Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 07-28-2017, 07:23 PM   #1
2017 27' Flying Cloud
Ocala , Florida
Power Caster PC3
For those of you using one (Power Caster PC3) -- how do you fasten it to your trailer?[LIST]
  • Did you drill the frame and attach an adapter
  • did you have the adapter welded to your frame?
  • Do you attach the PC3 to your Jack
  • do you use some sort of ball attachment
lastly do you like your Power caster PC3
My trailer is a 2017 Flying cloud 27FB - and is about 7,000 lbs loaded
Mikenbern is offline   Reply With Quote
Old 07-29-2017, 01:22 PM   #2
Ocala , Florida
crickets????
this is a quiet thread maybe a lil music will help
Old 07-29-2017, 01:45 PM   #3
2010 25' FB Flying Cloud
Powell , Ohio
Power Caster User
I use a power caster with a propride hich and not the ball. I had to make my own adapter to immobilize the hitch. After that it works great. Have used it on a number or trailers. The box trailers I just used the jack without a foot.
Hope this helps.
tbaugh is offline   Reply With Quote
Old 07-29-2017, 03:53 PM   #4
2018 27' International
Southeastern MI , Michigan
lol that's funny!
Countryboy59 is offline   Reply With Quote
Old 07-29-2017, 05:11 PM   #5
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Power Caster or other Dolly
Was aiming for similar dolly setup for our 25ft dual axel 5300/6300 Intl CCD. Chance found PRE owned 4 in-line tire electric "Power Mover" brand courtesy local Craigslist.
Available through dolly dealers but Fashioned a custom stout welded down tube bracket per our local hitch shop to attach just behind LP cover. Allows for proper clearance of dolly motor L+R swinging under battery box. Mount using long u bolts to avoid welding or piercing the frame. Also gives easy adjustment (never had to) or removal.
Wonderful combination. On Flat paved driveway performs effortless 2 point 180 with no backlash, springback tension as warned by some. Be sure to get proper rated dolly version for your tongue and GVW for proper control and stability. Good luck with your brand choice as there are a few out there.
ID:	290797   Click image for larger version
ID:	290799   Click image for larger version
Vantair is offline   Reply With Quote
Old 07-30-2017, 09:11 AM   #6
2007 22' International CCD
Good information. Like the socket idea!
Old 07-30-2017, 10:09 AM   #7
Vantair's Avatar
Forgot to add, single wheel row dolly manufacturers recommend @ 2ft setback from ball hitch to mount the down tube bracket.
They say Increased traction, stability and keeps mount out of the way.
Originally thought the ball would be the way but then you'd create a 750lb + unicycle. 🚑 !
jack caster wheel on '54 wanderer lunartic Jacks, Stabilizers, Lifting and Leveling 3 08-06-2018 12:41 PM
Power Caster Question Mikenbern Hitches, Couplers & Balls 0 07-27-2017 12:04 PM
Power Caster PC-3 Mikee6453 Airstream Classifieds 0 02-13-2017 01:32 PM
