Old 07-06-2015, 09:49 AM   #1
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Reducer Sleeve for Receiver
I did a search, but didn't find any threads on this.
Has anyone spot welded in the reducer sleeve that brings a 2.5 inch receiver down to 2 inch? With an Airsafe hitch, and Rock Tamers, it's a real (royal) pain to get the stinger in, and keep the holes lined up for the locking pin. I am thinking about just a couple of spots to keep the sleeve from slipping.
Is there any downside that you have encountered or can think of?
Thanks in advance.
Old 07-06-2015, 10:17 AM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
On WOODALLS.
Old 07-06-2015, 10:30 AM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
The sleeve on our class V Reese is welded, never been a problem.
Plus the extra thickness at the pin hole helps prevent elongation.
ID:	242340   Click image for larger version
Old 07-06-2015, 10:30 AM   #4
Free Range Human
Drathaar's Avatar
Twin Rocks , Oregon
Originally Posted by slowmover View Post
On WOODALLS.
Ok, I'm the slow one here. Woodalls?
Old 07-06-2015, 10:31 AM   #5
Free Range Human
Drathaar's Avatar
Twin Rocks , Oregon
Thanks Bob! Your post came in while I was typing.
Old 07-06-2015, 10:32 AM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
There is a recent thread here somewhere that addresses in great detail this subject. Look in this section, might be a page or two down.
MICHAEL
Old 07-06-2015, 11:08 AM   #7
jfowler218's Avatar
2007 31' Classic
Bend , Oregon
I put a spot weld on mine. It broke on first use which was fine because now the weld spot acts as a stopper to align the sleeve. I can use either size receiver
jfowler218 is offline   Reply With Quote
Old 07-06-2015, 11:14 AM   #8
1977 31' Sovereign
Lynnwood , Washington
Go the other way with it, Bro. Don't reduce. Get a 2.5" stinger.
When there's a choice, there's nothing wring with overkill (aka, over-engineering).
Tom
TomKirk is offline   Reply With Quote
Old 07-06-2015, 11:38 AM   #9
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
I welded also, Propride
DoublTrouble is offline   Reply With Quote
Old 07-06-2015, 12:20 PM   #10
The Cralls
thecralls's Avatar
2012 28' International
Bremerton , Washington
I have a Equqlizer hitch and I'm planning on getting the 2 1/2" hitch. I'm leery about modifying any part of a hitch since welding can alter the properties of the metal in ways it was not intended. I'm seeing more and more 2 1/2 ball mounts and such on the market, so I'm also planning on a new general use ball mount. The 2 1/2" mounts are rated for a much higher load than the 2".
thecralls is offline   Reply With Quote
Old 07-06-2015, 12:48 PM   #11
Thumbs up
Tom
I like the extra margin of safety that a class 5 receiver affords, a welded sleeve is the only safe way to go.
OEM IV.....
Reese V Tow Beast...
Old 07-06-2015, 12:56 PM   #12
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
2.5 hitch
I lost my receiver reducer when I got my new pickup. So I went with a 2.5 inch hitch. Other than being heavier to lift, I don't have the problem of the movable reducer. But then again I can't put small stinger on the truck.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 07-07-2015, 07:54 PM   #13
Richard
Kilo3's Avatar
2015 27' Flying Cloud
Midland , Texas
Bought an Equalizer with my 2015 AS 27FB since that's all the dealer sold. They ordered a 2" and supplied a reducer sleeve. It had a lot of wiggle room, so I ordered a new $50 sleeve "Made in America". It arrived with a stamp on the side that said "Made in China". It's slightly tighter, so I will go with it. Still some play, however, and the dealer says it's ok since when fully hooked up it can't wiggle. Anyone know?
Kilo3 is offline   Reply With Quote
Old 07-07-2015, 08:01 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
There is some motion/slack. Things have to have enough room to fit together even when there is road debris or dirt embedded.
Peace and Blessings..
Channing
WBCCI# 30676
Broken sleeve on stabilizer crank SSquared General Repair Forum 24 04-17-2015 08:44 PM
What is it - pressure reducer? 68ambassador Fresh Water Systems 5 04-03-2012 07:42 AM
Pressure Reducer?...Regulating Valve? Hihosilver2 Fresh Water Systems 0 06-06-2010 03:10 PM
ZipDee Sleeve Leak henw Awnings 3 04-05-2010 01:00 PM
Zipdee fabric roller sleeve Lumatic Awnings 10 11-15-2009 08:43 PM
