Originally Posted by rmkrum
Uh, removing the WD bars from a ProPride can be easily done, but it requires the use of tools (a wrench or two) to disconnect them.
I replaced my hardware with two eye bolts and a pin so I can disengage the bars quickly, I am assuming the other end of the bar will drop out from there.
However, lets be honest, how much off-roading can an Airstream take? Even if you can get it through rough terrain, I am nervous brush and branches will damage the soft aluminum.
So I think the propride can handle offroading to the point the Airstream reaches its limits.
If I was going to do more rough roads and boondock, I would not get an Airstream. I look at all the full timers and wonder why they are in Airstreams. I think I'd go with a Nash.
