12-25-2013, 05:21 PM
1980 24' Caravelle
corpus christi
Round or Trunnion Bars
Starting to look for a WDH for our 24ft Caravella I have not used one before. Is there a difference in the ride of the round vs trunnion bar?
Does one give more ground clearance than the other?
12-25-2013, 05:25 PM
1979 23' Safari
1954 29' Liner
Orange
I believe that the trunnion bars give more ground clearance.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
It all depends on what the bar is rated for. 800, 1000,1200#. Ground clearances are about the same. I use a Reese trunion type and like it. Simple to hook up & maintain.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
12-25-2013, 05:56 PM
1980 24' Caravelle
corpus christi
Looking at 600lb bars. I thought I read some where the round bars gave a smoother ride but cannot find that info.
12-25-2013, 06:05 PM
2012 25' Flying Cloud
Battle Lake
Doug and Cheryl
12-25-2013, 06:07 PM
Biloxi
, Mississippi
OP, best clearance is with the Andersen WD system. It does not use bars to accomplish weight distribution; it uses chains and urethane bushings. It has proven to work very well with similar trailer and coupler combinations contrary to what some here would have you believe.
MICHAEL
12-25-2013, 06:27 PM
Lin
, Ne
12-25-2013, 06:31 PM
Full Time Alumaloafer
1966 24' Tradewind
Livingston
FWIW...I have had excellent results with a Blue Ox WD hitch setup. I have round 550 lb bars. Sway control is integral. YMMV.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
12-25-2013, 08:50 PM
1980 24' Caravelle
corpus christi
Has anyone used Curt WD I know they make a good hitch. Don't have the budget for Anderson or Equalizer that goes to the trailer still needs some things. And most of our trips are seldom over 400 miles.
12-25-2013, 08:56 PM
1997 30' Excella
San Antonio
What is your tow vehicle?
Bruce
12-25-2013, 09:06 PM
1980 24' Caravelle
corpus christi
2005 Chevrolet crew cab 1/2 ton 5.3
12-25-2013, 09:14 PM
1997 30' Excella
San Antonio
Is not the Curt similar to the Equalizer? Just don't by the one from Harbor Freight. That one is J U N K !
Bruce
12-26-2013, 04:40 AM
2013 30' Classic
Greenwood
, Mississippi
The Curt is junk. Not at all like the Equal-i-zer. More like the Eaz-Lift- just not as good. The little spring loaded tabs that hold the weight bars in are cheesy and have to be manipulated with one hand while putting the heavy bar in with the other hand. The EazLift is made so that the bars go in when parallel to the truck bumper and stay in when parallel to the trailer a frame- reverse procedure to remove- this procedure with Curt is way more cumbersome and difficult- and the little rivets holding the spring loaded tabs are loose and break real easy- then the bats won't stay in-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
12-26-2013, 07:25 AM
2010 28' Flying Cloud
Lower Alabama
, USA
Do your homework and buy once! You will find many folks who have bought multiple hitches. Spending money on a high quality hitch up front is a wise decision. There is a school of thought that round bars have more range of deflection and therefore give a smoother ride.
Sent from my SAMSUNG-SGH-I747 using Airstream Forums mobile app
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
