Old 10-29-2015, 09:31 AM   #1
MACINRIC's Avatar
1977 29' Ambassador
Richmond , Virginia
Pigtails and brakes 1977 Ambassador
I've just ordered up a pigtail that'll insert into my 1977 ambassador and then plug into my 2006 Chevy Suburban.
How do the Tow Vehicle brakes interact with the pigtail?
Should things like the brakes work as designed or Do I need to get a brake controller? I plan on 2 or 3 short trips this year and a whole slew next year.
MACINRIC is offline   Reply With Quote
Old 10-29-2015, 10:09 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
You need a brake controller. Some newer vehicles with towing packages have them built-in but I am sure the 2006 does not.
BambiTex is offline   Reply With Quote
Old 10-30-2015, 11:09 AM   #3
MACINRIC's Avatar
1977 29' Ambassador
Richmond , Virginia
DO the brakes go to full on with the slightest tap without a brake controller or just no work at all?
-Mac
Old 11-02-2015, 05:52 AM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
They will not work at all unless there is a controller sending them a signal.
Old 11-02-2015, 11:04 AM   #5
1977 31' Sovereign
Lynnwood , Washington
Do you have original brakes??.....with master cylinder and power brake booster??
Or, have they been converted to electric brakes?? If it's been converted, you'll need a brake controller.
Tom
TomKirk is offline   Reply With Quote
Replacing pigtails on'86 32' excella rbhinzman LP Gas, Piping, Tanks & Regulators 1 08-25-2014 11:00 AM
Marshall pigtails with 3/8" male fitting 2goldens LP Gas, Piping, Tanks & Regulators 4 04-03-2014 09:46 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Need Quick Disconnect Battery Pigtails sharris1199 Batteries, Univolts, Converters & Inverters 9 08-05-2009 10:46 PM
Old 1/4" pigtails don't fit new 1/4" regulator? longdog LP Gas, Piping, Tanks & Regulators 1 04-22-2009 08:56 PM
