Old 11-23-2015, 06:47 PM   #15
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Originally Posted by Inland RV Center, In View Post
Please be advised that several tests were made using automatic rear end leveling.
They "ALL" proved the same DISADVANTAGE.
When automatic leveling took place, the principle purpose of the load equalizing hitch was VOIDED by that system.
Further proof was the large number of roll over accidents that we (Caravanner Insurance) paid for when automatic leveling was used. Also improper inflated "air bags" and "air shocks" did the same thing, namely defeating the purpose of a load equalizing hitch.
Simply put, it took the bend out of the bars, meaning weight was not being properly transfered.
Do you have any empirical evidence for other air suspension systems such as my 2008 Range Rover HSE? I have Blue Ox WD with 1,000 lbs bars that remain bowed when vehicle is level and running. Thanks.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 11-23-2015, 07:49 PM   #16
interstateflyer's Avatar
2017 25' International
Los Osos , California
Buzz kill.....
interstateflyer is offline   Reply With Quote
Old 11-23-2015, 10:02 PM   #17
I towed a 6,000 pound trailer with my 2001 Tahoe equipped with a rear air load leveling system. The weight distribution system was initially set up with the load leveling system at rest, not active. The air system kicked in after approximately 2 miles of running and brought the SUV and trailer to a level attitude. I towed over 100,000 miles with this combination all over the U.S. mountain west, southwest and Canada. The WDS and Air Leveling system was very effective and reliable.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
Old 11-23-2015, 10:50 PM   #18
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
As with any rig, the Cat scales are the best answer as to whether or not the weight distribution bars are working or not and restoring the load to the front axle.
I suggest that for a vehicle equipped with self leveling air bags it is very important to check it out on the scales since you cannot do the dimensional measurements and checks to confirm deflections, etc. So the scales will let you know where you are after the truck levels up automatically in terms of WD.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Ram 2500 Auto Level Rear Air Suspension NoNameinNM Tow Vehicles 22 10-27-2015 08:37 PM
2014 Dodge 2500 rear suspension change crispyboy Tow Vehicles 0 07-03-2013 06:14 AM
Auto Leveling Jack Paintedpony Jacks, Stabilizers, Lifting and Leveling 1 10-11-2010 01:53 PM
Auto leveling on tow vehicle... arm4 Hitches, Couplers & Balls 36 06-15-2009 11:59 AM
2008 Expedition- axle ratio and load leveling suspension JHollenbeck Tow Vehicles 30 05-15-2008 07:55 PM
