Join Airstream Forums Today
Old 09-23-2011, 03:26 PM   #1
gtc6452's Avatar
2011 30' International
mooresburg , Tennessee
Scales
went to scales today, just want to know if this sound ok.
2007 toyota trundra. with 2011 30' internation.
full tank of gas, bed of truck loaded for camping, with generator.
trailer loaded for camping.
2 people and 1 dog in truck
propane and 1/8th of a tank of water.
steer axle: 3440
drive axle: 3720
trailer axle: 6440
gross weight: 13,600
gtc6452 is offline   Reply With Quote
Old 09-23-2011, 03:54 PM   #2
steer axle: 3440
drive axle: 3720
trailer axle: 6440
What brand and rating of load equalizing hitch are you using?
Andy 12K
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-23-2011, 04:40 PM   #3
2006 30' Classic
Milton , Florida
Truck & Trailer Weights
steer axle: 3440
drive axle: 3720
trailer axle: 6440
You may find the information at the following link helpful.
http://www.airforums.com/forums/f238...hts-73579.html
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 09-23-2011, 04:51 PM   #4
gtc6452's Avatar
I have a Reese 54970 with 1,200 lb bars. the dealer traded out my 750 lb hitch.
Old 09-23-2011, 05:20 PM   #5
1973 31' Excella 500
Marysville , Washington
Did you note the weight for each trailer axle? I have the 07 Tundra crew max 4wd but my 31' AS weighs less. The weight ratio of my TV axles was similar to yours and the AS rear axle weighed less than the front axle. I shortened the WD chains by ONE link and the result was the AS axles then weighed the same and about 125lbs transferred from the TV rear to the front.
Not Done is offline   Reply With Quote
Old 09-23-2011, 05:26 PM   #6
gtc6452's Avatar
thanks , not sure if my bars are to much. Do I need to go to 1000 lb bars, or does it make a difference.
Old 09-30-2011, 01:58 PM   #7
gtc6452's Avatar
went up one link and back to scales. now steer-3300
drive-3480
trailer-6300
gross-13080
rides about the same but is more level. thank all for the info. only one in truck.
TinCrumpet Vacations TinCrumpet Global 'streaming 11095 Today 01:48 AM
Michelin LTX MS2 235/75/15 XL Top Tires 55 10-17-2011 12:36 PM
2010 Suburban 1/2 ton w/tranny cooler... phbarnhart Tow Vehicles 53 09-23-2011 12:05 AM
WD hitch and tire wear... flmgrip Hitches, Couplers & Balls 46 09-14-2011 07:34 AM
Equalizer hitch benefits Moonstruck Hitches, Couplers & Balls 34 01-19-2011 08:03 AM
