Old 02-07-2015, 06:56 PM   #1
LOGRIDER's Avatar
2014 27' FB International
Avila Beach , California
Rear axle gear ratio question, no, it is not what you think!
Gang,
We are in the process of purchasing a used- obviously- 2012 Ram 2500 diesel.
The outfit does not have the original build sheet and the dealer seems incapable of finding out what the differential gear ratio is.
Mind you, this thing, even with 3:49 (or whatever) is fully capable of pulling our 2014 27ft International, however, for you experts out there, those more mechanically inclined than I, is there any way to determine what the rear end gear ratio is? Is it somehow reflected in VIN or???
Thanks.
Logrider
Logrider
"don't let life get in the way of living"
LOGRIDER is offline   Reply With Quote
Old 02-07-2015, 07:10 PM   #2
Gainesville , Florida
The parts or service dept should be able to run a build sheet. Any Dodge dealer can do it. All you need is the vin. Jim
Old 02-07-2015, 07:15 PM   #3
Wayward's Avatar
Cary , North Carolina
Dealer can get the build sheet. You can contact Dodge if you have the VIN.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 02-07-2015, 07:15 PM   #4
1994 34' Excella
Warren , Manitoba
If the Dodge dealer you are dealing with can't run the build sheet, it's time to "run" from that dealer. Basic ratio is 3.42 but it could be lower. You will have enough power to pull your trailer in any case.
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 02-07-2015, 07:27 PM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Guys, there is a better way. Go here: Ram Trucks - Recall
Click the link on the left hand side of the page that says EQUIPMENT LISTING
Enter your VIN and you will get a build sheet in PDF format.
We bought used, and this is how we verified our truck was 3.92 and had 32 gallon tank.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 02-07-2015, 09:34 PM   #6
1998 30' Excella 1000
Livingston , Texas
I just crawled under my 2015 Ram. The axle ratio was printed on a label on the bottom of the axle.
Siegmann is offline   Reply With Quote
Old 02-07-2015, 09:39 PM   #7
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
There is a tag on the rear housing cover with the gear ratio and some other numbers, most likely 3.73 , good ratio ,I would like to try a 3.54. Either one is good...
Old 02-08-2015, 03:21 AM   #8
Nomadic , USA
Depending on configuration it can only be one of 3 options. 3.42 - 3.73 or 4.10
http://www.ramtrucks.com/shared/pdf/..._Tow_Chart.pdf
I'd pass on 3.42 and aim for 3.73 or 4.10 depending on how you'll tow.
When it came to the half tons, the majority we looked at had the lower 3.21 gearing and some where 3.55. Took lots of looking to find one with 3.92 and the larger fuel tank. But we got it done using the vin reference I posted above.
The gearing is based on the transmission in the truck. Also, as stated it is usually stamped on the axle, but not all. Mine doesn't have it stamped on ours for axle. You win some, you loose some. But the Vin thing is always 100%.
Old 02-08-2015, 06:41 AM   #9
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Hey there logrider, don't get dirty while under the pickup looking at the tag on the axle housing which is on one of the bolts of the rear cover, we will be in oceanio about the first of April, to see my old friend Mr Beck, will try to remember to get in touch,you will like the dodge...,
Old 02-08-2015, 07:05 AM   #10
LOGRIDER's Avatar
In the dealer's defense, they are not an actual Dodge dealership but rather a independent. Nevertheless thanks to the suggested web site proffered by Bold Adventure, with the VIN, now I know everything there is to know about the oufit..I love this forum...a lot of knowledge out there, if you just know who to ask.
Logrider
Old 02-08-2015, 07:22 AM   #11
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
My Ford has an axle-type indicator on the sticker that is on the driver's door frame. Maybe yours has the same?
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 02-08-2015, 11:53 AM   #12
1976 31' Sovereign
Oswego , Illinois
The higher number more pulling power less economy lower top speed unless 3.71 4.10 etc. as dif. manf. have dif. ratios. High #s. for small horse power engine, unless you are going to move a house then you would need higher #s. I have been pulling all kinds of trailers & wghts. for well over 60 yrs. never had to specify high # rear axle, always had high horse power engines.
Old 02-08-2015, 02:40 PM   #13
2015 25' Flying Cloud
Apollo Beach , Florida
On subject with this post but TV is a F150 4x4 super cab Ecoboost, will be picking up our new 25' FC on Tuesday and asking the same question. What is your average electric bake controller setting or is it about the same 5 to 6 as most of the post suggest for the F250 and larger.
Guyel is offline   Reply With Quote
Old 02-08-2015, 02:41 PM   #14
Sorry fellas ask my question on the wrong post site.
Rear End Gear ratio Bfrank Mechanics Corner - Engines, Transmission & More... 3 05-15-2008 01:08 PM
Gear ratio (rear end) for towing bhayden Tow Vehicles 19 06-20-2006 08:23 AM
Gear Ratio ? slow-canoe Mechanics Corner - Engines, Transmission & More... 9 04-10-2006 08:29 PM
Gear ratio for my GM TV Double D Tow Vehicles 20 02-16-2006 07:41 PM
tow vehicle gear ratio redlion7 On The Road... 16 03-07-2004 06:25 PM
