Old 02-07-2015, 11:27 AM   #1
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Question for F-250/F-350 folks, Re: Brake Settings
Just a quick question.
What setting are you using on your Ford brake controller? I will check/reset mine prior to a trip, but on wet pavement (a given in Oregon!), about 5.5 seems appropriate on our new truck.
2014 F350 & 2012 Flying Cloud 25 FB.
Thanks in Advance!
Old 02-07-2015, 11:33 AM   #2
Durango , Colorado
I have a 2013 F-250 Platinum Diesel, pulling a 2015 27FB International Serenity.
I have been using either 5.0 or 5.5 as the setting on my brake controller and it seems to be about right.
RVDreamer is offline   Reply With Quote
Old 02-07-2015, 12:12 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I use "6" on our 2015 F-250 pulling a 27' FB model. Seems to be fine. Almost all Super Duty owners I discuss this with seem to use a number between 5 & 7.
Bob Martel
WBCCI# 5766
Old 02-07-2015, 01:55 PM   #4
2006 30' Classic
Milton , Florida
Type of Brakes?
Originally Posted by Drathaar View Post
...What setting are you using on your Ford brake controller? ...
What type of trailer brakes do you have? Are they electric, or electric over hydraulic? Pulling a 30' Classic with Dexter E/H brakes with a 2010 F250 and the Ford ITBC, I am using a setting of 8.5.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 02-07-2015, 02:22 PM   #5
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
F350 6.7 Diesel - 30' FC - 6.5
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 02-07-2015, 03:37 PM   #6
Free Range Human
Drathaar's Avatar
Twin Rocks , Oregon
Nick, they are just electric, although I wouldn't mind having E/H disks.
Old 02-08-2015, 01:03 PM   #7
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Regardless of the trailer I pull or its weight, I always set the controller after load out. The Tekonsha P3 controller I use is amazing.
NavyCorpsman is offline   Reply With Quote
Old 02-08-2015, 01:18 PM   #8
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
I drive an '03 E350 4X4 van and tow a 29' Ambassador. I have my brake set in the range of 4-5 but I can change the setting throughout the day. It just depends on the driving conditions, whether the brakes have been sitting for a while or are wet, etc. You will also have to take into consideration the condition of the brakes on your AS - are they new or is there a significant amount of wear on the shoes.
Eagle & Bear is offline   Reply With Quote
Old 02-08-2015, 02:12 PM   #9
2010 27' FB Flying Cloud
Ashburn , Virginia
Trailer brake setting
2013 Platinum 6.7 PSD towing a 2010 FC 27FB. I'm using 6.0 and it seems right.
Rod Johnson is offline   Reply With Quote
Old 02-09-2015, 03:48 AM   #10
2015 25' Flying Cloud
Apollo Beach , Florida
Same question on brake setting but with a 2013 F150 Ecoboost 4x4 crew cab towing a 25FC? I would assume its in the same range 5 to 6 on the brake controller but if anyone has the same TV and TT I would expreciate your comments. I'm picking up my our new 25' FC tomorrow. Thanks again
Guyel is offline   Reply With Quote
Old 02-09-2015, 05:26 AM   #11
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
Thanks in Advance!
My 2008 Safari 27FB Airstream did not have self adjusting brakes as standard equipment from the factory. I bought the trailer used and had an Airstream dealer adjust the brakes and set the controller. He set the Ford controller on my 2011 F250 at 5.0. After some experience with it I found 5.5 was optimal.
Last year the Airstream factory service center in Jackson Center replaced my brakes with self adjusting brakes. I ran for a couple of thousand miles at 5.5, as recommended by the service department so the brakes could self adjust, and realized I wasn't getting much braking power with the new brakes. After some trials at 20 mph, I found the new brakes don't lock up until the Ford controller is set at 7.5. I'm currently running at 7.0.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 02-09-2015, 05:35 AM   #12
Florida 55's Avatar
Images: 42
One additional note regarding the Ford controller and the Ford integrated braking system. I've been in one panic stop situation when a car approaching from behind on a two lane road quickly passed me, whipped in front of the truck and then slammed on its brakes to make a hard right turn into a driveway. There was on oncoming car in the lane to the left and the ditch to the right had a steep drop off so there was no place to steer to avoid a collision. I had no choice but to hit the brakes hard at 50 mph. The entire rig stopped quickly and straight as an arrow, stopping short of hitting the offending turning car by 2-3 inches.
Chuck
Old 02-09-2015, 05:49 AM   #13
paiceman's Avatar
Chuck
Love a good happy story at the end - congratulations on a successful end. Love our Ford.
Bud
SAFE TRAVELS
Bud
Old 03-10-2015, 10:23 AM   #14
Storm Master
Ampman's Avatar
2005 25' Classic
2012 F-250 pulling an 05 25ft classic. Electric over hydraulic brakes. Sweet spot is right at 7.
Ampman is offline   Reply With Quote
250 MH :: 1990 Airstream 250 barend Airstream Registry Discussions 0 08-19-2011 08:32 AM
