Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 07-11-2009, 07:35 PM   #1
Profile:  1973 27' Overlander
Space Coast , FL
Originally Posted by Mikethefixit View Post
Funkill
Just forget about those fender heights they mean nuffin. The actual axles weights look good. With a difference of only 300 lbs or so between steering and drive I dont think you can get much better. U really dont want them equal. That is about where I stand with the 1 ton,about 300 lbs difference and 6 links under tension. We use 550 or 600 lb bars .We get a really good soft ride.
You DID GOOD My favorite sayin is "THE TAIL IS IN THE SCALE" Now you know where you are. I have tried other settings for the chains but dont get the ride I do from 6 links under tension. You have to have bars that flex,large bars take so much energy to flex that when they do bend the rebound is awesome,and at some point the rebound I think can cause loss of control.
Good luck with your setup
Roger
Thanks for the vote of confidence Roger!!! I am leaving for a trip tomorrow and will get a good feel for the ride. I have been thinking about maybe going with lower rated bars -- maybe the 600 pounders -- if I don't see the flexing I hope. That will be under consideration after my trip! Now I need to focus on getting the last minute stuff stowed - yawn.
Laura
funkill is offline   Reply With Quote
Portable axle scales at a rally? richinny Hitches 10 06-03-2009 09:18 PM
visited CAT scales - the numbers are in... 2airishuman Towing, Tow Vehicles & Hitches 61 08-31-2008 10:37 PM
Took a trip to the scales today... bobfowler All Argosy Trailers 10 11-26-2007 07:32 PM
Tappan Oven adjustments srgntpepper Stoves, Ovens & Microwaves 0 12-07-2003 07:15 PM
Equalizer hitch adjustments Raptorrider2001 Hitches 2 03-25-2003 10:35 AM
