Old 11-17-2016, 02:13 PM   #1
Dublin , Ohio
Question about tongue weights
I really, really, really want to purchase a Basecamp but only if I can tow it with my Honda Odyssey which several people have told me is doable.
I am not concerned about the 3,500 pound max weight which aligns fine with the towing capacity of the Odyssey. I am concerned about the tongue weight.
I have a hidden hitch receiver and it has a plate on it that says it has a max tongue weight of 350 pounds for a weight carrying ball mount. I called the place that installed my hidden hitch receiver (8 years ago for a bicycle rack) and they told me that for an Odyssey I really should not exceed 350 pounds in tongue weight.
I want this to work but I want to be safe and I am not sure what to believe.
bikechuck is offline   Reply With Quote
Old 11-17-2016, 02:16 PM   #2
FCStreamer's Avatar
2014 30' Flying Cloud
And what is the tongue weight of the Basecamp?
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 11-17-2016, 02:26 PM   #3
Dublin , Ohio
It is 410 pounds
Old 11-17-2016, 02:29 PM   #4
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Load toward the rear.
You might be able to lighten the tongue by loading up the back of the BC. I have no idea how it is configured (like where are tanks, etc.)...
BambiTex is offline   Reply With Quote
Old 11-17-2016, 02:38 PM   #5
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
I found this link in an old thread: http://www.odyclub.com/forums/. You may find more info there on towing ability. If you google "odyssey airstream airforums" or similar you may find threads that touch on this as well. Most people recommend using google to search these forums for better results. Just add "airforums" to your google search.
FWIW, doesn't look like you'll be in the majority if you decide to do it... Good luck and welcome, by the way! I just traded my Tacoma, which was a really awesome pickup, for a GMC 2500 to tow a 30' Safari. A little overkill, perhaps, but I've wanted a 3/4 ton for various reasons, anyway.
DaveMc is offline   Reply With Quote
Old 11-17-2016, 02:47 PM   #6
KSA63's Avatar
2011 28' Flying Cloud
Ramara , Ontario
There is a fellow on here that used to tow his 30+ foot airstream all over the place with a Honda Odyssey. I believe the setup was done by Andy at CanAm in London Ontario.
Beef up your existing hitch a bit or purchase a hitch with a better weight rating and you should be good to go!
Kevin
KSA63 is offline   Reply With Quote
Old 11-18-2016, 11:38 AM   #7
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Chuck
Check into adding airbags on your rear axle....for about $250 you're doing yourself and your truck a favor. I even had them installed on my Tahoe and 2,500 Suburban, don't like having to worry about being anywhere ner my TV capacity. Safe travels. jon
B00merang is offline   Reply With Quote
Old 11-18-2016, 02:14 PM   #8
N/A , N/A
You can change your hitch receiver. I believe Uhaul installs a class III hitch rated at 5000#/500# trailer/tongue weight. Also, you can buy a Sherline scale to weigh the tongue weight of your Basecamp. If travel ready, your tongue weight is 410#, I don't think Odyssey's suspension would know that extra 60#. If the tongue weight is more, obviously thats a different story.
rostam is offline   Reply With Quote
Old 11-18-2016, 02:26 PM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Do not know what year Odyssey is. A quick seaerh showed a Curt class 3 hitch for some years that carries 675 TW and 5000 lbs towing weight when used with a WD hitch. I would upgrade the hitch to tow an Airstream. Personally I would not count on the tongue weight being what the catalog figure is. I personally would not try to lower the tongue weight by moving stuff to the back or by loading more in the back of the trailer. Basically tongue weight is your friend when towing. You should probably check to see if your current hitch takes a WD setup and if it has a higher TW rating with the WD. My take is that you can do what you wish to do with the Odessey if you get the proper hitch.
Old 11-18-2016, 02:33 PM   #10
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
If you want to limit your Google search to just airforums, it is more effective to add the following string to the end of your search text,
site:airforums.com
than to include airforums as part of the search text.
Greg
greghoro is offline   Reply With Quote
Old 11-18-2016, 02:35 PM   #11
Cruiser6483's Avatar
1954 25' Cruiser
Bern - Thun , Berner Oberland
Images: 31
I live in Switzerland. Here and in the rest of Europe the weight on the hook of passenger cars is limited to 140 Kilo (308,65 lb). For my Airstream (3 tons) I should be 165 - 175 lb.
Greetings - Werner
Cruiser6483 is offline   Reply With Quote
Old 11-18-2016, 03:11 PM   #12
1988 25' Excella
1987 32' Excella
"I live in Switzerland. Here and in the rest of Europe the weight on the hook of passenger cars is limited to 140 Kilo (308,65 lb). For my Airstream (3 tons) I should be 165 - 175 lb.
Greetings - Werner"
Not sure I understand this. But I would not want to set up to European standards and then pull at 70 mph on an American interstate highway in the midwest with the wind. Here for a 6000 lb Airstream you ought to have 600 to 900 lbs tongue weight and a WD hitch. I am not at all sure that you cannot do it safely in other ways, but I know the tongue wt and WD hitch combination will work.
Real world tongue (hitch) weights kb0zke Towing, Tow Vehicles & Hitches 20 04-17-2016 09:56 AM
Can you trust Tongue weights provided by Airstream? Thiatt55 Towing, Tow Vehicles & Hitches 35 04-06-2016 10:23 AM
Share Your Real World Tongue Weights & Trailer Weights BoldAdventure Towing, Tow Vehicles & Hitches 182 06-23-2015 06:10 AM
Different Tongue Weights same size trailers 28' vs 27' Vitaminsea Towing, Tow Vehicles & Hitches 28 03-06-2014 07:56 AM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
