Old 04-15-2018, 07:26 AM   #21
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
It may not be the hitch.
We have experienced the harmonic porpoising on particular roads with concrete surfaces where the centers of every slab are a wee bit lower than the framed edges. If this is what is causing the problem, then slowing down is all that really helps (we had to go to 45 MPH on Nebraska Hiway 2 between Nebraska City and Lincoln to get it to not feel like we were on a carnival ride).
Other strong possibility is that most SOBs have HUGE "basement" storage areas, often right by the tongue.
If that is where most of the heavy gear is stored, then re-arranging that, along with heavy items in the truck bed, may help to smooth out the load and the ride.
Also agree to the speed remark about towing at 60-63, and addressing tire pressure.
If they have time, it would be interesting to experiment with where they keep the heavy stuff and how that affects how the rig rides.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 04-15-2018, 08:34 AM   #22
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
A word on Air Safe. Air Safe is not a hitch per se. You bolt a weight distributing hitch shank to the Air Safe which is basically a pneumatic air bag in a box. With my Air Safe class IV I have a Husky hitch. It won't work with all WD hitches like a Hensley Arrow which is set up totally different. I don't know about Pro Pride but suspect it will not.
Old 04-15-2018, 08:40 AM   #23
Journeyman
2016 25' International
Deerfield , Massachusetts
Since others have comment on the hitch, I'll talk about the truck.
I have heard a few towing reviews of the F150 that indicate that it porpoises more than trucks of another brand. The ford is tuned for a rather plush ride right out of the box.
I have LT tires on mine and so far that seems to have helped quite a bit, so I'd recommend those.
Others have highlighted the relatively cheap upgrade of moving to Bilstein shocks.
Lastly, addiing air bags has been cited as a way to dramatically improve the porpoising issue.
I hope that helps.
(I own a late model F150, so this is not a ding against the brand!)
thiel is offline   Reply With Quote
Old 04-15-2018, 11:27 AM   #24
2017 19' International
Tallahassee , Florida
This is all great info and, heck, I've learned a few things myself.
Thanks for all the contributions.
I'll be talking to my friend soon and can get more specific info.
I think he said he was on link No. 9 on his Blue Ox bars.
I believe this is his first trailer (he rented an RV for a trip a year or so ago, and that gave him the bug). So he may not know about loading the heavy loads over the axle, not in the front or in the rear.
I doubt he was trying to push it 70 mph or more, but I'll ask.
WhereStream is offline   Reply With Quote
Old 04-15-2018, 11:48 AM   #25
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The 9th link is what Blue Ox recommends as the starting point. In my case, my tongue weight is nearly at the bar rating, and I felt like I wasn't getting enough transfer in my first tow (before I'd had a chance to weigh the rig) and their customer support recommended I try the 10th link before I went to heavier-rated bars. It felt much better, and when I got a chance to weigh the rig the numbers come out right as well.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 04-15-2018, 11:59 AM   #26
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Porpoising is usually caused by these types of things:
(1) improper weight distribution hitch adjustment - try this first
(2) terrible stretch of road - does it always happen over the same stretch of road somewhere near your home? Maybe avoid it from now on.
(3) tongue weight is simply too great for the tow vehicle despite weight distribution - obviously, the most expensive potential problem.
Rocinante is our 2014 International Signature 27FB
Old 06-12-2018, 07:17 AM   #27
1999 28' Excella
Lake Mary , Florida
Porpoising
I assume the TV is a truck, many of which come with rear shocks designed to make the truck ride smooth like a car, but you are using it as a truck.
Best to remove the old cheap shock and replace it with a helper shock, a/k/a coil over shock. Buy a good stiff shock with an exterior spring. I always put Gabriels on my TV
suncoasteng is offline   Reply With Quote
Old 06-12-2018, 08:55 PM   #28
2007 22' International CCD
Porpoising
Need to verify that the weight on front axle is correct. Measuring height of wheel well is back to same height after cranking in WD is one way. Several passes over a CAT scale is better.
On my rig, porpoising is a clear indication of needing some more tension on the WD bars. On my ProPride Iíve found as little as 1/4 to 1/2 inch higher on the jacks makes a huge difference in handling, from making DW seasick to letting her take a nap in total comfort while I drive...and yes, it varies by load, road surface, and general environmental conditions. Seems to be touchy when itís hot out also.
First time towing - Porpoising help 3campers Towing, Tow Vehicles & Hitches 19 06-05-2012 08:35 AM
Concrete roads and porpoising GeocamperAS Towing, Tow Vehicles & Hitches 37 04-09-2012 07:22 PM
Porpoising Jammer Hitches, Couplers & Balls 19 08-10-2011 12:24 PM
