Old 10-02-2017, 10:02 AM   #1
MWBishop's Avatar
Huntsville , Alabama
Proper Tongue Height
Newbie here.
I am trying to get our 26U tongue height correct when hitching to F250.
The AS manual states tongue height (ground to top of ball) should be 17 3/4 inches.
But currently when hitched it measures 18 3/4 inches and appears somewhat nose-low.
Therefore to get to 17 3/4 (dropping front another inch) she'd be even more nose-low.
What am I missing?
Should I shoot for equal distance AS ground/frame front/back and forget that 17 3/4?
Thanks.
2017 Airstream 26U Twin
2017 F250 Platinum
MWBishop is offline   Reply With Quote
Old 10-02-2017, 10:34 AM   #2
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Originally Posted by MWBishop View Post
Newbie here.
What am I missing?
Thanks.
Front top of A frame and rear bumper top should be within 1/2", on level surface is what I remembered from the dealer recently. But, I would call the service guys and ask to make sure. You can adjust your hitch accordingly. Hope this helps.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 10-02-2017, 11:17 AM   #3
Mollysdad's Avatar
I also have a 26U, but it's not here to measure. Why does 19 3/4" stick in my mind?
Anyway, I'd go with what looks right, not what was in the AS manual (strange as that sounds) You don't know when the manual was written or for how many units.
Do you have the stock tires and rims?
"When hitched". Do you have enough pressure on the WD bars? The only real way to test is to take it to a Cat scale and have each axle weighed.
On my rig, I have to raise the jack a lot, and then pry the bars on the last inch. (Equalizer/ 4 washers).
If the trailer is unhitched, what's the ball height when the trailer is level? What hitch? Did you measure the truck without the trailer and measure the ground clearance in the wheel wells? Then the same loaded?
Does the truck look level but the trailer is nose down when hitched?
Setting up the hitch is a complicated process. Thankfully, You'll only do it once.
Old 10-02-2017, 11:41 AM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
There is a lot of "cut and paste" in the AS manuals. That leads to strange numbers popping up here and there. Go with what looks right on your trailer. Measure front and rear to double check.
Old 10-02-2017, 11:45 AM   #5
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Agreed. Don’t go by ball height, go by the frame height as measured at the front A-frame vs the rear bumper. Measuring on a level concrete pad somewhere is the only way to go (vs the street)
I believe mine is 15 3/4” or so from ground to bottom of the frame rail on a level concrete pad.
I have a 30’ trailer and with WD applied I am within 1/2 inch of level. I couldn’t tell you what my ball height is
wulfraat is offline   Reply With Quote
Old 10-02-2017, 11:47 AM   #6
MWBishop's Avatar
Based on my current calculations 19 3/4 would probably be more accurate.
Agree manual could be just a generic figure they've used for millions of years.
Yes. Stock GY Endurance tires and AS rims.
On my rig, I have to raise the jack a lot, and then pry the bars on the last inch. (Equalizer).
No WD (in the category of "ball-dropper").
F250 rear squats 1 3/8" with front 3/8" rise (240 lbs or 5%).
WD maybe for anti-sway, but is 3/8" front rise enough to try to redistribute?
So for now just ball drop on go.
Embarrassed to say I do not know. Guess I have a homework assignment.
So time to level, measure, and adjust.
When first purchased it "appeared" level at dealership, but I really don't think it was.
It tows ok, but want to ensure it truly is level when hitched for best towing.
Thanks for the response.
2017 F250 Platinum
Old 10-02-2017, 01:29 PM   #7
wulfraat's Avatar
For what it is worth I have a 3/4 ton truck (diesel) as well and I do use WD to restore about 3/8” / 200lbs to the front axle.... I’ve got a nice balanced ride (front vs rear axle weights) when loaded and hitched up for camping.
Old 10-02-2017, 01:58 PM   #8
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
I'd say put a level on the Airstream door sill and adjust your hitch until it is level with your weight distribution hitch engaged on a level surface. My truck's unhitched ball height starts at 22" to have a nearly level Airstream with the weight distribution hitch engaged. 22" is a lot higher than the recommended 17-3/4". By nearly level I mean as close to level as can be achieved with the 1-1/4" spacing on my hitch adjustments.
2017 Flying Cloud 25FB (Miles) 93 nights 13,812 miles
2016 Nissan Titan XD Diesel 4x4 Tow Vehicle (Max)
2013 Casita SD17 89 nights 16,200 miles < 2 years
AirMiles is offline   Reply With Quote
Old 10-02-2017, 01:58 PM   #9
MWBishop's Avatar
Interesting. Which WDH did you go with?
2017 F250 Platinum
Old 10-02-2017, 03:05 PM   #10
wulfraat's Avatar
PM sent so as not to hijack the thread
Old 10-02-2017, 03:48 PM   #11
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
If you use the technique of measuring the height of the frame front and rear, the surface does not have to be level, just flat.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-03-2017, 04:13 AM   #12
2012 19' International
Southeastern MI , Michigan
Newbie here.
What am I missing?
Thanks.
What hitch are you using? Does it have WD bars and sway control? This would help.
I have a 27' and F350 with a Hensley, it has wind up WD bars but not much WD is needed. The 17-3/4" sound low, mine was about 19".
I think you will like the combo. My F350 tows that 27' like it's not there.
Countryboy59 is offline   Reply With Quote
Old 10-03-2017, 11:22 AM   #13
AirMiles's Avatar
Al
Good point! I measured this way too as level surfaces are hard to find. I measured at the stabilizer mounting bolts, front and back rather than at the tongue and rear bumper. This measured at approximately 17-1/2" which is similar to Airstream's recommendation.
What I found when preparing to pick up my new Airstream was that ball height was much higher than the specs. I bought the 11" drop receiver to achieve 17-3/4" ball height and should have bought the 7" because I needed my ball at 22". I ended up cutting down my 11" receiver to the 7" length for added ground clearance.
Old 10-03-2017, 11:33 AM   #14
Denver , Colorado
It is normal and advisable for the trailer to be "nose low". First as you start speeding up to cruising speed your trailer will start leveling up (basic physics) the force start moving from downward to rearward..., second you will be more aerodynamic if your trailer is slightly tilted forward , and your car (the rear wheel) will be more grounded resulting in better control.
lifeisfab is offline   Reply With Quote
Proper height of Dual Function CO Monoxide and LP Gas Alarms bass-o-matic Electronics & Connectivity 2 01-30-2017 02:37 PM
Hitch Height vs. Ball Height adamwright Towing, Tow Vehicles & Hitches 5 02-12-2015 04:24 PM
another tongue weight/height question boondockdad Hitches, Couplers & Balls 6 11-20-2007 12:37 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 02:02 PM
Proper ride height? guy99 Classic Motorhomes 19 05-19-2006 11:07 PM
