Old 06-17-2015, 05:05 PM   #1
Vancouver , Washington
Range Rover rehash
New to forum but need to know all that has been discussed using the P38 Range Rover. We are targeting a 25' International Serenity. The stumbling point is tongue weight. I have towed very heavy utility trailers with this vehicle with TW far beyond that which Land Rover advertises. The receiver on the P38 Range Rover has two connection points to two separate frame members so rotational torque is held at minimum, unlike standard class III after market hitches. What are the suggestions to meet the TW AS is requiring for the 25' International?
Kumark1013 is offline   Reply With Quote
Old 06-17-2015, 07:02 PM   #2
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
I am towing our 2014 Serenity 25FB with a 2008 Range Rover HSE with the Westfalia hitch rated for 770 lbs TW and 7716 lbs trailer weight. AS sold and installed a Blue Ox Sway Pro with 1,000 lbs bars. Land Rover installed the brake controller and the service techs said that the RR should have no problem with the weights and WD for the Serenity. We have 600 miles so far with the highest elevation of 1,500' and so far no problem but you will know the AS is there on long grades if you can't start out at 55 mph.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 06-17-2015, 07:21 PM   #3
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
BTW, welcome to the Air Forums and good luck in your search!
towing an Airstream with 2008 Range Rover Sport allen galkin Tow Vehicles 17 06-20-2014 07:26 PM
Towing with 2006 Range Rover ghaag Tow Vehicles 15 06-30-2010 01:46 PM
2008 Toyota Landcruiser or 2006 Range Rover ghaag Tow Vehicles 5 06-02-2008 11:12 AM
Range Rover Sport w/ equlizer 64Vette Hitches, Couplers & Balls 0 05-04-2007 07:44 PM
towing with a 94 range rover maryszka Tow Vehicles 3 02-17-2004 06:36 PM
