11-03-2019, 07:01 PM
2019 33' Classic
Fort Wayne
, Indiana
Replacing breakaway cable
I have had my one year old breakaway cable break in half. I don't know exactly how, though perhaps it simply got caught on something. What does one do to replace such an item? It is a Cequent breakaway system. 2018 27FB FC. I have searched around and do not even find the same breakaway system. The cable is connected to the pin in a loop that is created with some sort of clamp.
Eric
11-03-2019, 07:31 PM
2015 27' Flying Cloud
Newberg
, Oregon
Originally Posted by billrector
I use the same thing.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
11-04-2019, 07:03 AM
2019 33' Classic
Fort Wayne
, Indiana
So, no need to replace the pin. That looks like it will work well.
Eric
11-04-2019, 08:18 AM
1976 31' Sovereign
Oswego
You can also buy a plain or vinyl covered piece of cable [any length as they will cut no extra charge]& slip on clamps for each end that you hammer flat after slipping on plus snap for lot less money than ready made, use your pin. IMO 6 ft cable way to long, if trailer comes loose you don't want 6 feet before brakes engage. These items can be pur. big box or farm supply stores
11-14-2019, 05:49 AM
2019 26' Flying Cloud
Summerfield
Excellent! I just ordered one. Fastway Zip 4 Foot Breakaway Cable
11-14-2019, 07:22 AM
Tampa
I bought the 4' Fastway.
The coil is pretty stiff, so I haven't installed it yet.
I suspect it's fine, and I read the 6' is for fifth wheels and the 4' for trailers so mine should work.
11-14-2019, 07:34 AM
2017 27' Flying Cloud
Fort Worth
Yes, while I tagged the 6’, I actually have the 4’. Btw....mailed the tubing yesterday.
11-14-2019, 09:11 AM
2004 30' Classic Slideout
Fenton
, Missouri
Had my breakaway cable show signs of failure this year. I just looked at the breakaway unit itself, found the brand and model name on it. It was a Tekonsha 2010 model. Went to etrailer.com found the exact replacement. https://www.etrailer.com/Accessories...ha/2010-A.html New cable came ready to go with new pin attached to it. Pulled the old cable and pin out and replaced with the new one. Easy peasy.
For your controller check Advanced Auto Parts. They carry Cequent break away controllers and cables. Also note the Tekonsha and Cequent are owned by the same parent company. So the folks at etrailer may also have a proper fitting cable and pin. I would personally rather buy a premade cable with attached pin than try to fabricate a cable. Do it wrong and that cable might not hold together at the attach points to the vehicle or at the pin itself.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
11-15-2019, 04:45 AM
2019 33' Classic
Fort Wayne
, Indiana
My solution
I just purchased the coiled 6’ coiled clip recommended. It works and now the AS is in storage for winter. I did not find the Cequent on etrailer.com and already had the clip before seeing that Advance might carry it.
Thanks to all.
Eric
11-17-2019, 10:53 AM
Summerfield
Break Away?
What are community thoughts on the weakest point in tow vehicle to trailer connection that could be the most probable breakaway point. And, what situations might that occur?
11-17-2019, 11:26 AM
South East
, Michigan
Top of the list - the human. Fail to lock down the coupler properly or fail to secure the hitch bar in the TV receiver and hit a bump on the road......
All other possibles are way down the list.
Al
2017 29' SOB, 2022 Platinum F-150 SCrew, ProPride
11-19-2019, 05:02 AM
Summerfield
Agree
I agree.
