Old 12-12-2012, 06:44 AM   #1
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Scan Gauge II
Anyone using a ScanGuage II? I tow with an Excursion. I'm hoping to learn a little more about how the v10 uses fuel by reading the info provided by the SGII.
Additionally, I am looking forward to the extra info such as trans temp, charge voltage etc.
Old 12-12-2012, 06:51 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have used mine on 4 different vehicles. Currently it is hooked up in the F150. It is a bit redundant in the F150 as it has a very comprehensive electronic data display system already built in.
MICHAEL
Old 12-12-2012, 06:54 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
My excuse to buy the ScanGauge II was to monitor transmission temperature in the truck. I found that it also provides a much more honest assessment of fuel use than the truck's overly-optimistic computer. I bought an extra cable so it's easy to pop out of the truck and use it as a code reader/reset for our other vehicles as well. I'm happy with the purchase.
— David
Old 12-12-2012, 07:03 AM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Yes, my reason is for the trans temp data as well. My one big complaint with the Excursion (petty) is the rather soccer momish displays, and data output!
Old 12-14-2012, 08:35 PM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I compared and went with UltraGauge.
The old set of tools (mechanical) was:
1] tachometer
2] vacuum
3] fuel flow meter
and, optionally,
4] airspeed indicator
Usually a "set" is best to get an intuitive feel for what the vehicle is experiencing. After all, it really doesn't need us except to process visual information. This is about road & load. Traffic, weather and surface conditions.
The least amount of throttle (and brake & steering) is the optimum for FE. But the visual interpreter is subject to irrationality during information processing unlike the vehicle command. Bad code from the teenage years never subsequently re-written.
If the SG has a provision for "engine load", use it first to tailor footwork.
Old 12-15-2012, 12:06 AM   #6
steverino's Avatar
2018 30' Classic
Ivins , Utah
Images: 8
I use my SG II to watch EGT, diesel filter temp, and fuel flow (gallons per hour). The exhaust temps help me spot diesel regens, the fuel flow help me maximise fuel economy. It seems more responsive and meaningful than the miles per gallon calculation, but probably is basically the same info. the fourth gauge is usually set to engine oil, water, or transmission fluid temperature, or fuel level depending on circumstances.
I haven't found the torque or engine load gauges terribly effective, but haven't spent much time with them either.
2010 Ford F250 diesel.
Steve
steverino is offline   Reply With Quote
Old 12-15-2012, 06:46 AM   #7
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I got my Scan Gauge installed last night, then the sun went down!
I entered codes for the "X-Gauges" I wanted. I spent a while tweeking and finally went for a test drive.
Overall a pretty nifty little gadget. It has all the features I need... trans temp, accurate fuel levels, water temp, etc.
I routed the wiring through the dash so nothing was visible, then hardwired the connection to the OBD II connector. This way, should I ever require service at the stealership, they can plug in without ripping my connector off. I have the pinout info should anyone want it.
Old 12-03-2013, 08:05 AM   #8
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
Just so you all know, the ScanGuage II is on sale at Amazon for $115 for the next three hours or so. It is normally $135.
The above link is through my Amazon store.
aluminitus is offline   Reply With Quote
Old 12-03-2013, 07:45 PM   #9
andreasduess's Avatar
1984 34' International
Toronto , Ontario
If you have an Android phone or tablet, there are a bunch of $5 app that do pretty much the same thing. I use this one, with a $10 bluetooth transmitter from ebay that plugs into the car.
If you want to check if this is for you then the cheaper setup might be a good entry point.
andreasduess is offline   Reply With Quote
Old 12-03-2013, 09:00 PM   #10
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I really like my Scangauge II, and keep track of mileage, voltage, turbo boost and accurate engine temp. It doesn't work the same on all vehicles, though. My Sprinter does not give a trans temp feed to the computer, so I can't get that, unfortunately. I use it to clear codes that trip the CEL light each time I cold start ( I have a glowplug that's out), and use the trip functions frequently. It's a great tool.
robert claus is offline   Reply With Quote
Dash and/or gauge replacement dadstoy Classic Motorhomes 19 11-18-2011 11:32 PM
How long can my battery cable be - and what gauge wire? robwok Electrical - Systems, Generators, Batteries & Solar 3 10-20-2011 09:52 AM
C-Channel Gauge and Dimensions P&K Repairing/Replacing Floor &/or Frame 3 09-19-2011 10:37 AM
Rogue 10 gauge wire? pdallas Classic Motorhomes 12 06-06-2011 06:53 PM
Recommended 110V Wire Gauge SilverHoot Electrical - Systems, Generators, Batteries & Solar 13 02-28-2011 09:42 PM
