08-17-2015, 01:45 PM
#21
2015 27' Flying Cloud
Bozman
, Maryland
Looks like you have used max lift on the WD bars. I have a feeling this setup will be very difficult to hitch/unhitching. I think you should use washers to tilt the stinger down 10 degrees or so when not connected. When connected, everything should be level. For my combination, about 5 3/4" of lift on the WD bars works well. Truck and trailer are level. My truck is a '15 GMC Sierra 1500 with max tow package and the trailer is an FC27 front bed.
08-17-2015, 01:48 PM
#22
Bozman
, Maryland
PS: Sawing off a piece of the stinger sounds like a bad idea to me. With the WD bars tightened, there's a lot of stress on that part. That's how some of the tongue weight is "levered" off the rear axle.
08-19-2015, 09:24 PM
#23
2015 30' FB FC Bunk
Ayer
, Massachusetts
Originally Posted by Ted S.
So anyway, here's the update.
I quoted my origional photo link for easy reference...in this photo I already have 4 washers in there and I am still not parrellel to the frame with the hitch.
Any of you go with more than 4 washers?
08-19-2015, 09:37 PM
#24
1999 34' Excella
Hillsboro
Ted,
Before you go anutha futha, I have to ask.... Is this a new Excursion ? It looks to me like the receiver is not "level to the ground"/parallel to the TV(tow vehicle). I once had a Ford that the screws on the receiver were loose. That allowed the whole receiver to move, rotationaly. Please, put a 2x2 board into the receiver and see if it is "parallel" to the ground. It it is rotated "up", it would cause that condition you have in your picture.
In fact, a member of this board had to replace his TV receiver hitch because it was so "sloppy"!!!! He had used the TV that tow something heavy and it "stretched"'the metal tubing!!!!
Peace and Blessings..
Channing
WBCCI# 30676
08-19-2015, 09:46 PM
#25
2015 30' FB FC Bunk
Ayer
, Massachusetts
Thanks for the warning cwf. I will look at it closely tomorrow, we are headed up to NH for a small trip.
This is a 2005 Excursion, the last year made. The stinger does have slop in the reciever, same as my other set ups, not sure how you would get rid of that. The reciever is just barely bigger than the hitch bar.
08-19-2015, 09:56 PM
#26
Northeastern
, Kentucky
Was there suppose to be another photo? I only see the original.
08-19-2015, 09:58 PM
#27
2015 30' FB FC Bunk
Ayer
, Massachusetts
Just the origional...nothing has changed. I will be going over the hitch reciever tommorow and will update if it is lose or has other issues.
08-19-2015, 11:25 PM
#28
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
When installing on my ML350 I tried every hole combination and shank position Up/Down to establish a level trailer, level stinger extension and level ML when the bars were fully engaged. I wound up with the stinger shank hanging down and cutting it off to provide ground clearance. I also made an additional rivet and used two to prevent any possible movement of the stinger when installed. I think I might have had one washer at the top to level it. Not sure why but I can not get a my photo to upload. I even tried one that I posted previously. Must just be too late in the night. From the picture you would have seen that everything is level when loaded.
08-20-2015, 06:58 AM
#29
1999 34' Excella
Hillsboro
To get around the site issues, upload to the free Tinypic.com sit then copy the links they provide and paste here! Like so...
Channing
WBCCI# 30676
08-20-2015, 07:35 AM
#30
2015 30' FB FC Bunk
Golden
Thank you this appears to work. Not sure why I have to go through this now.
The camera angle is not the best.
08-20-2015, 08:08 AM
#31
Portland
, Oregon
Shouldn't your chains be between the bars?
2015 Nash 24M
2014 Tundra DC Limited TRD (Sold)
2016 Ram 3500 CTD SRW CC
Blue Ox SwayPro
Still looking at Airstreams....
08-20-2015, 08:16 AM
#32
2015 30' FB FC Bunk
Golden
Yes, but I did not have them extended yet. I would also normally cross them.
08-20-2015, 06:59 PM
#33
2015 30' FB FC Bunk
Ayer
, Massachusetts
Update:
It appears there is considerable slop in my receiver/ stinger connection. I have always noticed the play and tow quite a bit. I have corrected this before by laying welds on the hitch bar and grinding them down to make a good spacer. Used to do this all the time with construction trailers.
Not sure how I am going to address it this time. I am leery of any welding on the hitch bar at this point as it is such an engineered unit.
09-08-2015, 03:32 PM
#34
2015 27' FB International
Howard
, Ohio
Update:
Ted, for slop in the receiver / stinger interface, try this. The link should take you to post 177 in this thread.
12-25-2015, 10:43 PM
#35
2015 30' FB FC Bunk
Ayer
, Massachusetts
So it appears this is the problem I have. The stinger has begun to deform my receiver. The Excursion is a very heavy vehicle, and the bunkhouse has a lot of tounge weight. The slop is growing, I fabricated a steel shim to take the slop out, and it loosened again. I am going to replace the entire receiver with the best I can fine, however I am concerned the issue will repeat itself.
12-25-2015, 10:50 PM
#36
2015 30' FB FC Bunk
Ayer
, Massachusetts
So I did something very similar to this but it was a steel shim. The problem repeated itself. The force of the weight distribution is a entirely on the shim, which is causing more deformation.
12-26-2015, 05:09 AM
#37
2007 30' Classic S/O
Somewhere
, South Carolina
Propride Dial-in
I made the same shim full length, a double and single face. I used a piece of stainless steel door kick plate. A bit tough to cut and drill but they have survived quite well. My tongue wt, a lot. 30' slider.
I feel it's helped and I'd make it again if I loose them.
12-26-2015, 06:30 AM
#38
2015 30' FB FC Bunk
Ayer
, Massachusetts
I made a full length shim, but could only get it in an inch or so because the deformation is only at the tip of the receiver. So I cut it down.
08-28-2018, 05:55 AM
#39
2009 25' FB International
2018 27' Globetrotter
Tavares
ProPride Stinger Set Up w/RAM 2500
I know this is an older thread but it applies to my question.
For those with the RAM 2500 TV how many washers do you use on the pin to set the stinger to the correct angle? And what is the correct angle?
Thanks for your input!
08-28-2018, 06:09 AM
#40
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
The picture below is with 4 washers and 6.5" on the jacks. The stinger sitting in the receiver prior to inserting in the head has a downward angle. As you add washers you will need less lift on the jacks to get the same WD.
Attachment 245565
Much better clearance...👍
Originally Posted by KYAirstream
I had a similar issue with mine and had to add 3 of the included washers to the adjustment pin so the stinger is tilted downward upon hitch up. As you mentioned, utilize the ability to tilt with those slotted holes.
Before
Attachment 245454
After
Attachment 245455
Too low? 😳
