Old 05-24-2016, 08:24 AM   #43
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Take a moment to consider the size difference between a 25 and 28 Airstream.
The 28 is actually only 24" longer, but with exact frontal dimensions, they have the same frontal air resistance. You will not notice the difference towing either.
The 28 has 300 lbs more axle load capacity. Fully loaded Ram 1500 and 25 will be about 13,000 lbs. Fully loaded Ram 1500 and 28 will be about 13,300 lbs. You will not notice the difference towing either.
The 28 has 65 lbs greater hitch weight, with weight distribution that's maybe 20 lbs to each truck axle and 15 lbs to the trailer axles. You will not notice the difference towing either.
The 25, 26, 27 and 28 are all mid-size Airstreams. Pick the size you like, you will not notice the difference towing either. (By the way, the 27 is 1" longer than the 28, and has he same axles).
Doug and Cheryl
Old 05-24-2016, 08:38 AM   #44
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I am wondering about how much experience is in the above posts....
Old 05-24-2016, 08:41 AM   #45
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
As to renting a tow vehicle, Enterprise truck rental does. We rented a 2016 Ram 2500 diesel for towing while our truck was in the shop for a few days while visiting Phoenix last winter. They do charge $20/day extra for towing.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 05-24-2016, 09:32 AM   #46
dkottum's Avatar
Good point, most have extensive experience and those are the one's we try to learn from. Some have none, just search the internet until they find something they like.
We have owned smaller and mid-size Airstreams, towed both all over the country and have spent some 48 months traveling and living in them. We have towed them with three different half-ton trucks, three different w.d. hitches.
We have experimented and learned some things about them and share our experience with those who ask. We love to read the experience of others and the chance to continue learning. I especially like to read about those whose Airstream experience goes back 30, 40, 50 years; that experience goes beyond the latest truck test and puts it into perspective.
Doug and Cheryl
Old 05-24-2016, 12:28 PM   #47
jcl
Vancouver , British Columbia
Originally Posted by SpletKay06 View Post
The air ride Elimates the weight transfer issues by making the truck sit level, loaded or empty. The reason our rams get squirly is the junk tires our trucks come with I switched to E load range Bfg K02's and its a huge improvement.
Air ride doesn't eliminate the weight transfer issues. The axle weights will be the same.
What it can do is eliminate the appearance issues, the rear end sag, and thereby mask the weight transfer issues.
It isn't the sag that causes the handling problems, in most cases. It is the reduction in front axle loading.
jcl is offline   Reply With Quote
Old 05-24-2016, 12:51 PM   #48
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
A lot of years.
That's why everyone on this forum advocates a WD/Anti-sway hitch that is setup properly and hitting the scales.
If you don't do this, it's your own fault that you have handling problems.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 05-24-2016, 10:03 PM   #49
1991 25' Excella
Stanfield , Oregon
I have confirmed that with air bags my front axle weights the same loaded and unloaded thats a fact. All a good wd hitch well help is with sway and lowering tongue weight which is what there for.
SpletKay06 is offline   Reply With Quote
Old 05-24-2016, 10:29 PM   #50
dkottum's Avatar
A well set up w.d hitch will distribute some hitch weight and some weight in the rear of the truck bed to the truck's steering axle, with a portion to the trailer's axle(s). If the bars are tilted down toward the rear, the bars will resist the trailer moving out of alignment with the truck and help it return to center when it does. The downward tilt will also resist the tendency of the truck to roll slightly in higher speed turns, improving tow vehicle stability.
Adding sway control or sway elimination devices to the w.d. hitch design makes them at least as important as truck and trailer design for towing. Keeping in mind good hitch setup is what makes them work well.
Doug and Cheryl
Old 05-25-2016, 03:30 PM   #51
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
In the changing to an airbag suspension, the axles did not change. So even though I have rear airbags rated for 10,000 pounds, the axle rating of 6,010 pounds controls the load. The E rated Michelins are rated for that load at 70 (of 80 max) psi. There is a similar constraint on the front axle despite the air bags.
The air bags keep my truck level all the time and the complete air bag system with an air compressor added 100 pounds to the empty weight of the truck after removing all the steel springs and their associated parts. They also allow for a softer ride for the front of the trailer.
There was NO increase in load capacity (really a 100 pound decrease) by this suspension modification.
Old 05-27-2016, 03:17 PM   #52
Rich and Kat
AIRHEDS's Avatar
Virginia near , Washington, D.C.
I'm the OP ... circling back after being frustrated
So, I called the dealership. Not sure if I mentioned I only bought the truck in December. I told him about my predicament: My door sticker states I can carry 1,040 lbs of payload ... and the RAM website stated for my VIN, as configured/ordered, that my max payload was 1300 lbs and that my towable weight was 7860 lbs. He said - "that's not right ..." Your truck will tow 10,500 lbs AND carry 1,900 payload (passengers and cargo) ... all simultaneously! Come on ... you don't think RAM would make a truck that wouldn't hold 5 workers and be able to tow!? The loggers go up and down here every day with 10,500 lbs in their 1500's." I corrected him with what I learned from this forum and he insisted that I was wrong ... that hitch weight wasn't included. So using RAM's towing site, which made more sense to me after spending time reading all of your posts, I found the info I needed on the RAM websites to prove he was wrong. He asked me to contact RAM Corporate because that can't be right. So I did. I spoke with a young lady who opened a case up for me and insisted, reading general documents, that I could tow (based on my VIN number), 10,650 lbs AND separately add 1600 lbs of passengers and cargo. That was a new number - no idea where it came from be she also insisted that the tongue weight was irrelevant. SO ... they have opened a case and they included the information I presented to them which includes their own websites saying that you must subtract tongue weight from the payload for an adjusted payload, which in my case would be 1000 lbs from 1040 lbs. The young lady from corporate couldn't believe it ... their own website shows that the tongue weight needs to be 10-25% of the trailer weight. I said, it wasn't possible to tow a 10,000 trailer with 10% weight and drive the truck. She got her manager involved who opened the case. And yes, because I have the integrated computer-controlled air suspension, if I go over my weight, it will error and bust my warranty. So, in closing, does anyone have a 5 year old that can drive my truck and trailer for me because my fat ass will put the truck over its limit. I'll also have to leave my wife, kids, chairs, food, generator, water, and cookies (the main reason that I need a 5 year old to drive my truck). http://www.airforums.com/forums/imag...lies/angry.gif Here's the best part. I'm checking out 2500's and 3500's. They're all too big to park in my underground parking garage. So, in addition to ditching my 5 month old truck, needing to buy a trailer, needing to buy a new tow vehicle that will actually carry my fat ass and my box (okay ... boxes) of cookies, and the rest of our stuff, I'll also need to buy another vehicle to commute to/from work daily. So I broke the news to my wife... That's a story for another time. Get your cookies ready.
AIRHEDS is offline   Reply With Quote
Old 05-27-2016, 03:39 PM   #53
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You just talked me out of buying a new Dodge. I was seriously considering it. Far as I am concerned it is an American right to be able to sometimes overload a pickup truck. What is the point of having one? Sensor to bust warranty? No way for me. If it says Ram tough it better be.
Do they still sell the trucks with real springs?
Does Dodge use the new industry standard to messure towing capacity? They must have a retired jockey to drive it up the course sitting on a plastic Coke crate.
We tow a 25' with a 2007 Dodge 2500 4x4. We have 175000 miles on it, about 1/3 of which is towing. (my experience). And you are right about parking garages. It is too high for many of them and scary in the ones it is supposed to fit. The 2x4 trucks are a couple of inches lower.
There are 1/2 tons you can tow Airstreams with. But it does not sound like the air suspension Dodge is one of them. I bet they cannot tell you how heavy the load must be to trip the sensor?
Old 05-27-2016, 04:16 PM   #54
Plasma800's Avatar
houston , Texas
exactly.........
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 05-27-2016, 04:58 PM   #55
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Please help newbie demystify towing ...
There are three kinds of people in this debate.
1. Those who study the published figures and data and come to a decision.
2. Those who simply use what they have and decide whether it works or not.
3. Those who study published data, and to it add the benefit of practical experience and decide what works and its limitations.
Practically speaking, whether everyone agrees or not, a good weight distribution device coupled with GOOD TIRES WILL extend the practical payload of a tow vehicle.
This is much of the philosophy at CanAm, and mine as well.
Everyone is going to pretty much do what they think is right, as will I.
I love my 1/2 ton to tow my Airstream, I would never feel forced to buy a 3/4 to or bigger just for the sake of towing it. My combination tows super sweet even with 1,200 pounds of tools and stuff in my pickup box.
I know there are folks here who will not believe that, but I have A LOT of towing experience, I know what a nice towing setup feels like.
Superat stultitia.
Old 05-27-2016, 05:20 PM   #56
dkottum's Avatar
You are frustrated, no wonder as there is no one at Ram you talked to who knows a damn thing about setting up a truck for towing, the effect of weight distribution or balancing trailer load and equipment.
We have steel coil springs, our Airstream loaded for travel 7300 lbs and ProPride hitch add 820 lbs to the truck at last weighing. The factory hitch weight spec is 835 lbs empty and ProPride hitch assembly 180 lbs. Go figure.
Our Ram GVWR is 6950, total axle capacity 7800, total tire capacity 10400. This is our second Ram with these ratings, my experience is the GVWR is hundreds of pounds less than what the truck is easily capable of with an Airstream trailer and well set up weight distribution hitch, drives, brakes and handles extremely well.
My experience without the trailer, I would not exceed GVWR loading only the truck bed. An entirely different driving, handling and braking experience, bed loads put everything on the rear axle, our trailer with w.d. puts even loads on the axles.
Then there is the Ram air suspension measuring and reporting GVWR overload, and the fellow who told you it would "bust your warranty". Yes it does measure loads, I doubt it's there to "bust warranties" but if the word gets out that it does it will be "busting sales" big time. Read Bill M.'s followup post. Do you think Ram marketing will have a word about that.
I suspect the fellow who is telling customers an overloaded GVWR on their air suspension is a gotcha to "bust their warranty" will have the marketing division in an uproar, we'll see. We, nor many others would have the air suspension if this is the case, and I like the functional features it provides.
Another thought. Most of us are recreational Airstreamers, we don't tow these things up and down the highways and mountains on a daily basis. Much of the time we use them as the family car. I doubt our combined daily and recreational use puts unusual wear and tear on our trucks.
Our last Ram we traded in with 50,000 miles, never in the shop for a single repair, 45,000 miles on original tires with some wear left, brakes showing minor wear, actual trade-in value $4500 less than we paid for it. And with seven months retirement travel and camping every year, we towed far more than most working people.
Were we sometimes above GVRW when towing, probably. Were we above GVWR hauling bed loads, tried it, never again. There's a difference we as users know but manufacturers don't account for. Get to know your truck and you will know what it can do.
Doug and Cheryl
Newbie Towing Numbers - Expert Fact Check, Please! snarlz Tow Vehicles 11 07-06-2015 06:51 PM
Please help - opinion please - 1967 caravel for $1000 knishiya Airstream Trailer Forums 5 05-11-2012 09:33 PM
PLEASE help me with towing needs -PLZ tempest2 Hitches, Couplers & Balls 5 06-05-2009 11:22 PM
Newbie trying to decode Serial Number: HELP, please? rocklobster Member Introductions 4 08-06-2007 08:09 AM
Bmw Towing Capacity Please Help ACHALAT Tow Vehicles 4 02-03-2006 06:42 AM
