Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 05-24-2004, 07:17 PM   #15
FireFighter's Avatar
Profile:  Currently Looking...
bay city , Michigan
vote
does everyone think that i should just purchase a whole new setup rather than try to use anything on the trailer, the one looks bent in the first picture am i correct?
FireFighter is offline   Reply With Quote
Old 05-24-2004, 07:25 PM   #16
jimmickle's Avatar
Profile:  Marion , Iowa
Absolutely. Get a complete new Reese hitch with dual cam. You are correct about it being bent. I sure wouldn't try to straighten it, even if it were possible.
jimmickle is offline   Reply With Quote
Old 05-24-2004, 08:27 PM   #17
bay city , Michigan
where to purchase
hey does anyone have a we source that can get me into the new WD setup cheap?
there is a thread on this but real quick is the HD with the bolt on brackets the way to go or should i just use the regular dual cam?
Old 05-24-2004, 09:18 PM   #18
Barkingspider's Avatar
Profile:  Austin , Texas
I have the HP with the bolt on and I love it. Looks like it is really part of the trailer. Joe
Barkingspider is offline   Reply With Quote
Old 05-24-2004, 09:21 PM   #19
Here's a good place to purchase online: Reese Strait-Line Hitch
Cost = $400 (1200lb bars)
Old 05-24-2004, 09:22 PM   #20
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If you are passing through STL on the way to Mississippi, I have a dual cam and 1,000 lb. bars that I would be willing to let go at a nominal cost.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
Old 05-25-2004, 06:23 AM   #21
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
"new WD setup" and "cheap" are mutually exclusive terms.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 05-25-2004, 06:34 AM   #22
bay city , Michigan
Roger,
what setup are your using on your 34?
Old 05-25-2004, 08:05 AM   #23
85MH325's Avatar
Images: 37
Reese Hi-performance drawbar and ball mount
It's pretty standard... I have the Hi-perf 12,000 lb draw bar and ball mount. The mount is slanted about 15 degrees on the draw bar. The WD bars and cams that mount on the tongue are the older style that I got from the P.O. when I bought the trailer. The original setup I bought, I got for a Minuet several years ago, so I still have the later-style lightweight bars and those cams in a box somewhere. All-in-all, it's a pretty pedestrian hitch... nothing fancy at all, but it seems to work fine.
When I first got the 34' I had huge sway issues. As it turned out, the draw bar was too long; it was for a van conversion with rear-mounted spare and it flexed like crazy. Using the Hi-Perf draw bar stopped about half of the sway, but I still had issues until I figured out the tire pressures were WAY too low on the Excursion at 55psi on my "E" range tires. That allowed too much sidewall flex which allowed the Excursion to "wiggle" with trailer input at speed. It was pretty scary. At 70psi (all the way around) on the Ex and the trailer tires aired up to max, and the Hi-Perf draw bar setup, the thing tracks like it's on rails.
Good luck!
Roger
Old 05-25-2004, 01:36 PM   #24
bay city , Michigan
Lightbulb Finally have this isssue solved
Thanks one and all for the help and the lessons on WD. I found a gent to bring this baby up to me. he is a professional owns his own tow rig and WD setup that he puts on and gets to towing. I should have my new A/S 1 week from today. i am exicted and scared to see what i actually have purchased.
Pingbacks are On
motor home 454 engines (motors) wb13798 Airstream Motorhome Forums 6 01-31-2004 09:26 AM
She is home! Pahaska 2003 Classic 9 10-23-2003 11:50 AM
new member/new motor home malski Airstream Motorhome Forums 12 08-09-2003 05:02 PM
Time for that second Honda 2000 Raptorrider2001 Our Community 2 06-17-2003 05:57 PM
Finally! Bringing it home... pjtaia Our Community 12 09-30-2002 08:31 PM
SEO by vBSEO 3.1.0
