Old 03-12-2012, 08:38 PM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Please interpret these pictures items
We were goofing off outside this evening before the sun set. And I walked over to the 'said' tow truck. The hitch is a draw tight, but what does the other pictures mean? That last picture is my Reese hitch - looking down on it. And theres another number.
ID:	153228   Click image for larger version
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 03-12-2012, 08:46 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
It means you have a hitch good for 1000 pounds tongue weight and 10000 pounds trailer weight if using wd equipment. It also means you need a heavier duty trailer ball, since the loaded weight of your overlander will exceed the 6000 pound rating for it.
Old 03-12-2012, 08:56 PM   #3
1970 27' Overlander
Please elaborate on the heavier duty trailer ball...do I go to the department that says heavier duty? Or what would be a more specific title for that?
Old 03-12-2012, 10:35 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you have a farm supply store near you they will carry heavier ball mounts and balls that will work for your trailer. If not hitch manufacturers like Curtis will have them.
I just purchased a ball mount rated at 16,000# and a 2 5/16" ball at the local farm supply.
Old 03-13-2012, 04:54 AM   #5
1970 27' Overlander
Ok I will go check this out,. We have an Atwoods Hardware...they have trailer supplies. Thanks for this information.
Old 03-13-2012, 05:30 AM   #6
Well Preserved
1993 21' Sovereign
Generally, the smaller shank (threaded part) on the bottom of the ball equals less weight capacity. If you remove yours from the ball mount, you will probably find a spacer between the shank and the ball mount. Get a ball with a larger shank, usually 1 1/4", and install it on the ball mount.
Old 03-13-2012, 06:05 AM   #7
dznf0g's Avatar
Oswego , Illinois
But measure the hole in the shank before you go. I think we are assuming the hitch head/shank is a 10,000lb head. It probably is, but save yourself from potentially two trips to the store. Remove the old ball and measure the hole in the head.
-Rich-
Old 03-13-2012, 06:14 AM   #8
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
There is some variety of 2 5/16 hitch balls out there. A farm and ranch store may have a selection, but you may better find what you want at a store that specializes in RV parts. This one is rated at 10,000 #
Here's a random link to one that is rated at 12,000#
http://www.etrailer.com/Balls/Tow-Ready/19286.html
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
A little info please before buying a Classic... Corrales Kid Classic Motorhomes 6 03-18-2012 06:55 PM
New member here! Please be gentle... MrsHaase 1965 Safari 17 03-13-2012 09:21 AM
Please interpret these pictures items AIR-Quarius Towing, Tow Vehicles & Hitches 7 03-13-2012 06:14 AM
