Old 05-09-2015, 03:58 PM   #43
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Using this process above, you can make your 'ramp' so that you could literally build it in pieces, to cover the whole driveway area. That way you can deploy the ramps, then the AS, then recover the ramps.
Hard wheel cart will roll easier... I just had this air filled tire cart from my yard work...
The 'edges' have worn a bit from not aligning the ramp really well and the tires rolling off the edge.. it's kinda a freaky thing to watch...
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-12-2015, 11:37 PM   #44
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
I get it. I need to spend some time measuring that distance.
Of course, there's the question of ROI. I cannot say for sure how often I would actually use them.
DoublTrouble is offline   Reply With Quote
Old 05-12-2015, 11:50 PM   #45
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We leave the stinger in the truck all the time as it is not a daily driver. I have marked the stinger up with red and white reflective tape. The Rock tamers stay bolted to the stinger.
I found some sleeves to reduce the hole diameter through the stinger so a ⅝" stainless steel bolt could be worked through and then secured the stainless steel nut with locktite.
ID:	238336   Click image for larger version
