Old 12-18-2006, 07:19 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Exclamation RT 95 Fort McHenry tunnel & propane
I have beed reading that you can't drive thru the MD tunnel with propane.
But you can
Code of Maryland Regulations (COMAR) govern the transport of hazardous materials across our toll facilities. Under these regulations, vehicles carrying bottled propane gas in excess of 10 pounds per container (maximum of 10 containers), bulk gasoline, explosives, significant amounts of radioactive materials, and other hazardous materials are prohibited from using the Fort McHenry Tunnel (I-95) or the Baltimore Harbor Tunnel (I-895). The Francis Scott Key Bridge (I-695, the Baltimore Beltway) is a convenient alternative route for crossing Baltimore's Harbor.
Visit the Division of State Documents' website at CODE OF MARYLAND REGULATIONS to view the actual COMAR regulations: Title 11, Subtitle 7, Chapter 1 (11.07.01).
Therfore, upto 10 40 gallon tanks are permitted, correct?
'77 Sovereign Intl 31' CB
Old 12-18-2006, 07:42 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
But you can
No, it's 10 POUNDS per container, not 10 GALLONS. A gallon of propane weighs a bit over 7 pounds. You can transport up to 10 of those cute little Coleman propane fual cannisters for your gas hibachi.
Old 12-18-2006, 07:56 PM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Opps, that's like 2 1/2 gallons ( 4.24 lbs per gallon) or maybe a 10 gallon tank.
Old 12-18-2006, 08:17 PM   #4
1993 21' Sovereign
Oops, that's like 2 1/2 gallons ( 4.24 lbs per gallon) or maybe a 10 gallon tank.
Sorry to rain on your parade...
Old 12-18-2006, 08:29 PM   #5
Placitas , New Mexico
MD tunnel regulations
Don't take chances on someone with more badge than brains turning you around and making you look like the cause of the traffic jam from hell.....take the 695 bypass (the west side is toll-free).
JakBluMule is offline   Reply With Quote
Old 12-18-2006, 08:34 PM   #6
Over59's Avatar
Putnam , Connecticut
Images: 37
Does this apply to the bay tunnel bridge going to Va as well?
Over59 is offline   Reply With Quote
Old 12-18-2006, 10:18 PM   #7
Since the bay bridge/tunnel starts/ends in MD, and with the general paranoia that exists everywhere, I'd call MD State Police @ 410-486-3101 or MD Environmental Dept. @ 410-333-2950. Be prepared to deal with the bureaucratic miasma. I haven't been that way in several years, but I recall it being a rather bumpy roadway, and I was driving a semi that had air-ride suspensions on both tractor & trailer. Put everything on the floor first before it winds up there.
Old 12-18-2006, 10:27 PM   #8
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
When I called thr MD Bridge and Tunnel, I was told "NO"
Michael
ArtStream is offline   Reply With Quote
Old 12-18-2006, 10:54 PM   #9
VA tunnel regulations
If you're planning a trip to/from Norfolk area, check with the authorities there re: tunnels on I-64 & I-664.....otherwise you might be restricted to US 17 and the old James River Bridge. However, US 17 is one of those cool old "blue" highways that passes through some beautiful country. We try to avoid the interstates as much as possible when we travel (I spent many years on them in a hurry from point a to point b). We did 5500 miles in Sept & Oct and I'd say we were on interstates less than 100 miles the entire trip.
Old 12-18-2006, 11:17 PM   #10
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I called the VA bridge/tunnel in advance and was told to make sure my tanks were shut off. No one checked, or asked. Same with the Lewes-Cape May Ferry.
SilverRanger is offline   Reply With Quote
Old 12-18-2006, 11:26 PM   #11
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I have traveled extensively in the Norfolk area using all of the tunnels as well as the Bay Bridge. They have an inspection station when you have to pull in to check your propane tanks. Some will take your word that the tanks are closed others will check. I carry two 40 lb bottles and that has never been a concern as long as they were shut off.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 12-18-2006, 11:59 PM   #12
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Bay Bridge Tunnel
I live in Va Beach and have for 30 years. You can go to the eastern shore on route 13 with propane tanks, but they must be shut off. Ditto for the Hampton Roads Bridge Tunnel US 64 and the Monitor Merrimac Tunnel US 664.
What you won't remember is that in the 50's or 60's there was an explosion in the Baltimore tunnel when a tank truck blew up - dozens of fatalities - and hours and hours to clear the area. Their paranoia is based on that tragedy.
Paula Ford
Old 12-19-2006, 12:29 AM   #13
I have to correct an earlier post: The Chesapeake Bay Bridge/Tunnel is entirely in Virginia.....it does not start or end in Maryland. My apologies for the error.
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 11:34 AM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 02:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 04:54 AM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 10:42 PM
Tunnel Mountain Campground @ Banff John On The Road... 5 04-13-2002 10:01 AM
