05-22-2016, 03:47 PM
#21
2013 27' FB International
El Dorado Hills
A weight distribution hitch stiffens the connection between trailer and tow vehicle. The net effect is to slightly lift the rear wheels by shifting that weight roughly equally between the front tires and trailer. You might realize a transfer of 100 or so pounds (give or take 100 lbs) to the trailer.
05-22-2016, 04:39 PM
#22
2014 30' FB FC Bunk
Hoover
, Alabama
I doubt the payload numbers will work out here....do your own math and come to your own conclusion....
I am trying to figure out at what point there is consensus on questions like this?
05-22-2016, 05:41 PM
#23
1991 25' Excella
Stanfield
, Oregon
I have a 2015 ram 1500 equipped very similar to yours except mine has the ecodiesel with 3:55 gears and it pulls my 25ft execcela with ease. The only thing you well need is better tires the stock p rated goodyears are junk and well squirm a lot. The air ride handles the weight very well and a decent wd well help you lower your tounge weight. Personally I dont use them but it not a bad idea.
05-22-2016, 06:17 PM
#24
N/A
, N/A
Originally Posted by dkottum
Rich, careful about internet advice...
Well, in an online forum, all you will get is internet advice. Some are factual, some are not.
Its a fact that door sticker payload number is less than the published payload number for a bare bones truck. Its also a fact that overloading your Ram truck with air suspension will be recorded by the truck computer.
05-22-2016, 06:30 PM
#25
Southwestern
, Ohio
On Airforums? That's easy. NEVER!!!
05-22-2016, 06:47 PM
#26
2013 31' Classic
billings
, Montana
Hook up the trailer and try it, it may be fine....
05-22-2016, 06:50 PM
#27
1991 25' Excella
Stanfield
, Oregon
On a side note my ecodiesel is heavier than the hemi and not just the engine but it also has an 8 gallon def tank and a lot heavier exhaust system too. But even with that unhooked with a full tank of diesel and 300 lbs of passengers it still tanks about 800 lbs to get to sticker capacity on my truck. But it takes another 600 lbs on top of that to go into protection mode on the air ride.
05-22-2016, 09:11 PM
#28
2015 30' FB FC Bunk
Ayer
, Massachusetts
Side note:
Call me old school but 1040 lbs payload capacity for a full size pickup with a 6'4" bed doesn't sound like ... "Ram Tough" ...
05-22-2016, 09:43 PM
#29
2012 25' Flying Cloud
Battle Lake
These late model trucks are a LOT more capable than some who are not using them claim.
It's become normal here to tell you what you can't do, but very few who will explain how you can. There is one fellow here who weighs in on every towing thread with zero relevant towing experience.
The only towing expert on this forum is Can-Am Airstream in Ontario. Contact them and they will detail how to set up your truck and trailer, or set it up expertly for you. You will learn from them how and why your truck is an excellent tow vehicle for this size Airstream. Something that we who have them set up well already know.
http://www.canamrv.ca/towing-expertise/
Doug and Cheryl
05-23-2016, 06:23 AM
#30
N/A
, N/A
Its almost guaranteed that you would overload a Ram with 1040# of payload and a 28'.
IMO, when making a recommendation to someone, you would want to be specially conservative to make sure you do not put them in any (potential) trouble. Many folks in this forum seems to disagree with me on this.
There are well intending folks on this forum that after seeing an online video (or reading an online article) are absolutely convinced its ok to ignore manufacturer tow ratings.
05-23-2016, 07:51 AM
#31
2002 30' Classic S/O
Garden Valley
, Idaho
I beg to differ. Anyone that suggests a passenger car is a better tow vehicle than a truck designed to tow, has lost credibility in my opinion.
05-23-2016, 08:03 AM
#32
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
A 28 footer might be pushing it for that vehicle. As others stated, it's on the low side, especially with that gearing. I towed our 27fter with a 1500 Ram 4x4 Laramie with 3.92 gears for a year. But, I had to ride around with a mostly empty bed to stay all within the ratings of the vehicle. That gets old fast. (Tongue weight on mine was 960lbs.)
Some odd observations about Ram. The axle and tire ratings are much higher than the GVWR. The 1500 had a FAWR & RAWR of 3900lbs. That's 7800lbs while the door sticker stated the vehicle had a GVWR of 6800lbs.
This is the difference with the Ram and the Ford. Ram offers one axle combo across the board, and it's heavy duty.
What I can tell you is, that you won't find a 1000lb difference between GVWR and axle ratings on the F150. It will be significantly less. And the combinations are a little mind boggling: https://www.fleet.ford.com/truckbbas...tes_010815.pdf
Based on those axle weight ratings, Ford seems to be all over the place. And the GVWR's are too. But I did some math on a few of them, and the trend is the same, one vehicle with A SuperCrew 4x2 only has 375lbs of spare capacity on it's axle.
So, I disagree with Rostam. You are more likely to overload your Ford than you are your Ram. I've posted this multiple times across this forum, in more detail in other places. Ford has the highest numbers because they are already maxed out.
Another thought.
Ram has a habit of de-rating things. I don't know why. The general consensus on a few other forums is "lawyers". My Power Wagon for example has a lower GVWR than an identical 2500 4x4 without the PW package. It's the same truck. It's believed, it was derated for liability because of the 2 inch factory lift. The Warn winch in all materials is labeled as a 12,000lb winch, but if you remove the cover, you'll find a Warn M15000 which is a 15,000 lb winch. It's labeled right on the thing. So why does Ram in all material state it's a 12,000lb winch? ¯\_(ツ)_/¯ I don't work for FCA so I can only speculate.
All of that said, there is a difference between towing with a 1/2 ton and a 3/4 ton. I've done both now. I'd recommend the 3/4 ton as a better towing experience for anything over 25ft.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
05-23-2016, 08:33 AM
#33
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Changing the gears after the unit is built or adding springs or whatever, does not change the door label data unless a modification shop issues an amended certification label for the loads in the truck.
That could be important to you if taking the rig to Canada where the door label IS the controlling document as posted elsewhere on this forum.
When we converted the 2012 Ram 2500HD Cummins to the Kelderman level ride air suspension system, al the steel springs were replaced with air bags. On the rear they put 10,000 pound rated air bags. However, the rear axle is still rated 6,010 pounds and the factory installed Michelin LT265/70R17E tires are rated for that load at 70 psi. (Running the tires at 80 psi gives a load rating of 3,195 pounds versus the 3,005 pounds at 70 psi)
Kelderman did NOT issue an amended door label as they did not change the axle.
Our factory receiver was rated 1,200 pounds, but due to mentioned weld failures of the support member, we removed that receiver and installed a Curt 15049 rated for 2,550 pounds of tongue weight and a 17,000 pound trailer, which more than covers the Airstream product line. However, the truck is limited to a combined towing weight of 20,000 pounds, so we see 19,200 pounds cruising down the road loaded for camping.
The factory door sticker numbers will be different depending on the gear ratios in the differentials. But the "as built" rules the day for most folks.
05-23-2016, 08:50 AM
#34
2014 28' International
Blacksburg
, Virginia
Serenity
well you got a lot of good information riffin-rich. What Bold adventure says, that is experience talking to you.
Also what Tomhenritz is telling you about gearing and how he changed his to 3.73 instead of trading vehicles, that's good info too. Also I saw someone recommended LT tires for your truck because passenger tires ( P rated) are softer in the sidewall (Generally speaking). There are exceptions, granted a 40 series P rated tire is pretty stiff. LT tires are stronger. That's good info you can use.
So you do have good information here , just have to dig a little
Yeah the Serenity model is really nice, kinda partial to it . The 28' is IMO kinda heavy, but I am comparing to a some other brand, as I haven't pulled any other model AS. But I must say my 28' is the best towing trailer I have ever pulled. Its like one with the truck.
It doesn't swing and sway or buck & fight the truck.
Tractor trailers passing do not affect it. Winds do not bother it. I have had winds catch my previous trailer like a sail on high bridges, and it is not a good feeling !
The AS is just rock solid, I can tell you that.
Once you decide on a tow vehicle, and get a good hitch, a 28' Serenity is a mighty fine trailer to tow
I hope this helped some
have a good one !
Ra & Chelle
For my next trick, I will use my new AS & Dodge Ram CTD to make this pile of money disappear.
05-23-2016, 09:06 AM
#35
Nomadic
, USA
This is why I make the statement that the axle ratings and tire ratings are what you need to pay attention to, and to hit the scales. According to the Canadian members on the Ramforum in the towing section, their version of DOT looks at axle and tire ratings, not payload. And will subject you to a scale if they think you are over.
If you are over, they will then make you unload.
In the US you generally don't have to worry much about DOT. But there was a member who just posted, about being stopped in Nebraska by DOT and written a ticket for straps on his boat not being proper.
I'm sure all of us are breaking a rule we've never heard of every day.
That's life.
05-23-2016, 03:23 PM
#36
2015 27' Flying Cloud
Bozman
, Maryland
For the last 6 months my wife and I have been fulltiming with our FC27 . . . And have covered over 25k miles, mostly in the west after a cross-country trip from Washington DC to Los Angeles. The two vehicle is a GMC Sierra 1500 crew cab with the "max trailer tow package" and the 420 hp 6.2 liter gas engine with the 8-speed tranny. Cargo capacity per the door sticker is 1940 lbs. There's about 500 lbs of "meat" aboard, a Honda generator (50 lbs), a 3-gallon gas can, a toolbox that weighs about 50 lbs, snow chains for the truck and trailer (California requirement), spare clothes, a tabletop grill and a portable satellite dish. While I haven't weighed the combination, I would say I'm maxed out. . . And that's using a ProPride weight distribution hitch. I say that, based on the appearance of the back tired when inflated to the recommended air pressure. The problem with the "front bed" Airstreams is that 3/4 or more of the storage space is forward of the axles. Because we didn't really want to go to a 3/4 we shopped for a year for a truck. Other than the GM truck (equipped the the max tow, which adds 400 lb payload), the only other crew cab truck we found that we would have been comfortable with was the pre-aluminum F150 with the max payload and max tow packages. They will have a door sticker payload of about 1700 lbs. Online, it appears you could configure a new F150 to carry that much or more. However, it appears the max payload package precludes you from having anything other than the standard 20 gallon fuel tank. The 26 gallons our GMC carries is the minimum I would have, based on our experience. I've been completely satisfied with our combination. Because of the limitations of the Marathon tires, we tow at 60 or the speed limit, whichever is lower.
I recall that some testers --maybe pickup trucks.com--commented that overloading the Ram (in a comparison with other 1/2 tons carrying the same weight but with higher rated cargo capacity) produced some pretty squirrelly handling. The problem with overloading isn't breaking something, it's weight transfer off the front tires producing overly sensitive steering or, in worst case, loss of control in low traction situations like rain.
05-23-2016, 04:46 PM
#37
1991 25' Excella
Stanfield
, Oregon
The air ride Elimates the weight transfer issues by making the truck sit level, loaded or empty. The reason our rams get squirly is the junk tires our trucks come with I switched to E load range Bfg K02's and its a huge improvement.
05-23-2016, 05:49 PM
#38
Battle Lake
Here's some real world experience.
Our last Ram 1500 5.7 Hemi 4X4 and FC 25 and ProPride hitch fully loaded for seven months travel. Wonderful tow vehicle, absolutely rock solid stability and handling. Traveled through every state west of the Mississippi many times and most of the east to the coast.
Loved it, so when looking for a new truck we bought a 2016 Ram 1500. Same Airstream and ProPride hitch, same great towing performance, 3500 miles towing cross-country so far.
These are terrific trucks for mid-size Airstreams, with 800-1000 lbs remaining axle capacity (loaded evenly with weight distribution as in the photos), I wouldn't hesitate a moment to tow the 300 lbs additional weight of a 28 with either truck. By the way the Ram 20" tires have plenty of load capacity and the low profile design at full pressure are not squiggly.
Doug and Cheryl
05-23-2016, 07:48 PM
#39
Nomadic
, USA
You should be using a Anti-sway/WD hitch anyways. In their tests, they reported that about all vehicles and were not using a hitch. So, nonrelevant.
05-23-2016, 09:04 PM
#40
Blacksburg
, Virginia
Hey Doug, (Dkottum) Is your white Ram a 4x2 with the 3.92 axle ? It looks good.
I would really like to find a gently used a non-4wd Dodge dually.
( I mean 'Ram' dually) .
That lower center of gravity and no transfer case weight and no drag of 4wd system, and of course Cummins powered. I think that would be a towing beast . I had read 2wd trucks are very good for towing. If I find one at the right price
have a good one !
Ra & Chelle
