Old 07-27-2015, 10:45 PM   #1
Rockingham , North Carolina
Payload: does it count 150 lb driver? Full tank? Or neither?
Read all the old threads I could find. I'm hearing many different explanations about how I should use the payload sticker on inside driver door jamb.
Does it include 150 lb driver and full tank?
Full tank of fuel but not driver?
Does it account for nothing but empty vehicle? So all human, fuel, gear, counts
Curious if anyone knows. Where would a person verify this?
Thanks.
Dan
Danattherock is offline   Reply With Quote
Old 07-28-2015, 12:11 AM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Payload capacity includes all of the previously-mentioned.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 07-28-2015, 05:21 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
In our Ram truck, payload is the difference between GVW Gross Vehicle Weight and Curb Weight. Curb weight includes fuel, fluids, and all options on the truck but no passengers or added loads. So you can see the more optional equipment you have the factory add to the truck, the lower the payload. And the more people and added loads, the less the remaining payload. Here's a guide from the Ram truck site to play with and get some definitions.
Ram Trucks - Towing Capacity Chart
Hooking a trailer will add to the payload as well, but it's not straightforward. Just dropping it on the ball may leave you within payload but overloading the rear axle or tires. A good, effective weight distribution system will redistribute much of the tongue weight (and truck's load load in the bed behind the truck's rear axle) among the truck and trailer axles.
So with a weight distribution system, you cannot just add trailer tongue weight to the truck's payload for an accurate weight, you must take it to a truck scale to know what effect the trailer tongue weight has on payload and axle and tire loads. You will also learn if your weight distribution system is adequate and adjusted properly (many are not).
Doug and Cheryl
Old 07-28-2015, 06:00 AM   #4
Thanks. That opens another can of worms
Read many times WD adds 100-150 lbs to what I count against payload. Just like adding another 100-150 lb person.
I've also read that if WD is adjusted properly it returns some portion, up to 30%, to axle on camper. So if 900 lb hitch weight camper, 300 lbs off that number is transferred back to camper axle/axles.
Obviously HUGE difference on which happens.
If this is false, my 900 lb hitch plus 150 lb WD is 1150 into my payload capacity.
If this is true, 900 lb with WD 150, puts 1/3 back, so leaves 750 in pay cap.
And that would be assuming I leave all the weight of WD in payload capacity.
Which is still a net difference of 400 lbs!!
So which is it? Huge difference. How does one verify these 'rules'?
There has to be more than contradicting opinion for newer folks like myself. Not that I don't appreciate all opinion. It's what has me asking these questions trying to learn. But I'm really surprised there is not a more unified consensus. We are after all, talking about physics. My experience with such in past has had little appetite for opinion.
Thanks for any suggestions or links to where I can learn more. About to buy a tow vehicle and first Airstream. I'm not going to this without being sure I'm safely doing so. This is all new to my wife and I, with infant and toddler. I've spent too much time looking at $60k trucks and not enough time determining if I need one.
Dan
Old 07-28-2015, 06:16 AM   #5
dkottum's Avatar
Buy the trailer first, then shop for a truck match trailer, loads in truck and trailer, and your family vehicle needs. And of course your family budget for the whole thing.
The hitch between the truck and trailer should not be underestimated, its ability to distribute the weight you need and dampen or eliminate sway, and its proper setup are just as important as truck and trailer.
Doug and Cheryl
Old 07-28-2015, 06:30 AM   #6
N/A , N/A
Thanks.
Dan
Here is what Ram's user manual says on page 646:
"Payload
The payload of a vehicle is defined as the allowable load
weight a truck can carry, including the weight of the
driver, all passengers, options and cargo
It seems a full tank of gas is assumed, and everything else (including the driver) counts against the payload figure.
rostam is offline   Reply With Quote
Old 07-28-2015, 07:13 AM   #7
That's very helpful, thank you.
I wonder if all manufacturers do the same. I've read Toyota, for example, is complying with some new rules, that others may not be. It's what I read is reasoning for the low payload capacity ratings for the Tundra.
Not sure what's the truth, but it does seem possible that the manufacturers might tabulate things differently. If true, yet another variable in what's already in my opinion a minefield.
Anyone with another manufacturers truck or full size SUV? If time allows, what's the cliff notes from your owners manual. Would be most insightful to me and other village idiots reading here. Ha ha.
Dan
Old 07-28-2015, 07:21 AM   #8
richinny's Avatar
2011 34' Classic
my 2012 F150 deducts 150 lbs. for the driver and a full tank of gas before giving the payload number.
Ricky
Old 07-28-2015, 07:27 AM   #9
dznf0g's Avatar
Oswego , Illinois
I thought I recalled that FMVSS moved the driver to 175 lbs (since the fattening of America), but regardless, that not a huge thing...but yes, full tank of fuel and all fluids are accounted for.
-Rich-
Old 07-28-2015, 07:30 AM   #10
dznf0g's Avatar
Oswego , Illinois
Dan, the only "new rules" I am aware of are for towing capacity, and most all mfrs are on the J2807 standard. Toyota was first but the others followed as new updated trucks came out. GM: 2014 for 1500s; 2015 for HDs, 2015 for Colorado; 2014 for Full Size SUVs. Crossovers and cars are a mixed bag, but are all now J2807.
And they aren't "rules". Rules are in FMVSS, relative to GVW, GAWRs, Payload, etc. J2807 is a voluntary rating "suggested" by SAE for comparison shopping purposes.
You may even find GCWR numbers for a vehicle which are higher than J2807 numbers.
-Rich-
Old 07-28-2015, 07:39 AM   #11
N/A , N/A
My understanding is that 150# for the driver is considered for calculating GCVWR only, and for payload purposes the weight of the driver, passengers, and cargo all must be added up, and compared to the door sticker. This is according to the new F150 manual.
Old 07-28-2015, 07:53 AM   #12
dznf0g's Avatar
Oswego , Illinois
Anything with a "R" behind it is the rating, or max established by the mfr. Max payload is the same, a rating. All the "r" numbers include driver, full of fluids and fuel. "Actual payload" and anything without and "R" behind it are measured and scaled at a point in time with a particular load, and include everything....vehicle options, aftermarket add-ons, people, dogs, cargo, etc......
-Rich-
Old 07-28-2015, 08:06 AM   #13
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
The payload stickers on any car/truck have the same language " The Combined Weight of Occupants and Cargo Should Never Exceed xxx KG or xxx LB"
Old 07-28-2015, 08:09 AM   #14
richw46's Avatar
Lexington , Kentucky
Dan
It's an SAE standard used to measure towing capacity for trucks (and cars) with a payload of less than 14,000 payload (up from 13,000), not a rule or law but a voluntary standard. It just puts everyone on an equal footing so the consumer can compare towing capacities among vehicles and not have one manufacturer exaggerate their claims.
Ford finally agreed that it would use the J2807 on new or redesigned trucks so the F-150 for 2015 is certified for J2807 but not previous models. Toyotas are certified starting in 2013. Ram and GM 1500-series pickup trucks were certified to SAE J2807 as soon as it was clear that Ford was going to follow through. Nissan is the only holdout at this time.
Standardized Tow Rating Procedure Finally Gaining Traction | Edmunds.com
All the unrealistic test weight practices of the past that led to asterisks and fine print have been eliminated. Maximum tow ratings can no longer be based on a stripped base-model truck with a 150-pound driver traveling alone. Test trucks must now be equipped with popular options found on 33 percent (or more) of the configuration being tested. The 150-pound test driver is now accompanied by a 150-pound passenger.
http://www.autonews.com/article/2013...-isnt-standard
To pass the acceleration test, the vehicle and loaded trailer have 12 seconds to reach 30 mph and a total of 30 seconds to reach 60 mph. The vehicle also must be able to accelerate from 40 mph to 60 mph in less than 18 seconds, all on level ground.
The climbing test requires the vehicle and loaded trailer to ascend 3,000 feet over an 11.4-mile stretch without dropping below 40 mph and with the air conditioning at maximum. The test is based on the Davis Dam grade, a stretch of Arizona road southeast of Las Vegas.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Forgive me: Does tongue weight count against payload? marter Towing, Tow Vehicles & Hitches 105 09-24-2017 07:51 PM
New - Does an Interstate Still Count:-)? mjwcubed Airstream Motorhome Forums 16 05-11-2015 10:13 PM
Ford 2014 Ecoboost 150 with Max tow and HD payload Rollster On The Road... 27 01-20-2015 08:10 AM
Driver seat does not pivot 180 dateem Land Yacht/Legacy Motorhomes 11 11-12-2014 02:32 PM
