Old 07-22-2019, 06:17 AM   #1
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Payload? So why not add a leaf?
I ran across this product for an F-250 to "Add-a-Leaf" into the leaf pack. The kit purports to increase the payload capacity by 1100 lbs.
The video gives you an idea of how simple it is to install (although having a lift is Ideal) and the cost is minimal. I have heard that the difference between a single rear wheel F-350 is nothing more than an F-250 with an extra leaf spring. Well, it may not be that simple! This may add 1 1/2" of height to the rear (arg!) but 1100 lbs. of additional payload! That's nice.
Many here have said the ride difference between an F-250 and an F-350 are very similar. So why not do this to add even more stability? My F-250 diesel has a payload of 2100 I believe. Add the 30' Classic and ProPride hitch and I have about 800 lbs. leftover. Add two people and a large dog, 390 lbs. I carry about 350 lbs in the bed with cap, 60 lbs. left. It goes fast. Now add in the weight transfer with the weight distribution hitch and we might be back to 200-300 lbs. We are at the upper range.
Does this make sense? It seems like a very simple solution to a problem everyone here has to deal with. Kits are available for many trucks, and I realize you are not going to make an F-150 into an F-450, but given the similarities of the 250/350, this could work well. IMHO-WNEWTAA . (In my humble opinion with no experience with this at all)
Video:
https://youtu.be/9Asuh-cdYUo
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 07-22-2019, 06:51 AM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Sure it does. I’ve done it 3 times on other trucks. All GM products but same concept.
Dept of “OverKill”
Old 07-22-2019, 07:02 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yep...as long as the drivetrain, tires and axles are up to specs.👍
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 07-22-2019, 08:46 AM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
Sure, the kit will change how your truck carries weight. However, it will not change the data on your door sticker if that were ever to come into question by a DOT officer or after a major traffic crash.
CRH is offline   Reply With Quote
Old 07-22-2019, 09:18 AM   #5
kpm
2018 25' International
Mound , Minnesota
There is a recent thread on the payload frustrations and possible remedies on the ford truck forum - https://www.ford-trucks.com/forums/1...strations.html. Similar to airforums, everybody's got an opinion
kpm is offline   Reply With Quote
Old 07-22-2019, 09:28 AM   #6
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Agree with Robert Cross on this - short answer is yes, provided that.... (the rest of the truck meet the load spec) I have seen this done on F-150.
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
drbrick is offline   Reply With Quote
Old 07-22-2019, 10:02 AM   #7
2019 22' Sport
Waynesville , Missouri
Check Your Truck Weight Planning
Video:
You may want to check the way your truck's manufacturer came up with it's weight capacity. I know they base capacities on 200lbs for each passenger, plus that number might be already subtracted out of what's left on the overall weight capacity. Not sure if I said that last part clearly. The weight you can put into your vehicle might already have 200lbs people factored in, so you might not have to subtract yourself, your better half, and a dog. My TV's weight capacity was based on 4- 200lbs people. Since my better half and I are the only passengers, I can add 400 lbs to the TV's carry capacity (2x200lbs). Not all vehicle makers base their numbers the same way, so you have to check with them to see the way they calculate their numbers.
DAVSCH is offline   Reply With Quote
Old 07-22-2019, 10:09 AM   #8
2013 20' Flying Cloud
Westerly , Rhode Island
I'd be interested to know what manufacturer calculates payload like that. In the end though it doesn't really make a difference since a trip to the CAT scales with your GVWR and GAWRs are really all that matters for the TV.
smithcreek is offline   Reply With Quote
Old 07-22-2019, 10:23 AM   #9
CWSWine's Avatar
2019 33' Classic
Manhattan , Kansas
There are two ratings that you are working with. One is the GVWR and GAWR. The GVWR has nothing to do with the axles and springs but solely a chassis rating and the axle ratings are ratings of the axles/springs being able to carry the weight. You figure payload by subtracting the CAT scale weight of the truck from the GVWR equals the payload the truck can handle. So to increase the payload you have to increase the GVWR listed on the silver sticker on the door jam and of course, you have to stay within GAWR/GCWR/Tire Ratings.
Will it make the truck more capable to carry the weight - Yes. Does it increase the assigned payload of the truck - NO. Will you get pulled over and given a ticket for being overweight - Very Unlikely. Could it be a liability in an accident - Possibly."
Since the truck manufactures towing guides says "must not cause vehicle weights to exceed the rear GAWR (Gross Axle Weight Rating) or GVWR (Gross Vehicle Weight Rating). These ratings can be found on the vehicle’s Safety Compliance Certification" I wish everyone would follow their advice for their safety and others on the road, You're the captain of your ship and only you can decide is the risk worth the benefit.
PS In my state the insurance has to cover the cost of an. accident up to the limits on your policy. If you end up in court and found negligent the judge can make you pay back the insurance company the entire claim cost including court cost.
Dennis & Ellie
2019 Ram 2500 Longhorn 6.4 Hemi w/2868 payload on the Yellow Tag.
2019 Airstream Classic 33FB Dry Weight 8595 Tongue 1230
CWSWine is offline   Reply With Quote
Old 07-22-2019, 11:39 AM   #10
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
My intention is not to add any more payload to the truck, and in fact, I have removed some of the weight (items) we really don't need. I am trying to get the best towing experience out of the truck.
I just found my CAT scale sheets. Will post a better picture in a bit.
Old 07-22-2019, 11:56 AM   #11
CWSWine's Avatar
2019 33' Classic
Manhattan , Kansas
Before I would add a spring that would affect the ride either loaded or unloaded I would add Air Bags that can be aired down when not towing. You can also adjust the air pressure to handle different loading.
Dennis & Ellie
Old 07-22-2019, 11:56 AM   #12
1996 25' Excella
Tillsonburg , Ontario
My issue with my Dakota was the trailer hitch was stressing the truck frame since original spring rate was not adequate. The weight transfer bars were really curved and the hitch head was flexing up as it was lifting the rear end.
Solution was either beef up the hitch or as the spring shop suggested add a leaf and a helper. Really Glad I went that route
Truck now sits 1 1/2 in higher unloaded but I don't need near as much weight distribution
Truck has run that way now for 15 years. I do not consider the payload to.be increased
But weight distribution is much easier
JCW
JCWDCW is offline   Reply With Quote
Old 07-22-2019, 01:05 PM   #13
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
OK, here are the door stickers. As you can see, the Payload on the sricker is 2086.
My GAWR is a total of 12330 from the CAT scale, but you can't use that as the rear can only hold 6340. Subtracting the weight of truck from total GAWR would not work as a payload number as the rear could be overloaded.
The sticker shows GAWR rear as 6340. My Cat scale rear number loaded is 5400. You would subtract that from the sticker rear number GAWR to approximate the payload left. 6340-5400=940.
Cat scale shows 4800 front, 4240 rear with no load and bed cap added. Cat rear weight truck loaded with trailer and WD =5400.
5400 - 4240= 1200 This I assume would be tongue weight and loading rear tires with one person and dog. If I add the tongue weight calculated plus the remaining payload weight you get 1200 + 940= 2140. Is that right?
I also have the cat scale weigh slip for a loaded truck and trailer. Other weighs show 260 lbs. moving to the front truck tires and 200 lbs moving to the trailer tires.
With weight distribution
Steer = 4920
drive = 5400
trailer = 8840
No weight distribution is:
steer - 4640
drive = 5740
trailer= 8640
My brain hurts.
Name:	door sticker payload.JPG
ID:	347337   Click image for larger version
Name:	door sticker GAWR.JPG
Name:	Cat final.JPG
Old 07-22-2019, 01:18 PM   #14
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
The payload capacity shown on the door jamb sticker has already factored in all fluids and a full tank of fuel, but it does NOT include the weight of a driver, passengers, or any other cargo. I'm fairly certain the same standard is used by all the major truck manufacturers.
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is offline   Reply With Quote
Why the big payload difference between 3/4 & 1 ton Wanna EB Tow Vehicles 29 04-25-2016 08:37 AM
Looking to downsize and simplify. Is Airstream a good option? Why? why not? jeremymm Full-Timing 23 12-05-2014 05:34 PM
sell my new tundra? add a leaf? stay single? carl28 Tow Vehicles 91 10-06-2010 12:23 AM
Pro-flamingo? Why or why not? Stella Fun & Games 32 04-13-2008 10:18 PM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
