Old 08-18-2016, 05:22 PM   #1
ericpeltier's Avatar
Superior , Colorado
Safety Chain attachment
My trailer came complete with safety chain attachments that were ripped off. No, I don't know why.
I am going to have some new loops welded on. Loops like:
https://www.amazon.com/Heavy-Duty-St...ds=steel+links
but smaller than that.
My welder friend is asking if i want them stick welded on or wire-feed welded on.
Thoughts?
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 08-18-2016, 05:27 PM   #2
1976 31' Sovereign
Oswego , Illinois
I like wire feed but use both.
Old 08-18-2016, 05:29 PM   #3
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
North Port , Florida
That's a weird question??? It's like your mechanic asking ratchet or wrench.
cliffcharb is offline   Reply With Quote
Old 08-18-2016, 07:57 PM   #4
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
Seriously though, if he's good with a welder it should t matter. Migs tend to be used indoors so the shielding gas doesn't get blown away. I would think he'd use a stick
Old 08-19-2016, 06:38 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Just what I would do...
.....don't weld those screw type links.
Type of weld....Quality.
Get the proper rated chain, have two of the links welded directly to the frame.
Or as AS does....
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Old 08-19-2016, 07:57 AM   #6
2016 25' Flying Cloud
Holly Springs , Mississippi
+1 for Bob Cross's solution. Do it right the first time or you'll get to do it again, later.
I've always used stick when my life depended on it, because it's easier to get weld penetration. Mig is great for sticking two pieces of metal together where a weld failure isn't catastrophic, or for welding thinner stock.
Be sure your guy removes the paint in weld area. As soon as the weld is completed and the slag removed, paint spray the weldment while it's still hot. If it cools without being painted it will draw moisture into the weld and you'll fight rust forever.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Welding Advice? (Safety Chain & Cable Attachments) slowmover Hitches, Couplers & Balls 9 04-28-2008 11:52 AM
Safety Chain on Inside or Outside of Equalizer Bars? 87MH Hitches, Couplers & Balls 13 10-07-2007 08:05 PM
Safety Chain Restraint Navigator On The Road... 3 02-28-2004 11:20 AM
Safety Chain Shaclkle - Weakest Link? Creampuff Hitches, Couplers & Balls 6 12-09-2003 07:46 PM
Safety chain femuse Hitches, Couplers & Balls 4 04-19-2003 09:26 AM
