Old 03-25-2018, 07:33 AM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Propride Hitch: Going to a 1000lb bar from 1400lb
Curious if anyone has experience doing this? I have some slight body damage as discussed in this Thread:
http://www.airforums.com/forums/f44/...ge-175039.html
Note that the damage is not uncommon and I donít want to speculate the reasons for the damage, I simply want to soften my ride.
I am considering going to the 1000lb bars.
Tow vehicle is a 2005 Ford Excursion, 3P Hitch, trailer is 2015 30í Flying Cloud bunkhouse.
Tounge weight is 1150lbs measured with Surline scale.
Thank you for you thoughts.
Ted S. is offline   Reply With Quote
Old 03-25-2018, 08:30 AM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I went in the opposite direction (1000# bars to 1400#) because I was struggling getting enough weight back to the steer axle. Since Colonial basically reinstalled the entire hitch because my original dealer didn't do it right from the start - I can't say whether the bars or the reinstall solved the problem - but it works. And no damage like the pictures you've shared.
Probably not an overly helpful answer. Good luck!
SteveSueMac is online now   Reply With Quote
Old 03-25-2018, 08:40 AM   #3
2016 28' International
Sioux Falls , SD
What does the trailer weigh loaded?
If I remember correctly, the tongue can be no more than 10-15% of the trailer. Could it be overstressed fully loaded?
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Rock Tamers hub not fitting on ProPride hitch bar NoNameinNM Hitches, Couplers & Balls 12 07-06-2017 08:19 AM
ProPride 3P Hitch Lot Bar with Link Locking Plate questions... RxGuy Hitches, Couplers & Balls 3 03-07-2017 01:03 PM
1400lb Hensley hitch CStan5793 Airstream Classifieds 0 04-29-2014 09:52 AM
Lets talk Hensley 1400lb spring bars and grease fittings mikeb9550 Hitches, Couplers & Balls 0 03-20-2011 10:18 AM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
