Old 07-15-2017, 12:09 PM   #29
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
No for a 2014 Tundra pulling a 2014 25' FB with an Equal-I-zer
GammaDog is offline   Reply With Quote
Old 07-15-2017, 12:15 PM   #30
OriginalMrT's Avatar
2017 27' International
Orland Park , Illinois
2500HD GMC Sierra with Blue Ox the tailgate opens fully no problem.
Mark
OriginalMrT is offline   Reply With Quote
Old 07-15-2017, 01:13 PM   #31
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
I use an Equalizer on my 2008 F250 and I can open my tailgate, but I also have Firestone air bags set at 60lbs. to hold down the interstate hop.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 07-15-2017, 01:24 PM   #32
1994 34' Excella
Duncan , Arizona
Depends on the trailer and truck. We have an F250 with a 3" lift and the tailgate opens fine with our '94 34' Excella.
HeltzelEricE is offline   Reply With Quote
Old 07-15-2017, 01:30 PM   #33
Mollysdad's Avatar
Does it hit the motor housing or the post? I have almost the same setup and am curious. Would turning the motor head sideways cure the issue?
I think the Tundra tailgate is a bit taller since it has 23" of height in the bed.
I think not being able to open the tailgate to be a major pain. I'd get a longer shank by an inch or two. I don't think drilling another hole is feasible since they're solid and it changes the leverage inside the receiver.
I also can't believe there's much difference in Airstream A frames between models, e.g.. a 25' clears but a 27' doesn't.
I just visited the Equalizer web site to see the options, and in shanks the standard choices are a 12" long and a 18" long, both with a 3" drop and 7" rise (standard, I think)
So you'd gain 6" of length. That seems like a lot to me, as far as the torsion inside the receiver.
Curt makes one with a 14" length, more moderate. Same specs.
Old 07-15-2017, 01:41 PM   #34
2014 27' FB International
Sugar Land , Texas
2015 F150 2wd with Hensley hitch, no problem
us3rnam3 is offline   Reply With Quote
Old 07-15-2017, 02:03 PM   #35
2018 33' Classic
Newport , Pennsylvania
2015 GMC Denali equalizer and 30 ft Classic I can open tail gate
EarlM is offline   Reply With Quote
Old 07-15-2017, 03:29 PM   #36
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Originally Posted by Mollysdad View Post
Since the jack post has 3 bolts, I'd think turning the entire jack would demand 120 degree increments. In other words, you can't turn it sideways.
Yes, there are 3 holes in the frame where it gets mounted, but on my jack at least, there are extra holes provided so that you can turn it 90 degrees sideways. It's designed that way so that you can turn it if required to clear the tailgate.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 07-15-2017, 03:33 PM   #37
PVStreamer
2005 28' International CCD
Scottsdale , Arizona
Pvstresmer
Originally Posted by ITSNO60 View Post
Can you open the tail gate while hooked up, or does it hit the jack? We are planning to use the bed of our F350 with topper for storage, would be nice to be able to open the tail gate when hooked up to the trailer.
Had the issue when I changed from a 2500 Suburban to my current Ram 2500 Cummings. Rebuilt the hitch using a prefab 14" draw base with adjustable height. Now no problem dropping the tailgate as the added length from the truck allows the space. It also improves handling, especially backing with increased angle clearance before jack knifing. Easy and not expensive.
PVStreamer is offline   Reply With Quote
Old 07-15-2017, 04:26 PM   #38
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
So it seems like it is more of a hitch setup issue than a trailer issue. We rented a trailer this week with a Blue Ox Sway Pro and the tail gate would only open part way before hitting the jack. F-350.
2016 F350 and BlueOx. I can drop the tailgate if truck and trailer are straight.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 07-15-2017, 06:43 PM   #39
2017 25' International
Framingham , Massachusetts
2017 GMC 2500HD, Denali; 25FB International, Equilizer hitch set up, tailgate opens with room to spare.
quietguy is offline   Reply With Quote
Old 07-15-2017, 07:27 PM   #40
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My 07 new 17 2500 ram with Reese duel cam, have lots of room...
Old 07-15-2017, 08:13 PM   #41
jamieb1086's Avatar
Selbyville , Delaware
2016 Chevy High Country 2500 Duramax pulling a 2016 FC front bedroom, equal-I-zer hitch. Can open the tailgate even with the truck turned a bit.
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Watchung NJ Unit
jamieb1086 is offline   Reply With Quote
Old 07-15-2017, 10:51 PM   #42
Wconley's Avatar
2018 28' International
Renton , Washington
We have a 2013 F150 and 2013 23D. We couldn't until I loosened the three set screws on the jack head and rotate it 90degrees. Took me 5 minutes and now we can open our tailgate fully.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Ford F-1/F-100 Vintage Pickups for Towing a 1952 Flying Cloud chopperusa Tow Vehicles 6 02-17-2014 05:26 PM
LNG/Gas Pickups Denis4x4 Tow Vehicles 12 05-08-2012 05:35 PM
Chrysler recalls 242,000 Ram pickups from 2008-2011 JFScheck Tow Vehicles 0 07-13-2011 01:35 PM
Four big pickups get low marks in crash tests Airslide Tow Vehicles 54 02-19-2009 11:49 AM
GM recalling 155k Vans, Pickups and SUVs Silvertwinkie Off Topic Forum 0 02-10-2005 11:43 AM
