perchance slip. It will! I know!!
Old 06-16-2014, 01:05 PM   #22
m.hony's Avatar
2013 30' Classic
I have an Equal-i-zer. I usually leave the bars in the L brackets when parked. I took them out and laid them on the ground Saturday to adjust and tighten the brackets. Sunday, when I went to pick them up to put them on, I dropped on on my finger. That hurt!
TAC #MS-10
Airforums #70955
Old 07-24-2014, 07:58 PM   #23
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Originally Posted by mcgintyrch View Post
I would greatly appreciate any secrets you may have to raising trunnion bars of weight distribution hitches into place. I am still a newbie at this and do all my hitching, etc., solo. I still find the tension trunnion bars a bit intimidating. Perhaps, I'm overlooking the obvious. Should I lift the trailer as high as possible? Coupled or uncoupled to the tow vehicle?
Thanks for any sharing from the "Book of Secrets" of all you Airstreamers!
Susanne and the red kids
2009 23' Ocean Breeze
2008 Yukon XL
Drawtite Hitch 800 lb bars
I'm new to the site so maybe this is covered elsewhere - guidance appreciated.
On the Reese site they also suggest raising the Jack to decrease the angle of the bar and the TT frame to make hookup easier, as everyone here does.
One point no one has mentioned: Proper trunnion bar adjustment by measuring the truck wheelwell heights before and after the barss are adjusted. If the differences in the before and after heights are the same front and rear on the TV, you've properly transferred the weight to the front axle in proportion to the weight left on the rear axle. On my Ram 2500 & 27FB the proper hookup results in one inch drop in each of the front and rear wheelwell heights. This was achieved by trial and error, counting links and then measuring wheelwell delta on a nice level surface..
The Ice Man is offline   Reply With Quote
Old 07-25-2014, 08:43 AM   #24
You really don't need any bar or pipe.
In fact you can engage the torsion bars, with just one hand.
How?? Easy !!
Lock the coupler to the ball. With the tongue jack, lift the front end of the trailer "high".
Then simply engage the bars.
Then lower the jack.
I did that for many years, and never needed a pipe or extension handle.
Old 07-25-2014, 09:09 AM   #25
m.hony's Avatar
2013 30' Classic
What he said.
I have an Equal-i-zer and never "lift" the bars.
I raise the truck 'n' trailer with the tongue jack. I remove the pins and slide the bars back in the L brackets and leave them there.
When I hook up again, I lift the truck 'n' trailer with the tongue jack and slide the bars into the hitch head and put in the pins. It's so easy I hesitate to get a ProPride even though I want one...
TAC #MS-10
Airforums #70955
Size of 600lb Reese Trunnion bars? glacierrunne Hitches, Couplers & Balls 5 08-09-2010 08:07 PM
Spring Bars: Round or Trunnion? Any opinions??? Geoffrey Hitches, Couplers & Balls 15 09-09-2009 09:07 PM
Where to buy or exchange trunnion bars? nunya001 Hitches, Couplers & Balls 9 05-24-2009 09:16 AM
Reese Dual Cam Trunnion Bars dscluchfc Hitches, Couplers & Balls 17 04-21-2005 05:52 AM
weight distributing bars/trunnion bars teutonik Hitches, Couplers & Balls 2 12-04-2003 06:58 AM
