Old 03-08-2017, 03:36 PM   #1
waninae39's Avatar
2017 22' Sport
NCR , Ontario
reese or eze-lft hitch on a sport 22FB
One dealer told us that he CANT add a reece or an eze-hitch sway and weight control hitch on the sport 22FB.
he says it has to be 26" away from the ball and the gas bottle is in the way.
another dealer told us no problem, just install the bracket at 28" and let the chain be on a bit of an angle.
Any thought if the second dealer is correct
The first two photo shows how the second dealer did it
the one with the red tape is the dealer that states it wont fit
Name:	2017-03-08 16.48.51.jpg
ID:	281055   Click image for larger version
Name:	2017-03-08 16.48.56.jpg
Name:	reese- ezelift will not fit under gas can.JPG
ID:	281057   Click image for larger version
waninae39 is offline   Reply With Quote
Old 03-08-2017, 03:46 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The second dealer is right. The fact that the chains hang at an angle has no effect in there effectiveness. Yes it does increase the tension on the chains by the trigonometric function of that angle but not to worry. Those chains will carry many times the load you are going to apply.
I would suggest you look at a sway control bar set up rather than the friction plate system. The friction plate system is a pain in the butt.
2004 Excursion 4x4
Old 03-08-2017, 03:47 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
this clearly shows all the parts and that the reece or eze-lft can fit on a sport 22FB
Name:	2017-03-08 17.29.26.jpg
Eze kleen black water hook up Mifair Waste Systems, Tanks & Totes 4 04-24-2013 08:17 PM
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
Kwik-Eze steps robber2711 Land Yacht/Legacy Motorhomes 10 01-11-2012 03:18 PM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
Help! Dealer put 4" scratch in lft mid corner panel ncbambi General Repair Forum 16 08-05-2009 12:54 PM
