Old 11-21-2013, 04:40 PM   #1
Winnipeg , Manitoba
Please Clarify - Tow ratings
I need Clarification on how much airstream I can tow with either the Ram or Ford, I just don't get It I want to buy eventually a 30 or 34 ft airstream around 9, 000 pds or just under and I'm unclear about the Advertised Max tow capasicty and the GCWR??? The Ram truck has 6,1000 and a 11,2000 GCWR does that mean it can tow 6,100 pds airstream or can it tow a much larger up to max 11,200 pds. Sheeeesh HELP PLS
2013 Ram 1500 VS. 2013 Ford F-150 XLT SuperCab
*Advertised Max Towing Capacity:
6,100
6,400
*GCWR:
11,200
11,700
Available Towing Capacity (GCWR - a - b):
5,765
6,150
Trailer weight:
5,765
5,765 (run 1)
6,065 (run 2)
Note: *Ram requires optional 3.55 rear axle, Ford requires optional 3.73 rear axle
Happydays is offline   Reply With Quote
Old 11-21-2013, 05:00 PM   #2
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
The reason it is unclear is that you left out payload capacity- very different from towing capacity. Your tongue weight is subtracted from payload which is usually found on the door sticker. That is the one critical figure that separates the 1/2 ton from the bigger trucks and why some tow with 250's or 2500's. The towing capacity is really just how much extra weight the truck can pull but the payload is the "load" it can handle. You will get a lot of feedback on this forum but without ANY alteration of the truck, you need to know BOTH the payload capacity of the specific truck AND the towing capacity with payload being the most important in a 1/2 ton because that is the one you will most easily surpass. What is the rated tongue weight of the trailer you want? That is the weight load bearing down on that hitch and rear of the truck. Mine is rated at 840 but it is 1000 with LP gas, etc. Weight distribution balances out that weight but it still must be within specs to be safe. Yes, if you go with Ford, the max trailer tow package requires the 3.73 and the truck (2013) will have anywhere from 1700-1900 or so payload capacity. The 1900 being the max payload package too. The regular F150 has a payload of around 1400 or so- my neighbor just got a 2013 Lariat with a 1412lb payload. My '09 is 1548 lbs. My tongue weight is 1000 lbs. by the CAT scale so I have 548 lbs left for people and stuff.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 11-21-2013, 05:06 PM   #3
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Yes the new rage in truck advertising is how many LBS they can tow.
But the harder thing to find is how much payload can they haul (not advertised).hmmmmm
Old 11-21-2013, 05:24 PM   #4
Winnipeg , Manitoba
Besides the door sticker is their anyway to know maybe by pulling up the VIN??
Old 11-21-2013, 05:28 PM   #5
Winnipeg , Manitoba
Does this help
2013 Ram 1500 SLT Quad Cab
6,100
6,400
*GCWR:
11,200
11,700
Advertised Curb Weight:
4,928
5,043
(a) Measured Curb Weight:
5,050
5,165
(b) Occupant and Luggage Weight:
385
385
5,765
6,150
Trailer weight:
5,765
5,765 (run 1)
6,065 (run 2)
As-Tested GCWR Percentage:
100%
96.7% (run 1)
99.3% (run 2)
Old 11-21-2013, 05:32 PM   #6
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
You're not using the right numbers. Max GCWR for an F150 XLT Supercab is 17,100 lb, TRAILER max weight is 11,100 or 11,300 depending on wheelbase.
— David
Old 11-21-2013, 05:34 PM   #7
Winnipeg , Manitoba
What can this tow Make/Model: 2011 FORD F350 SD XL CREW CAB
Make/Model: 2011 FORD F150 FX4 SUPERCREW
Old 11-21-2013, 05:40 PM   #8
2006 25' Safari
Images: 8
The numbers are incorrect. Here is my door sticker. Note the one that says tires and loading info. Note the 1548 lbs. Another source is the towing guide. Ford has one online and I am sure Dodge does too. It will tell you by configuration what the general payload capacity is. Each truck, by VIN has a capacity based on engine, springs, etc.
Old 11-21-2013, 05:46 PM   #9
2006 25' Safari
Images: 8
Here ya go!
Towing Guides | fleet.ford.com
Old 11-21-2013, 07:01 PM   #10
Winnipeg , Manitoba
O Wow you all just made my evening!!!!
We are looking at a used ford 150 just as listed above.
At first we thought of a Ram but this seems like the right one for us
thank you all sooo much
Old 11-21-2013, 07:22 PM   #11
7GenTex's Avatar
Briarcliff , Texas
You will run out of payload (trailer tongue weight, driver, passengers and gear in the truck) before you get anywhere near "Max towing".
Imagine that!
What you will see in most brochures / towing guides is "maximum" for tow limit and payload.
How the truck is actually trimmed (XL, XLT, Lariat) and optioned makes all the difference in the world. Higher trims usually equals LESS payload.
Don't believe published tongue weights either - usually VERY low compared to actual "ready to go / camping" weights.
IMHO - For a 9#k trailer - I would be in a 2500 series minimum............
Advertising is like........................advertising!
1966 T-27 Avion (Sold & missed already!)
7GenTex is offline   Reply With Quote
Old 11-21-2013, 07:44 PM   #12
2006 25' Safari
Images: 8
7GenTex has a point.
Glad to help. The towing guide is just that.
Old 11-21-2013, 07:50 PM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
The best way to make sure your not over the payload ratings.
Weigh the truck and check the front and rear axle loads against the door sticker. Those specifications along with tire load ratings will tell you how much payload you have available.
As noted... it's way more likely you'll run out of payload before GCWR.
Better to have more than you need than need more than you have.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 11-21-2013, 09:25 PM   #14
DKB_SATX's Avatar
1976 Argosy 28
OK, from what you wrote at the beginning, I though you were looking at generic new trucks. Are you looking at specific ones for sale? What engines are in the 2 trucks you're comparing? If you're looking at a naturally-aspirated 3.7l V6, the numbers you quoted for the F150 are close. If you're looking at the V8 or the Ecoboost, it's closer to the numbers I tossed out higher in this thread.
— David
Sequoia Tow Rating akjam Tow Vehicles 17 02-06-2012 11:15 PM
Need a truck to tow a 2007 16' Bambi rportillo Tow Vehicles 15 10-24-2011 01:48 PM
Van Conversion/Small Motorhome as tow vehicle? TG2500 Tow Vehicles 0 10-16-2011 06:07 PM
1/2 Ton Tow Vehicles brianw Tow Vehicles 39 09-08-2011 06:44 PM
Tow Vehicle for 27' Overlander pyrenees Tow Vehicles 9 05-06-2011 08:18 PM
