07-14-2017, 06:23 PM
diesel maniac
Airstream - Other
Tucson
, AZ
Question for those towing with pickups
Can you open the tail gate while hooked up, or does it hit the jack? We are planning to use the bed of our F350 with topper for storage, would be nice to be able to open the tail gate when hooked up to the trailer.
07-14-2017, 06:24 PM
2017 27' Flying Cloud
Ocala
in a word.... NO
maybe with a propride or other longer shank hitch -- you may be able to have clearance....
i use an equalizer-- and I can not open the tailgate
07-14-2017, 06:25 PM
Biloxi
, Mississippi
Depends on the individual trailer hitch coupler shank. With some no problem. Others have reported issues.
MICHAEL
07-14-2017, 07:00 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
We. Can. Dodge 2500. Reese Straight Line hitch. Depends in drawbar length, I think.
07-14-2017, 07:05 PM
2016 25' Flying Cloud
Jupiter
I am using an Equal-i-zer, and if my truck and trailer are aligned in a straight line I can open my tailgate. I did have to turn my jack 90 degrees when I replaced it with a new one so that it would clear.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
07-14-2017, 07:06 PM
Tavares
My Ram 2500 Crew Cab Short bed with ProPride hitch, no problem dropping the tailgate when connected up.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
07-14-2017, 07:09 PM
2017 27' International
Fenton
, Michigan
Ram 2500 with Reese equalizer and electric tongue jack....No issues opening the tailgate.
2016 Ram 2500 6.4 V8
2017 Airstream International Serenity - 27FB
07-14-2017, 07:22 PM
Traveler
2017 25' International
Staunton
, Virginia
Ram 2500 crew cab power wagon package, fastaway e2 hitch, electric jack. I cannot open my tailgate.
07-14-2017, 07:35 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
With a Classic, Equal-I-Zer and an F-250 ..... nope.
07-14-2017, 07:38 PM
1995 25' Excella
xxxxx
, xxxxxx
I can
07-14-2017, 08:13 PM
2005 28' Safari S/O
Paradise
No problem with my Hensley hitch. Plenty of room with both an F250 and GMC 2500.
Steve
"THE OLDER I GET, THE BETTER I WAS"
07-14-2017, 08:21 PM
2003 Silverado with 19'. No WD. No problem opening tailgate.
07-14-2017, 08:26 PM
2007 22' International CCD
Corona
Toyota Tacoma, ProPride, jack not turned, plenty of clearance.
Yeah, yeah, I know, the stinger is really long.
We will not speak about the scars on my shins from it[emoji3][emoji3][emoji30]
07-14-2017, 08:34 PM
1994 34' Excella
Warren
, Manitoba
2002 Duramax with a Husky Center Line and no problems.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
07-14-2017, 08:41 PM
diesel maniac
Airstream - Other
Tucson
, AZ
So it seems like it is more of a hitch setup issue than a trailer issue. We rented a trailer this week with a Blue Ox Sway Pro and the tail gate would only open part way before hitting the jack. F-350.
07-14-2017, 09:15 PM
2012 25' Flying Cloud
Battle Lake
The Hensley/ProPride sway elimination linkage extends the distance of the trailer from the truck. No tailgate problems.
An extended stinger extends the distance of the trailer from the truck. It also increases the leverage of trailer sway forces transmitted to the truck's steering axle.
Doug and Cheryl
07-14-2017, 09:43 PM
2008 27' International FB
Venice
I think it all depends on the length of the shaft on the ball hitch and the height of the tailgate. 2014 Silverado, Airstream has a flag holder in front of the jack, ample room to open tailgate. Truck and trailer must be straight.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
07-14-2017, 09:45 PM
2014 27' FB Classic
Cambridge
, New York
I have a Ram 3500 and utilize an AirSafe/Equalizer combo. The double hitches give me plenty of room to open tailgate and even partially pull out the bed roller for access. If you are planning on towing with a one-ton, I suggest that you look into an AirSafe - much easier ride for both TV and TT - and you can open your tailgate!
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
07-15-2017, 04:42 AM
2018 27' International
Southeastern MI
, Michigan
I have an F350, mine hits the jack but opens far enough to get what I need. It rests on the plastic tailgate trim and does no damage. I have to climb the tire or step on the hitch to get something out of the bed too.
I wouldn't have it any other way.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
07-15-2017, 06:06 AM
2016 27' Flying Cloud
Hartsburg
, Missouri
It depends on the truck and hitch. Like others I have a late model ford and an equalizer hitch and the tail gate just barely hit the Jack. I purchased a 2 inch longer shank (14") and that solved the problem with no noticeable impact on how the trailer towed. On some posts you will see statements that increasing the shank will halve your allowable hitch weight. Well as stated above increasing the shank does increase the leverage the trailer exerts on tow vehicle and this does affect allowable hitch weight, but the increase is proportional to the increase in length. I did not notice any decrease in towing performance with a 2 inch longer shank.--Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
