07-06-2015, 09:49 AM
Free Range Human
2012 25' FB Flying Cloud
Haines
, Oregon
Reducer Sleeve for Receiver
I did a search, but didn't find any threads on this.
Has anyone spot welded in the reducer sleeve that brings a 2.5 inch receiver down to 2 inch? With an Airsafe hitch, and Rock Tamers, it's a real (royal) pain to get the stinger in, and keep the holes lined up for the locking pin. I am thinking about just a couple of spots to keep the sleeve from slipping.
Is there any downside that you have encountered or can think of?
Thanks in advance.
07-06-2015, 10:17 AM
Vintage Kin
Fort Worth
On WOODALLS.
07-06-2015, 10:30 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
The sleeve on our class V Reese is welded, never been a problem.
Plus the extra thickness at the pin hole helps prevent elongation.
Free Range Human
Haines
, Oregon
Originally Posted by slowmover
On WOODALLS.
Ok, I'm the slow one here. Woodalls?
07-06-2015, 10:31 AM
Free Range Human
Haines
, Oregon
Thanks Bob! Your post came in while I was typing.
07-06-2015, 10:32 AM
Biloxi
, Mississippi
There is a recent thread here somewhere that addresses in great detail this subject. Look in this section, might be a page or two down.
MICHAEL
07-06-2015, 11:08 AM
2007 31' Classic
Bend
, Oregon
I put a spot weld on mine. It broke on first use which was fine because now the weld spot acts as a stopper to align the sleeve. I can use either size receiver
07-06-2015, 11:14 AM
1977 31' Sovereign
Lynnwood
Go the other way with it, Bro. Don't reduce. Get a 2.5" stinger.
When there's a choice, there's nothing wring with overkill (aka, over-engineering).
Tom
07-06-2015, 11:38 AM
2017 25' International
Carlsbad
I welded also, Propride
07-06-2015, 12:20 PM
Dan and Lynda
2012 28' International
Bremerton
I have a Equqlizer hitch and I'm planning on getting the 2 1/2" hitch. I'm leery about modifying any part of a hitch since welding can alter the properties of the metal in ways it was not intended. I'm seeing more and more 2 1/2 ball mounts and such on the market, so I'm also planning on a new general use ball mount. The 2 1/2" mounts are rated for a much higher load than the 2".
07-06-2015, 12:48 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Tom
I like the extra margin of safety that a class 5 receiver affords, a welded sleeve is the only safe way to go.
OEM IV.....
Reese V Tow Beast...
07-06-2015, 12:56 PM
2007 25' Safari FB SE
Bozeman
, Montana
2.5 hitch
I lost my receiver reducer when I got my new pickup. So I went with a 2.5 inch hitch. Other than being heavier to lift, I don't have the problem of the movable reducer. But then again I can't put small stinger on the truck.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
07-07-2015, 07:54 PM
Richard
2015 27' Flying Cloud
Midland
Bought an Equalizer with my 2015 AS 27FB since that's all the dealer sold. They ordered a 2" and supplied a reducer sleeve. It had a lot of wiggle room, so I ordered a new $50 sleeve "Made in America". It arrived with a stamp on the side that said "Made in China". It's slightly tighter, so I will go with it. Still some play, however, and the dealer says it's ok since when fully hooked up it can't wiggle. Anyone know?
07-07-2015, 08:01 PM
1999 34' Excella
Hillsboro
There is some motion/slack. Things have to have enough room to fit together even when there is road debris or dirt embedded.
Peace and Blessings..
Channing
WBCCI# 30676
07-07-2015, 08:31 PM
2010 28' Flying Cloud
Lower Alabama
, USA
Here is the recent thread on the issue of loose fits
http://www.airforums.com/forums/f464...ay-136126.html
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
07-07-2015, 08:43 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
A friend of mine and I welded my sleeve solid in my 2500HD. Then I ran a 5/8" drill bit through it to make sure I had a smooth fit. No slop and it works great.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
07-07-2015, 09:53 PM
Flagstaff
Spot weld or three should work. A tiny spot weld is not going to change the metallurgy in any way that matters. I haven't seen a hitch that isn't welded anyway and I'm confident that they don't heat treat after welding. Unless you have a hitch that was CNC milled out of a solid block of steel.
07-25-2015, 10:01 PM
2014 27' FB Classic
Cambridge
, New York
My two upgrades for this year were a new '15 Ram 3500 and an Airsafe Class VI hitch, which came with a 12" bracket to mount my E-quil-izer WD hitch. The Airsafe has a 2" shank and the Ram came with a Class V hitch with a 2.5" receiver and 2' sleeve. The combination AirSafe/E-quil-izer bolted together is 18" long, not counting shank, and about 60 lbs. I found that, when inserted in the sleeve/receiver and pinned, I could grab the back of the hitch combo and move it 3-4" up-down and left-right. Very sloppy tolerances. As we were leaving for a 3000 mile trip I shivved it with some aluminum sheet metal and duct tape (of course!). It helped some, but still sloppy in my opinion. When my engineer son-in-law looked at it, he seemed to think that most of the slack was between the 2" (solid) hitch shank on the AirSafe and the Ram-supplied reducer sleeve. His proposed solution was a 1/4" bead weld front and back affixing the sleeve to the shank. It really is not load-bearing, so might be a bit of over engineering - but I'm always good with that. Besides the additional wear-and-tear caused by the sloppy fit, I also wonder if it negated the WD effect of the E-qual-izer by taking up so much of its forward torque in the slack, rather than transferring it (and the tongue weight) forward to the TV front axle.
Any thoughts? As always, I learn much from the expertise on this forum...
Tim
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
07-30-2015, 12:20 PM
Vintage Kin
Fort Worth
A better hitch receiver would be my choice. The TITAN #45299. See etrailer. A full crossmember replacement.
And then diagonal bracing from the receiver tube that clears the spare to well forward on the frame rails.
Or move spare to bed and extend receiver tube to near axle. Several reinforcements as well as cross bars.
I'm going to use above receiver and cut up the cheap CURT Class V I have now to serve as forward portion.
Controlling flex differences on frame rail ends is goal.
A schematic from the 1960s will show how we once did it with custom receivers. Use those as template. I've posted link here before from 1968 Plymouth full size.
Andrew_T knows this stuff backwards and forwards.
