Old 06-24-2013, 03:29 PM   #1
oldfulltimer's Avatar
1993 34' Excella
Randolph , Vermont
Realignment of triple axle
Recently returned from a three week trip and found tires on my 1993 34' triple axle to be wearing in a weird pattern and axles probably need realignment. We live in Vermont and trying to find someone in the Vermont area who could realign these axles properly. Does anyone have suggestions???
oldfulltimer is offline   Reply With Quote
Old 06-24-2013, 07:11 PM   #2
Charley72's Avatar
1970 27' Overlander
Willlamstown , Massachusetts
Try Justin Taylor at Nomad/GSM in Plattsburgh, NY. They do nothing but custom work on vintage Airstreams. He did a great job on my 72 Overlander.
Charley72 is offline   Reply With Quote
Old 06-25-2013, 05:38 AM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
A shop that services big trucks and trailers -- tires/brakes/alignments -- is my choice.
Old 06-25-2013, 06:44 AM   #4
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Could it be normal "scrubbing" wear from turning with the triple axles??
Someone here posted about using an 8' flourescent light bulb, placed along the 3 tires, to do a check.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 06-25-2013, 06:46 AM   #5
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
The belts in you tires possibly causing tread distortion.
Also too much air or not enough tire pressure can cause tire problems.
If you trailer isn't level with your truck when pulling ,you can put more trailer weight on the 2 rear axles and not the front causing abnormal front axle/tire wear pattern.
Anybody else that has opinions concerning this, please chime in!!!
If your trailer tires are more than 5-6 yrs old you might want to change them.
They are at their maximum life expectancy!!
william Haym is offline   Reply With Quote
Old 06-25-2013, 08:07 AM   #6
What's the age of the tires?
Is the running gear properly balanced?
