03-18-2016, 06:11 AM
2016 30' Classic
Houston
Parkit360 Trailer Dollies
Any experience with this brand of trailer dolly? Looking at the Parkit360 unit that is advertised to be effective with trailers up to 10,000 lbs. I have a ProPride hitch installed. The Parkit360 vendor's tech rep has told me that the Parkit360 unit can connect directly to the trailer's retracted hitch stand leg. Any thoughts will be appreciated. Thanks.
03-18-2016, 07:12 AM
Biloxi
, Mississippi
MICHAEL
03-18-2016, 08:19 AM
Oswego
My brother in law got one. When using the jack leg for the pivot point, there isn't enough clearance, to the handle/motor for a hensley head to swing. I suspect PP is the same.
-Rich-
03-18-2016, 08:36 AM
2005 30' Classic
Glendale
I use a parkit 360 with a classic 30' and a hensley hitch. I made a receiver adapter for the parkit 360 and hitch it up as if I were hooking up to the back of my truck. Works great. I can send pictures it you like.
03-18-2016, 08:58 AM
Oswego
Yes, please. I told my Bro that we could fab one up, but why reinvent the wheel? I list of brands and parts would be helpful as well.I assume you are using the HAHA stinger box to attach your adapter? How are you holding the head in place to prevent swinging?
-Rich-
03-18-2016, 09:59 AM
2005 30' Classic
Glendale
I keep my trailer in a storage garage a few miles from my house. I will take a few pictures this afternoon. The adapter is a 2" receiver welded on top of round stock. I do use the stinger hook up. Raising the hensley jacks levels the parkit 360 and removes the head play. The head will pivot to the side but hasn't interfered with my ability to back it up.
03-18-2016, 10:05 AM
Oswego
I have seen folks use a rod in the little "lock lever" slot between the upper head and lower head....as well as 2 pair of vice grips on the lower head, "capturing" the top head in place between them.
-Rich-
03-18-2016, 12:29 PM
2005 30' Classic
Glendale
The adapter is a 12" receiver purchased from Amazon. The round stock is 2" OD x 7" long with .25" wall purchased from speedymetals.com. I had a local shop weld the pieces with the addition of the 2" gusset added by them. He charged me $20.
03-20-2016, 06:50 AM
Stoughton
, Wisconsin
Do you have to put pressure on the jacks?
03-20-2016, 08:09 AM
2005 30' Classic
Glendale
For my setup I raise the hensley jacks to the first indicator notch
03-20-2016, 08:41 AM
Firedog1
2018 30' Classic
Woodbridge Connecticut &
, Venice Florida
I have a park it 360, used it once, worked great on my Classic, Then we put in a new larger driveway so I no longer need it. PM me if interested
Russ and Lisa
2018 Classic 30
2020 GMC Sierra 3500HD Denali Diesel 4x4
Sold but not forgotten: 2005 Classic 25 Limited
2015 Classic 30 RB
08-27-2018, 11:44 AM
2022 25' Flying Cloud
NCR
, Ontario
I use the parkit 360 with my AS 22FB 2017 Sport,
When using parkit360 on the hitch post I have only 30 degrees movement , as the lifting post hits the wheels of the parkit
I now remove the shoe from the lifting post. Then I lower that into the post on the parkit 360
Now I can maneuver the Parkit 190 degrees
08-28-2018, 08:04 AM
NCR
, Ontario
