Old 07-25-2016, 01:17 PM   #15
ghaag's Avatar
2014 30' FB FC Bunk
2007 25' Safari FB SE
Jonesboro , Arkansas
Originally Posted by kscherzi View Post
When said 5000 miles you weren't rounding! Thanks for the write up. Is your truck a XLT?
I do not see any XLT branding, so I assume not.
ghaag is offline   Reply With Quote
Old 07-25-2016, 01:24 PM   #16
ghaag's Avatar
2014 30' FB FC Bunk
Originally Posted by hkeach View Post
I'm relatively new to Airstream towing but I have what I think is a combination pretty similar to this one with a very similar F150 and a 29' Sovereign. I don't have any trouble getting my rig leveled out with the weight transfer hitch so I'm confused by the mention of 'leveling' the rig with airbags. What's up with this? Thanks.
Here is how I was instructed to do this, and the inches may be slightly off since I am going from memory. If I measure the front tire from the ground to the top of wheel well I get approximately 37" and if I measure the rear tire from the ground to top of wheel well I get roughly 41". I then connect the trailer and inflate airbags to achieve roughly these same measurements. Hopefully this makes sense.
Old 07-25-2016, 01:29 PM   #17
ghaag's Avatar
2014 30' FB FC Bunk
Originally Posted by franklyfrank View Post
I have a similar truck a couple of years older. If you have the heavy duty tow package there is a Tow Haul switch you engage on the gearshift. With that engaged all you do is tap your brake and the engine brake downshifting works automatically. It also manages the turbos, engine and trans cooling and keeps things from overheating. It works like a charm.
I the beginning I tried to do all that manually and I had the trans and engine overheat on a very steep long climb.
I do have that, and it worked beautifully on uphill climbs but on downhill I had to handle in manually or my speed increased too much.
Old 07-25-2016, 01:31 PM   #18
ghaag's Avatar
2014 30' FB FC Bunk
For what its worth, I also installed Firestone airbags on my 2012 Ecoboost. I ended up removing them after a few trips because they were limiting the suspension travel and with higher psi the ride was way to stiff. I replaced them with the Road master spring setup and now the truck rides like a dream with the Trailer behind it and it levels beautifully every time regardless how I load the truck. I have the Blue Ox hitch.
Sounds like a great setup!
Old 07-25-2016, 01:40 PM   #19
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Have you checked your TV axle weights? I would think this process might result in an overload of the TV rear axle. May not be a problem, depending on truck's payload rating and tow package. I use the same measurement technique, but control the loading with the WD hitch. If result is not level, then I move the hitch ball up or down and do it all again until I get proper wheel well heights and a level arrangement. When I did it this way on my 25 the axle loads were acceptable. I haven't done it yet with my 30 and the 2500 TV.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-25-2016, 01:40 PM   #20
2016 27' International
Harrisburg , Pennsylvania
If you had to make the same trip tomorrow would you want to do it with the Cummins or ecoboost?
Absalom is offline   Reply With Quote
Old 07-25-2016, 01:50 PM   #21
From Beautiful Egg Harbor
2016 25' Flying Cloud
Egg Harbor , Wisconsin
Thanks for your post. We're awaiting arrival of F150 and Looking forward to a similar trip this fall leaving from beautiful Wisconsin.
efaehw is offline   Reply With Quote
Old 07-25-2016, 01:54 PM   #22
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
I run the firestone bags under my ancient 2000 expedition. My expedition only had coil springs and gas shocks from the factory so a helping hand was severely needed. We run at 35psi if it's just the wife, dogs and myself and at 45psi if the children and their extra gear are along for the ride. We also have spring over gas shocks on the rear. I'm a little surprised that ecoboost is only getting 11 mpg while towing. As long as I keep the speed at 70 our 5.4 with 3.73 gears is turning 13 mpg according to the computer. I had to give up my diesel f250 lariat after a back injury deminished my half of the family income to near zip. Pulling our trailer with the 3/4 ton was reason enough for us to look at different suspension set ups on a 1/2 ton vehicle. The bags made the ride very comparable between the two and I'm pretty sure our fuel bills have dropped with the expedition. The 6.0 in my 2006 fx4 was turning out 14 to 15 mpg while towing. With the difference in gas and diesel prices 1 to 2 mpg makes me question if the extra costs of a diesel are worth it.
1973Argosy is offline   Reply With Quote
Old 07-25-2016, 03:06 PM   #23
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I also installed the air bags. Not so much for leveling but also for a little cushion for the trailer.
TinCan
graysailor is offline   Reply With Quote
Old 07-25-2016, 03:48 PM   #24
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
For what it's worth, the turbo 'EcoBoost' engine is as good as it gets.
It's ancient technology first used by the Germans inWW2
.because they didn't have 'TetraEthyl lead' compound that reduces engine knock under high boost, C/R and so on
So they used direct injection to get around the 'knock problem'.
My Ford Eco'B is snappy when I need it, reasonably fuel efficient in normal use; and I can cruise at the most efficient torque speed which is 2500 RPM.
This allows all the ancillary services to operate at a good speed, and the engine doesn't 'bog' when power is called for.
I very much like it; but of course' I'm a retired Cdn licenced aircraft mechanic; an A.M.E.
MelGoddard is offline   Reply With Quote
Old 07-25-2016, 04:14 PM   #25
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
@MelGoddard
I wasn't knocking the ecoboost, I am just surprised the economy dropped so much towing. I have a restored 1986 mustang svo with the 2.3 turbo Intercooled and direct injected. In its current tune it's pumping 315hp and almost 350ftlbs of torque to the rear wheels. Of course I've never towed anything with the Mustang but know that the mileage suffers when the right foot gets heavy and the turbo really starts spinning. I would have thought with the ecoboost hitting it's best numbers at a lower rpm that the towing mileage would have been a bit better than a naturally aspirated 5.4.
Old 07-25-2016, 04:41 PM   #26
jcl
Vancouver , British Columbia
I dare say it would be, if it was putting out the same hp at the time. Thing is, many vote with the throttle and decide to use the hp available, and that takes fuel.
jcl is offline   Reply With Quote
Old 07-26-2016, 08:19 AM   #27
Ron and Lilla McClendon
2013 27' FB International
Watkinsville , Georgia
Interesting post. We have an F-150 equipped like yours on order now for about 8 weeks. Still waiting. I was planning to go to the dealer and try to find a truck similar to ours to check the door sticker for payload rating. The various models and accessories all have different payloads.
Is your truck an XLT, Lariat, or Platinum, ...?
Thanks for providing the photos.
Ron
RonMcMusic is offline   Reply With Quote
Old 07-26-2016, 08:38 AM   #28
Anna Maria , Florida
Al
If you are struggling with leveling your TV rear end I would highly recommend the Roadmaster Spring set up. It will solve a host of problems and works like a charm and easy to install. Anyone with a floor jack and stands and basic mechanical skills can do it. Not only do they help with leveling the load they also eliminate axle wrap on those concrete washboard roads. I am on my second season using it and swear by it. As I noted above I went the air bag route first but they don't work very well on the F-150 suspension set up.
BTW I do have the slightly used complete Firestone Airbags I removed, if anyone is interested they can have them for the price of shipping cost from Naperville Il.
franklyfrank is offline   Reply With Quote
Looking at Ford 250 versus 150 - possible to overdo it on tow vehicle bonginator Tow Vehicles 13 09-08-2013 06:55 AM
Ford F-150 EcoBoost review JFScheck Tow Vehicles 387 05-28-2013 04:49 PM
New Tow Vehicle - 2010 Ford F-150 mello mike Tow Vehicles 50 03-21-2011 10:37 PM
Ford F 150 as a towing vehicle rgentry Tow Vehicles 19 01-22-2009 06:44 PM
Ford F-150 As a Tow Vehicle Cstar Tow Vehicles 16 05-02-2004 07:24 AM
