02-02-2012, 01:35 PM
Valparaiso
, Indiana
Purchasing Dilemma - 22ft versus 31ft.
I recently retired and have been looking for a smaller, older Airstream to restore and travel in (up to 22 ft). I've focused on smaller units because the rehab part seems less imposing as does towing, something I have no prior experience with. So far, every trailer I have looked at either requires major rehab (beyond my skill level) or is already rehabbed and priced accordingly. Out of the blue, I discovered a 1973 31ft Sovereign for sale not too far from my house. It is in need of some TLC, but nothing I can't handle and is priced right. However, the thing is huge when compared to the others and I am somewhat afraid to pull the trigger. I am having a hard time picturing myself lugging this thing around the country. My tow vehicle is a 2008 Ford F-150 2-wheel drive with the bigger V8. I would be grateful for any feedback from anyone who has experience with larger trailers. Thanks to all in advance for considering my request....
02-02-2012, 02:02 PM
1986 31' Sovereign
Miami
We ended up with a 31' for much the same reason -- the deal was right, the time was right. I had a (then)new Nissan Titan with a rated tow capacity of 9500# so was pretty comfortable with the big trailer (8600# max but we have never come close to that).
So, 45000 plus miles later I can report that the rig works just fine. We don't travel with a lot of stuff (we are half-timers) and there are just the two of us so the 1/2 ton works out. The 31 tows great - that length gives you great stability but can make for some interesting challenges backing into narrow campsites. Once you get some practice, it is actually pretty easy. We got some cardboard boxes, found a big empty lot on a Sunday morning and played "trailer jockey" school -- it really helped.
Would a big honkin' 3/4 or 1 ton with a zillion ft/lb of diesel torque work better? Probably. There are times, especially in the Rockies, where I am over in the "granny" lane doing 45 in third gear while those big duallys blow past me up the hill towing monster 5th wheels. If you collect antique safes or bowling balls or have a family of 9, this would be the way to go.
The 31' is very comfortable and has lots of storage. Also LARGE water, grey and black tanks (although yours is older and may have smaller tanks). I can comfortably boondock for quite a while before needing to dump.
Have fun, be safe and go camping -- nothing more demoralizing than having a camper that can't camp until it has had tons of work done.
mike
Plonk
Hi
Welcome to the forum.
I have a 30' trailer.
The general wisdom of the forum is that tow vehicles come and go while trailers endure. Accordingly it is better to get the right trailer and adjust your tow vehicle as necessary rather than the other way around.
The newer 1/2 ton trucks are capable of towing a Sovereign but will not do so as comfortably as a 3/4 ton truck. Indiana being fairly flat you would do OK. The problem is not one of safety or handling but rather the fact that the truck will wear somewhat faster than it should particularly if towing in the mountains or other demanding conditions. So perhaps you might work with the truck you have for a while and then think about a 3/4 ton truck next time.
From a driver skill standpoint, a 30' trailer is not much harder to drive than a 22 foot trailer. When people get cold feet and sell their trailer because they can't drive it, the problem is almost always that they never figure out how to back up. Length makes little difference with this basic skill.
The main disadvantage, in my experience, of a 30'/31' trailer is that they are more difficult to park in ad hoc sorts of situations. With most tow vehicles a 22' trailer can be parked using two stalls at a grocery store or mall or whatever and can usually be parked on city streets without blocking driveways. With a 31' trailer I use up 6 or 7 parking places at a grocery store because I have to park across them. Similarly I can't fit into some driveways and have to look harder to park on residential streets.
They're not as cute as the little trailers either.
I like my 30' and consider it a good tradeoff. While I would like the extra space a 34' offers I would not want the cost and hassle of maintaining a 3rd axle.
02-02-2012, 02:04 PM
1997 34' Limited
South of Atlanta
, Georgia
We have a 34' triple axle Airstream. Ou tow vehicle is a 2009 F150 with a 5.4L V8. We have towed her around the Southeast and up through the Smokies with out any trouble. You will need to keep an eye on the total weight of the truck, but fine otherwise. I do recommend a really good hitch setup. We changed from a Reese weight distribution setup to a ProPride hitch and it may a huge difference in comfort level of towing for us.
If the 31' is a trailer you like I encourag you to grab it before someone else does.
Craig and Carol
1997 34' Excella 1000
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
02-02-2012, 02:07 PM
1975 31' Sovereign
1977 23' Safari
Palmer Lake
I don't see much difference when towing an 18' Caravel or 31' Sovereign, except for turn radius and dragging the inside wheels over a curb, but I tow with a 3/4 diesel. The number one issue is two axles, which I think is a big plus, especially when you hit a major pothole. The number two issue is "rear end droop," which you will eventually see in the longer trailers. The number three issue is camping spot length--many parks are limited to 25' or 28'.
Longer is great if you go someplace that you're familiar with and intend to plant yourself and stay awhile. Shorter is better if you move on every day or two, or wind up in unfamliar places.
If you find an inexpensive 31', you can work with it and then sell it for about the same $$, if you don't like it. Inexpensive Sovereigns are very available these days. Inexpensive Safaris and Tradewinds are not.
Zep
MindsEyePhoto AirstreamDoctor PygmyKayaker
- Corporations are not people
- If you want the public to have an opinion, start the Draft within 60 days of hostilities
- If you are betting other peoples' money, you get a regular salary
02-02-2012, 02:09 PM
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview
, New Mexico
A 31 ft AS is very easy to pull You would hardly now its there. The longer the trailer the easier it is to back up. The thing I can think about is that a 73 doesn't have a grey tank they were put into the 74 or 75 years. I own a 22 ft and a 34 ft and I enjoy pulling my longer trailer a lot more.
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2006 F250 superduty crewcab
02-02-2012, 02:25 PM
Rivets?
1992 29' Excella
North
, Georgia
Don't buy a certain trailer just because it's a good deal. Similarly, don't shy away from a trailer because it's not exactly what you had in mind.
In our original window shopping days we considered pop-ups and small trailers - probably nothing bigger than 22 ft. because of the intimidation factor. We ended up with a 29 ft. for a variety of reasons and we've found it to be a comfortable size and I would not want to go with anything much less than 27 ft.
Of course, all that is my opinion. To each his own regarding size.
In the end, don't let what you think is a large size deter you from your purchase. Look at the floor plan - kitchen, bath, beds, living room, etc. - do they suit your needs? Think about using the trailer as you plan to use it - long weekends, extended travel - will it be suitable.
There are very few campgrounds where we find our 29 ft. to be a limitation. Keep in mind many campgrounds can handle 45 ft. motorhomes. Boondocking and other remote forms of camping may necessitate a smaller trailer but 31 ft. is not really that big in this day and age.
Lucius
02-02-2012, 02:39 PM
Addicted
1971 27' Overlander
Currently In: Trenton
, ME
We have a 1971 27' that we've towed over half the country so far, and will be doing the other half once it warms up a bit. We have an '09 F150 with the medium V8 (the 3V) and we didn't have any issues at all, no issues in Colorado, Montana, Wyoming...anywhere. There's really not that much difference in that extra 4 feet (at least from a towing perspective anyway), and if you're really "lugging this thing around the country", then you're going to likely appreciate the extra space.
02-02-2012, 02:47 PM
1976 31' Sovereign
Rock Hill
, South Carolina
We have 31' and 25' rigs. The 31' is easier to tow and back up. Being "too big for the site" has not been an issue for us. We pull with an F-150 and the only time we struggle is with 8% or greater grades.
"...the most confident critics are generally those who know the least about the matter criticised."
Ulysses S. Grant
02-02-2012, 03:10 PM
1982 34' Limited
Brunswick
, Georgia
I prefer the extra room of the longer trailers. I originally looked at the 31' but ended up finding a terrific deal on a 34' triple axle. Towing has never been a problem. The third axle drags on tight turns, and you have to be aware of the amount of rear overhang beyond the rear axle (tail swing and abrupt elevation changes at driveways/ entries, etc.). I have only heard of tail sag/droop on the rear bath models.
In regards to size, I have never been in a situation where the length has been an issue. In most cases I have been dwarfed by SOB's. It looks very big in the driveway, but smaller in relation to many other Class A's/5th wheels, etc.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
02-02-2012, 03:27 PM
1956 22' Safari
Edgewater
<SNIP>
Out of the blue, I discovered a 1973 31ft Sovereign for sale...
You don't say what your intended use for your "soon-to-be-new-to you" Airstream is...are you thinking of 1/2 or full-timing or mostly shorter trips? For you alone or with others or pets? Both these would play into answering the how big is "big enough" or "too big" question in my mind.
This is true, the longer trailers are going to give you lots more elbow room & storage options which would come in handy on longer trips or with more than just a single person. However, we are just fine in our 22' for 2-3 weeks with 2 adults, 2 small dogs & our kitty. Just depends on your lifestyle...we spend most of our days outside - so the 22' is plenty for us.
Watch out here, a 1973 most likely does NOT have a grey water tank - unless this trailer was a very late model '73 (or retro-fit in by a previous owner), as they did not become standard until 1974. Adding a grey tank can be done (we did in our '56) but it is a pretty big project which could lead to a major rehab, Airstream renos can turn into a slippery slope pretty quickly! If you don't have a grey tank, your camping options may be more limited or you will need to cary along a "blue tank" for boondocking or capturing your grey water when you aren't at a full-hook-up campsite as most places do not allow wash water to be run on the ground. This may or may not be a big deal to you - but just some food for thought.
Good luck during your search for the perfect trailer for you!
Shari
02-02-2012, 04:18 PM
1974 Argosy 22
I have had a 24', 28' and now a 22'. Lot's of good posts here! My 22' I have completly redone, and I am very happy with the reuslts. I loved the 28' because it did have lots of room, a bigger fridge/freezer, and bigger shower. Towing any of them is fine. Out here in CA there are some of the older state parks that have limits. I am happy to hear that F-150's are towing the bigger guys just fine. I have a 250 that makes a big sucking sound going down the road, and have considered a 150 for a replacement. I'm more comfortalbe in that decision now! You will have a ball with whatever you end up with!
| Thread Tools |
| Display Modes |
