Old 04-30-2015, 09:21 AM   #15
2015 25' Flying Cloud
Apollo Beach , Florida
F150
Originally Posted by BambiTex View Post
Empty mpg is pretty good for a 4x4. What is your axle ratio?
2013 F150 4x4 supercrew
145" wheelbase
Eocboost 3.5L V6 engine
3.55 Electronic lock RR Axle
tow package
36 gal fuel tank
Driving around town I get about 17mpg. On the interstate from Florida to GA at 70mph I avg 20 to 21 mpg in the warm weather. I do notice I get less mileage in cold weather. 40,000 miles on truck to date.
Guyel is offline   Reply With Quote
Old 04-30-2015, 09:26 AM   #16
dznf0g's Avatar
Oswego , Illinois
Originally Posted by SCOTTinNJ View Post
Intersting. I thought the mpg would be noticably higher. I get nearly that with my 5.0 V8.
We have a tendency to get numbed to the raw numbers because we always think MPG.
So (Chev 2500 6.0 gas vs. Duramax for my experience and example)
6.0l = 9.5mpg
Duramax = 12.5mpg
Doesn't sound like a lot, but it is a 31.5% increase with diesel.
-Rich-
Old 04-30-2015, 10:33 AM   #17
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
6.0l = 9.5mpg
Duramax = 12.5mpg
This is all true, but now factor in the cost difference during what I see on these forums is about 2 years before people get bored with their ride and just have to change.
George
gandttimes is online now   Reply With Quote
Old 04-30-2015, 10:39 AM   #18
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Air bags would have no effect on scale weight. All they can possibly do is level the trailer with the truck.
TinCan
graysailor is offline   Reply With Quote
Old 04-30-2015, 10:43 AM   #19
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
6.0l = 9.5mpg
Duramax = 12.5mpg
Excellent point. To further confuse the matter, the 6.0 only needs 87 octane.
Today's national average for 87 is $2.58 and diesel is $2.81. That's 9% difference. Add for DEF and you are probably looking at a 10-11% offset for fuel costs, making the 31.5% MPG difference more like 20%.
If you needed premium in a gas truck (Ford Ecoboost, Silverado 6.2L), that's $2.97 today. All of a sudden that 31.5% jumps to the mid 30's.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 04-30-2015, 11:40 AM   #20
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
DEF-
It isn't that big of a cost. It is $2.69/gal from the truck stop. My truck gets about 1,000 mpg of DEF. So that is about .00269 cents per mile.
You can read about my RAM 1500 EcoDiesel here.
My fuelly is here.
Lance
Top is offline   Reply With Quote
Old 04-30-2015, 12:17 PM   #21
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
In my mind it is not just the fuel cost difference that one needs to take into consideration... One also needs to consider that the diesel costs about 12,000 more when purchasing. Also an oil change will run you about 200.00 per change.
Finally, one needs to remember that injectors will need to be changed out every 150,000 km. The cost for that here in Canada is 9,000.00 (I know I just did it) So as you can see, the operational costs of Diesel can really be substantial compared to gas and at the end of the day you better plan on putting many hundred's of thousands of miles on an engine if you ever hope to make it pay.
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 04-30-2015, 12:37 PM   #22
st augustine , Florida
The cost difference in the ECO Diesel here is about $3500 over the V-8. Oil change for diesel here is $99.00
A larger diesel is probably more like you described.
Vagante is offline   Reply With Quote
Old 04-30-2015, 02:31 PM   #23
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
I hate to say it, but Nissan is nailing a missing segment with their upcoming truck. 310 HP with 555 lb-ft of torque. Payload likely over 2000 lbs.
Old 04-30-2015, 07:18 PM   #24
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Maybe. Depends how the fuel economy is vs the 3/4T Cummins, Duramax and Powerstroke.
It doesn't help that the truck itself is, shall I say, less than appealing.
Lance
Old 04-30-2015, 07:26 PM   #25
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
That's true. But the 555 lb-ft of torque is right in the sweet spot for a larger Airstream. The 750-850 lb-ft of today's 3/4 tons is really overkill for a 8,000-10,000 lb trailer. And the 6.0-6.4 L gassers are seemingly underpowered and certainly inefficient.
My assumption is that the fuel economy will be between the Ram Ecodiesel and today's bigger diesels.
Old 04-30-2015, 08:50 PM   #26
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Originally Posted by Makaira View Post
We have a 2014 EcoDiesel and a 28 foot International behind it. We are in it all of the time and move about 2x per month (not Jan/Feb/Mar however). We get in the 30s on highway driving (even up to 40 sometimes). Regular town and country driving is about 24- 26. When we tow, we get between 18 and 22 unless its all uphill, of course. We have airbags on the rear which have made a big difference in our scale numbers. Have not had any issues with the truck itself which we purchased in May 2014. Lastly, we really l like the truck.
If your truck is getting 18- 22 mpg towing a 28ft International you should have it bronzed and put in the Ford Museum
How are u calculating your fuel mileage???
Something is wrong here.........
Old 04-30-2015, 08:53 PM   #27
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
He is referring to the Ram Ecodiesel not the Ford EcoBoost
Old 04-30-2015, 09:06 PM   #28
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Yup, and that does seem oddly high, considering Top's detailed thread, where he claimed he got 16MPG, and he keeps detailed records on Fully, so I'm a believer.
http://www.airforums.com/forums/f463...ml#post1586735
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Ford F150 3.5L Eco Boost tlcbuilder Tow Vehicles 601 05-19-2014 08:05 PM
2015 Ford Expedition with Eco-Boost Roadtech Tow Vehicles 16 02-24-2014 04:43 PM
Interesting read on the Eco-boost Denis4x4 Tow Vehicles 4 08-21-2011 11:58 AM
