Old 05-03-2014, 01:31 PM   #1
San Antonio , Texas
Range Rover HSE 2014
New vehicle...new capacities...supposed 7700 lb tow limit. Any thoughts regarding the possibilities? It is a Supercharged V-6, 300+ horse...300+ torque.
GreyLens is offline   Reply With Quote
Old 05-22-2014, 09:31 PM   #2
Jr1974's Avatar
2012 25' FB Eddie Bauer
Issaquah , Washington
I towed with an '04 Rover for two years and just completed my first trip with my new tow vehicle today (2014 Tundra). Honestly, although the Tundra is much better on the steeper hills, the ride with the Rover was better. Keep in mind that the 04 has less HP and Torque than the newer models, so I think you will be very happy. Don't let the naysayers discourage you (short wheel base, unreliable.... Blah, blah, blah). The range rover is a hell of a tow vehicle. Airstream website has a RR on their home page last I checked.
Jr1974 is offline   Reply With Quote
Old 05-23-2014, 10:35 PM   #3
2004 16' International CCD
Chicagoland , Illinois
What do you plan to tow with it? How much "stuff" do you drag along with you in the vehicle? It doesn't have a high payload capacity. I think you could fill it with people and gear and go WAY over the vehicle's payload capacity if you weren't pretty careful.
Airrogant is offline   Reply With Quote
Old 05-27-2014, 12:51 AM   #4
Vitaminsea's Avatar
2012 28' International
Alameda , California
Have the v8 supercharged. Lots of pulling power. The max hitch weight is 700#. It will pull 7700 by specs. But the hitch weight is limiting factor on bigger trailers.
The SUV is from the future in so many ways.
Vitaminsea is offline   Reply With Quote
Old 05-27-2014, 04:22 AM   #5
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Just get the hitch reinforced and be done with it. Makes a huge difference.
andreasduess is offline   Reply With Quote
Old 05-27-2014, 11:24 PM   #6
Vitaminsea's Avatar
Even with the 2014 range rover losing 700# with new aluminum, it's the suspension and total weight that limits me. The engine is amazing etc. My door sticker says 700# for the hitch. And about 1000# added for the gvw (people and gear and hitchThe SUV is great but for my 28' trailer not the right fit.
Old 05-28-2014, 07:25 AM   #7
N/A , N/A
If your vehicle is under warranty, reinforcing the hitch may void the warranty. I have seen photos of some massive hitch reinforcements on this forum -- Its not something you could hide from your dealer. The dealer could (rightly) assume you are overloading the vehicle (otherwise you would not need such a major reinforcement) and blame the issue on the overloading and refuse to fix it.
rostam is offline   Reply With Quote
Old 05-28-2014, 02:45 PM   #8
Toronto , Ontario
I showed my hitch reinforcement to my dealer - I trust him and wanted to get his opinion about any possible warranty issue. He admired the work, called it "very professionally done" and assured me that this would in no way void any warranty.
However, if anybody would come in with damage that would suggest that the reason for the damage is (for example) that the payload has been seriously exceeded then eyebrows might well be raised.
Old 05-28-2014, 03:12 PM   #9
Tltulsa's Avatar
1992 29' Excella
Tulsa , Oklahoma
There is a lot of debate regarding the GVW, tongue weight and such...and i'm not discounting any of it. But i towed our similar sized 29' 93 Excella 2000 miles behind a 2011 LR4. Mind you, V8 under the hood, but i've been told the Sport and LR4 share a chassis/suspension. Having said that, the RR's also often have towing software built in that compensate for trailer sway and whatnot. I'd call your RR dealer and have a detailed conversation. Towing alone is not always the issue, sometimes stopping quickly will be the real issue...or holding the line during traffic and or windy road conditions. I believe the weight of the RR's is an asset when things get weird.
1992 Excella Classic 29'
...2013 Chevy 2500 HD, 6.0 Gasser
Tltulsa is offline   Reply With Quote
Old 05-29-2014, 09:11 AM   #10
San Antonio , Texas
Wow, thanks to everyone for your replies. Much to think about.
I'm new to towing...reading as much as I can before we commit. Here's an older article that raises a number of issues. Whew!
Q: When you speak of hitch reinforcement do you mean reinforcement of an equalizing hitch like Hensley?
We haven't decided on the Airstream size yet but it will likely be 25' or 28' length in Sterling or Serenity layout...though I lean toward to rear bedroom. Only two travelers and not a lot of additional gear...no generator, etc. Plan to stay in RV facilities...no backwoods stuff with the Airstream.
Old 05-29-2014, 08:29 PM   #11
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
That's my experience, too, my dealer was similarly impressed.
Strengthening the hitch addresses the frailties of the hitch, not the vehicle, and doesn't imply any overloading. There was a VAP audio file on here not so long ago in which the Canadian hitch wizard (He Who Must Not Be Named) explained that the SAE guidelines for hitch manufacture, those used by vehicle and after market manufacturers, were woefully inadequate and struggled to contain the forces exerted by even a moderately loaded weight distribution system, hence the required re-inforcement.
Talk of void warranties is at best, speculation.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 05-29-2014, 08:55 PM   #12
N/A , N/A
Things could be different in Canada. Hence, I suggest the OP take a photo of the hitch reinforcement, done by He Who Should Not Be Named, to his dealer and verify that it does not void the warranty.
Old 05-30-2014, 09:51 AM   #13
JFScheck's Avatar
Rockville , Maryland
Images: 33
What is the max payload?
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 05-30-2014, 03:56 PM   #14
raleigh , California
Payload?
Why do you ask questions you already know the answer to?
NCstreamer is offline   Reply With Quote
towing an Airstream with 2008 Range Rover Sport allen galkin Tow Vehicles 17 06-20-2014 07:26 PM
Towing with 2006 Range Rover ghaag Tow Vehicles 15 06-30-2010 01:46 PM
2008 Toyota Landcruiser or 2006 Range Rover ghaag Tow Vehicles 5 06-02-2008 11:12 AM
Range Rover Sport w/ equlizer 64Vette Hitches, Couplers & Balls 0 05-04-2007 07:44 PM
towing with a 94 range rover maryszka Tow Vehicles 3 02-17-2004 06:36 PM
