Old 05-14-2012, 06:26 PM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Reese Dual Cam ?????
I followed etrailerís instructions on installing a reese dual cam sway control, Iím 18Ē from center of ball to pivot point on arm and the 600lb barís are to close to pivot arm, this canít be correct. Open for comments.............
toastie
ID:	158394   Click image for larger version
toastie is offline   Reply With Quote
Old 05-14-2012, 06:34 PM   #2
dznf0g's Avatar
Oswego , Illinois
The hitch head should be tilted back several notches. You should have a minimum of 5 links under tension on the chains. Try that and get some more pics to us.
-Rich-
Old 05-14-2012, 06:35 PM   #3
dznf0g's Avatar
Oswego , Illinois
Don't pull like it is now. You WILL bent those cam arms.
-Rich-
Old 05-14-2012, 06:37 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
It's probably that the frame rails are closer together and less of an angle then new trailers. Don't know how you will get around that.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 05-14-2012, 06:38 PM   #5
dznf0g's Avatar
Oswego , Illinois
Should look like something this:
-Rich-
Old 05-14-2012, 06:40 PM   #6
dznf0g's Avatar
Oswego , Illinois
Having issues with pic uploads????
-Rich-
Old 05-14-2012, 07:04 PM   #7
toastie's Avatar
1955 22' Safari
Thanks dznf0g, saving your great looking pictures to my hard drive. You can see in the picture that the hitch hasn't been tilted. Would you know the max tilt on the hitch.
Thanks very much
toastie
Old 05-14-2012, 07:04 PM   #8
dznf0g's Avatar
Oswego , Illinois
Toastie,
Something doesn't look right with your cam plates. The bronze things at the end of your chains. They appear to on backwards...or the u bolts are in backwards. I can't tell from the pics.
-Rich-
Old 05-14-2012, 07:09 PM   #9
toastie's Avatar
1955 22' Safari
Toastie,
Yes it's backwards, was in a hurry to take pictures.......
Old 05-14-2012, 07:09 PM   #10
dznf0g's Avatar
Oswego , Illinois
I don't know the max, but mine had either 4 or 5 notches showing (exposed) on the head on the trailer side of the silver thru bolt mounting plate. You can't do too much tilt, as a matter of safety or whatever. The slot in the head will only allow so much tilt before it hits the bolt.
What weight rating are your bars. With your light trailer, I'd start with 4 notches showing on the head and 5 links under tension on the chains.
Take a close look at those cam plates. maybe a close up pic?
-Rich-
Old 05-14-2012, 07:14 PM   #11
dznf0g's Avatar
Oswego , Illinois
Here's a better close-up after I got mine all dialed in. Trailer is to the right, TV to the left. Four notches exposed.
Yours will be different, I'm sure, to get dialed in but you gotta get a lot more tilt to clear those cam arms.
-Rich-
Old 05-14-2012, 07:20 PM   #12
toastie's Avatar
1955 22' Safari
Attachment 158403
Will dial it in, thanks very much...............
Old 05-14-2012, 07:59 PM   #13
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
dznf0g,
What weight bars do you have?
Thanks.
10Smiles is offline   Reply With Quote
Old 05-14-2012, 08:06 PM   #14
dznf0g's Avatar
Oswego , Illinois
Mine are 800#....but I have a 30' Classic. I would think you would want 600#ers.
OOPs, thought Toastie was posting, sorry.
800#ers would be perfect for you, IMHO.
-Rich-
Old 05-14-2012, 08:19 PM   #15
10Smiles's Avatar
2005 30' Classic
Thank you. My trailer came with the 1,200 pound bars. I felt like they were a bit strong, so I purchased the 800 pounders. I like it much better.
I think you have your bars bent more than I do though, maybe I'll try going another link tighter.
Don't mean to hijack the thread, back to toastie's issues...
Old 05-14-2012, 08:23 PM   #16
dznf0g's Avatar
Oswego , Illinois
Not sure what you are towing with, but those pics show it hitched up to a 1/2 ton Yukon XL, so the bars were pretty cranked up.
-Rich-
Old 05-15-2012, 05:59 AM   #17
toastie's Avatar
1955 22' Safari
Started with 4 and ended up at 5 notches, I'm at 6 chains links with good tension, (5 links was to much) but feel I need just a little more, the bars are 600#. Much, much better clearance.
toastie
ID:	158442   Click image for larger version
Old 05-15-2012, 06:10 AM   #18
dznf0g's Avatar
Oswego , Illinois
That looks DANDY! You may find, after you get you tanks on, gear in the truck and trailer, etc that you may need to go to 5 links. When you are ready to go, weight the rig by each axle, and then weight the loaded truck by itself by each axle. That'll get you exactly where you need to be. Tongue weight should be checked as well.
-Rich-
Old 05-15-2012, 01:41 PM   #19
10Smiles's Avatar
2005 30' Classic
That does look great. Now you have a useable setup. I hope you enjoy the trips.
Old 05-15-2012, 01:54 PM   #20
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
I was just wondering how those trunnion style bars are sitting on those cams? Are they nice and flat to where they wont wear into one side of the cam lobe or are they pitched to one side when under load causing a significant amount of wear in the cam? I have a unit thats wearing that way requiring a different head and bars.
Thanks Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
