I know that the issue of carrying cargo on the rear bumper of an Airstream has been addressed extensively on these Forums, but none of the strings that I could locate seem appropriate for this posting.
I recently came across two photos of late model Airstreams that were set up to carry significant weight on the back end. One is an Airstream that is for sale on Ebay that has a tool box installed on the rear bumper. The other is an Airstream that is offered for rent and sports a rack with a genset on it.
The tool box seems to be sitting on bumper support extensions that are welded to the frame. This appears to be a solid installation that was done with some thought.
On the Airstream with the genset, I can't tell how the rack is attached. It doesn't appear to be quite as well done as the tool box.
Any insight or comments wouild be appreciated. I don't know if I would want to carry a genset back there, but a small aluminum tool box would be super helpful in my travels.
Brian
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
The increased weight and length aside for the moment, that area tends to get drenched in water and mud/dirt/grease when towing. Think about how nasty the rear of a Suburban gets in the rain and snow. Any of that stuff would work its way into the box, and soak the tools, rendering them useless after a short time, no matter how well you try to seal it.
Terry Change is inevitable, except from a vending machine
AIR#2611
Here we go again!
Another opportunity for me to pitch the Sewer Solution!
How much does all that slinkey stinkey stuff you folks tote around weigh? empty of course. Ditch it and get a SS,
And what about that 30 foot long #10 gauge power cord!Mine is stowed in the rear bumper hatch. I'm thinkin of relocating it like the newer trailers, so I can put the cord in another underside bin. Then I'll put my bike on the bumper! Weight is weight is it not?
And what about that pic posted on this forum with the wally in the alps with a bike on the back of this trailer?
A genset is a little much!
On another note; Moosetags- Thank you once again for the best thread of 2007, your trip is most inspiring!
DG
The 2 worst things that can happen to an old aviator:
(1) One day you will walk out to your aircraft,
knowing that it will be your last flight.
(2) One day you will walk out to your aircraft,
not knowing it will be your last flight.
Here we go again!
DG
I'm already using the Sewer Solution, and I think that it is great. I'm still carrying a slinky, though, as I haven't found a way to use the SS at a group sewer dump. The water supply does not usually lend itself to SS use.
Thanx for the kind words on "Lucy's Great Excursion". It was fun doing it. In April, Lucy will be on her way to Moosehead Lake in the Maine backcountry, and I'm planning another electronic trip log.
Brian
And by adding the extension and weight, you can mess up the warranty on any NEW vehicle or cancel out and guarantees on a used one. I'd be very careful about doing any of the above. We've had posts where that has happened - why mess up a good thing.......as 2air questioned, "Why try turning a thoroughbred into a pack animal?
________________________________
2007 Airstream International SS OB
2004 Nissan Pathfinder Armada
Equal-i-zer Hitch
Prodigy Brake
I can not wait for Inland Andy to chime in. If it will not fit in the compartment between the bumper then it is too big or heavy from what I have read. In the end however, one of the reasons I bought an airstream was for the beauty and simplicity of the design. These add ons are well, UGLY.
I agree that it is ugly, but the Yamaha generator is about 140 lb, so it is not a big weight. I've been carrying 500 lb Personal Watercraft hanging on rear hitches on the 4-th motorhome to date. Don't really feel it there, but than -fishtailing is not an issue on motorhome.
And a motor home has a truck frame to support it, where an Airstream's frame is supported by the body, and not very substantial.
AIR#2611
Well each his own and it seems the beauty of these RVs is just what got me so interested. If you want to paint it pink with polka dots go ahead. I have had 5-6 other SOB from Class A to travel trailers and I always pointd out airstreams. Finally my wife said to buy one and get it over. I love that women!!
140 pounds, is "dead" weight.
That is not what the generator weighs at the bumper..
As an example, if the generator is 10 feet rearward of the rear tire, then the generator now weighs 1400 pounds, sitting still.
Then when you hit just a small bump, that weight will suddenly multiply by 2, 3 or even more times.
"Moment arm" is the name of the game.
Moment arm changes the complexion, quickly, in an aircraft or anything that is towed.
Anything over the weight of a sewer hose and it's related fittings, is "begging" for trouble on bended knees.
It doesn't matter how much you beef up the frame, you cannot change the moment arm.
In fact, adding additional weight to the frame to hold a storage box at the rear, just adds to the moment arm situation, and in time, "will" rip apart the rear end.
