Old 07-25-2015, 08:10 AM   #29
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Doug - as an FYI - Sean also recommended the 1400# bars for my setup which is a 3/4 ton diesel. I went with the 1000# bars and am having the 1400s installed at Colonial later this year.
Old 07-25-2015, 06:30 PM   #30
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Originally Posted by jwp View Post
How did you do that and/or verify it? Does the Cayenne have PDCC?
I should weigh with my LR3 empty/stripped down of all outing gear to see what it's axle weights are because loaded for a trip it's at 8000 lbs which is already over GVWR before hooking up a trailer.
I have much higher rated tires than you do though, for whatever that's worth
jwp, I replaced the lead acid batteries with AGM's and moved them to the rear of the AS with the inverter, deleted the AS spare, upgraded the AS tires to Michelin LT's and store a full size spare for my Cayenne under the dinette when towing. I have a thread on here describing what I did. Weights were checked with a Sherline and verified on the scales. The tongue was down from 900 lbs to 650 with an Eaz-Lift. It's now around 750 with the ProPride. Caution - my tongue weight was below 10%, not recommended unless you have a Hensley or ProPride to ensure you do not have sway issues.
If you are really over your GVWR without your AS hitched I would suggest an alternate TV........or putting your LR3 on a serious diet...! Going a bit over GVWR is probably OK (although I would not recommend it), but 700 or 800lbs is probably a very bad idea. Be safe.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 07-25-2015, 07:00 PM   #31
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I spoke with Sean when I got the PP and with my 1000# tongue weight he told me to get the 1400# bars, that, you never want to be at the max of the bars.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-25-2015, 07:48 PM   #32
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Rod,
1400 on a 1/2 ton p/u, what am I missing?
How much of that 1000lb TW are you moving?...I move 820 from an un-hitched TW of 1200lbs Hope I'm ok....
Why 1400 for the PP?
Maybe it's 'cuz it's so much stronger than the HaHa.
Old 07-25-2015, 07:50 PM   #33
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Like Gary Haynes....I am towing a '15 Classic with a '2500 -- though mine's a '14 Ram w/Cummins. I've towed my new trailer about 10,000 miles now, and while we do obviously have different set-ups, I cannot even begin to imagine 9" on the jacks. I'm good anywhere between 5-6" depending on how fully I'm loaded (which tends to be pretty heavy). I do know that if I have more torsion moved forward it has a drastic impact on the ride in the truck. Hope you can get this dialed in correctly so you can enjoy the PP.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-25-2015, 08:19 PM   #34
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I wonder how many washers the OP installed in the hitch head? No washers would require a lot more travel on the bars. See Step 5 on page 6 of the installation instructions.
I put all the washers that came plus one and that works for me. Changing the four Lifeline 6CT GSM batteries and stainless steel enclosure (around 450 pounds) mounted immediately behind the propane tanks for a lithium iron phosphate battery (about 175 pounds) mounted inside under the sofa changed my measurement from 6" to 5.0 to 5.5" depending on what is in the truck bed.
Old 07-26-2015, 04:36 AM   #35
2010 30' Flying Cloud
Livingston , Texas
Just to close the loop I have to report that after trying for several frustrating days and talking with Sean a couple more times I just could not get the hang of hitching and adjusting the Propride. So I have taken it off and reinstalled my Equalizer. Thanks again for all your help.
BTW in response to one question I had started with two washers installed and also tried it with all four.
bw2315 is offline   Reply With Quote
Old 07-26-2015, 05:53 AM   #36
W , New England
Sorry you had such frustrations with it.
Safe and happy travels to you.
Old 07-26-2015, 07:41 AM   #37
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
All this happened the last two days?
Doug and Cheryl
Old 07-26-2015, 08:37 AM   #38
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
I guess now that it has been taken off this may be too late to ask for, but do you have some pictures of your setup that you can share? There has to be something that is off that in these discussions is not coming out. The adjustable shank may be too high/low or something. As many folks that have posted about the ProPride in the Unofficial ProPride thread and the many others on this forum there should be an answer to the issue. So many pull with an F150 and experience far superior ride and sway control over some of the other hitches, there should be an answer and without seeing the actual setup, hard to resolve.
Wish you the best in safe travels with whichever hitch setup you go with. Sorry we couldn't have been of more help.
Chuck
silverlabs is offline   Reply With Quote
Old 07-26-2015, 10:03 AM   #39
2016 30' Classic
Erie , Colorado
My post#2 asked for photos. For others that ever need help photos/videos can really speed up the trouble shooting process. As Chuck hit it on the head. Lots of folks can help but the group needs lots of information and as is said a picture is a 1000 words.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Pro-pride (Hensley) Hitch for sale Schilling Airstream Classifieds 0 06-06-2014 08:56 AM
Pro Pride or Hensley with F350 4X4 Crew Cab vetdr Hitches, Couplers & Balls 20 04-01-2012 10:24 PM
Pro Pride Arrived Today! AirHeadRik Hitches, Couplers & Balls 3 12-03-2010 07:18 AM
First Pro Pride tow Aviator Hitches, Couplers & Balls 3 06-06-2010 10:34 PM
Pro pride hitch/weight distribution question dkottum Hitches, Couplers & Balls 19 03-03-2010 09:42 PM
