Old 07-23-2016, 03:08 PM   #183
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
The forks get held by a mount that locks them in place like the wheels are attached. Look at the Yakama and Thule bike racks. Often used in the back of a pickup. Think carpet covered plywood with a set of vertical slots for the wheels. Less will be more, because it's easier to load and unload. Padding, boxes that capture the mount in a central location. You will find a way. Go slow and work it out.
Your kids bikes got shipped disassembled. They come apart. Get out your wrenches. Show them how to use a tool. Make it a new camping tradition where you work together to set them up and tear them down. Time them. Encourage them. Make it a family thing. You will have fun.
The interior bike racks can capture the wheels or the forks. Depends on the space and rack style. Both will need to be controlled. You are correct, you do not want to damage the floor.
Good luck. Pat
Old 07-23-2016, 04:51 PM   #184
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by cazual6 View Post
>> snip>> The interior bike stand, whether DIY or store bought is something I would consider << snip<<
An interior bike rack is what I use now. I bungie the bikes together and into the rack. I've been doing this for several years. It also give me a place to store the bikes at the campsite and cable lock them all together.
http://www.homedepot.com/p/Racor-2-B...A&gclsrc=aw.ds
I went through the same scenario as you are doing now, but several years ago. I went as far as building a custom hitch and mounting it on my Safari. I took it off after the forum members warned me, and I considered the potential of rear end separation in the trailer and/or the possibility of wrecking the truck/trailer. The hitch is still lying out in the garage waiting to be re-purposed into a front mounted hitch for my truck, to support the bow of my canoe.
I also built a custom bike rack for the trailer. At least I was able to sell the bike rack.
Alan
A W Warn is online now   Reply With Quote
Old 07-23-2016, 06:39 PM   #185
2015 27' Flying Cloud
Washington , Washington, D.C.
I would keep the concentrated 100+ lb. mass of the generators out of the ends of the trailer and load them over the axle. It's obvious that shorter single-axle trailers are much more sensitive to loading. Left to its own, a single-axle trailer has zero yaw stability. If you were strong enough to lift the tongue, you could spin it around easily. By contrast, a multi-axle trailer has inherent yaw stability; it wants to go in the direction it's pointed. I can see that every time I put my FC 27 into a tight turn when parking it; the tires scuff on the ground. So you really need to keep weight out of the ends of your trailer, even if it's "balanced" on the pitch axis (up and down). Trailer "sway" happens when the trailer becomes unstable on the yaw axis and the trailer, using the hitch near the bumper as a lever arm, tries to change the direction of the tow vehicle. Putting weight in the ends of the trailer increases its rotational inertia, making it harder to control once it starts to rotate. Friction type anti-sway hitches resist this motion but once the trailer has enough rotational energy to overcome this friction, then it offers no additional resistance.
I don't have anything to add to what others have said about the jury-rig bike hitch and the bikes except to note that, like the generators stored in front, they just add to the rotational inertia of your trailer, which makes it more difficult to control.
I have the Flamma rack on my FC 27, and the upper support broke in exactly the same place as someone showed in the photo. I was carrying an aluminum-frame "hybrid" bike and a cruiser-style bike, though not as heavy. So, I'm not wild about the product, especially given its cost. But . . . It does carry 2 bikes properly for an Airstream.
Finally, I spent nearly 6 months based in your area traveling all over the west. I took seriously California's 55 mph speed limit for towed vehicles, not exceeding 60. I noticed that most trucks did the same. I had read that your police were not lenient with RVers who flagrantly violated that limit on the theory that they probably were not as competent as long haul truck drivers. It made sense to me, but I didn't test the theory. Outside of California I would go 60 or the limit whichever was lower. After I had accumulated over 30,000 miles towing I would sometimes cruise at 63 in light traffic and easy conditions. From where you live to Big Bear, the time difference between going 55-60 and 60-65 is trivial.
Just sayin'.
You are fortunate to live in a state with such incredible scenery. We went from Imperial Beach to Crescent City and everywhere in between- Death Valley, Yosemite, Kings Canyon, you name it.
Enjoy it all!
DC Bruce is offline   Reply With Quote
Old 07-24-2016, 01:29 AM   #186
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
Reseda , California
You've stuck with me through this thread, I appreciate it but no need for this.
I respect this forum to much to start throwing this kind of attitude. We can agree to disagree.
May I ask what you do and how you have so much experience in this?
You've been on this thread preaching a good amount of information, and truly I do appreciate it. I don't want you to think I don't.
But based on what you said, what you do, and your experience does matter. Look at some of the experiences said.
It is clear to me, you do care for my safety and the safety of others. I just have to know where you are getting your information from.
Don't take this as an attack, I am not.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 07-24-2016, 01:31 AM   #187
Stay CazuaL
cazual6's Avatar
Reseda , California
The mount is something doable. I just have to measure if the bikes will fit the way the mount will fit. I appreciate the positive comment.
WBCCI 9164
Old 07-24-2016, 01:53 AM   #188
Stay CazuaL
cazual6's Avatar
Reseda , California
Just sayin'.
Enjoy it all!
I would love to see the pictures. I am thrilled to have someone doing what I am trying to do. That actually did it.
I can do the two kids bike in the mount and the two adult bikes inside. That can work. I've done that already. And maybe this maybe the the way to go. The only way to go.
In one of my first trip, to Sequoia, I had the four bikes in the back and the gens in the front. The road to and from Sequoia from Northridge had all the fun of being the road. It was not smooth. Never experienced the sway. So sway was something I fought hard to understand, hence why this thread is still going. What stop the trip with the bike in the back was the Saris rack that was about to come apart on the way back. I had no incident on the way up. People were flagging me to look back. This was also when I bent my hitch due to the sway control bar because I had to do a three point turn in a street in Solvang where I pulled off. Also when I learned that NOT all bike mounts can be used for a trailer.
Sifting through this thread came good advise, well, all advise is good to me, but some were just wild statements that had no backing behind it other than to say it won't work. It may NOT work, I get it. But I wanted to understand. People gave lots and lots and lots of advice. Some made sense, and some were beyond my understanding. I continued and still continue to appreciate it.
I am stubborn. Especially when I put my mind into something. I work the problem to get a solution. Solution takes theory and field test. Everyone has given me so much information. i am sure they are all way smarter than me. And maybe that is why I didn't get it.
If you would please, send me pics of your current setup if it is not too much to ask.
WBCCI 9164
Old 07-24-2016, 02:35 PM   #189
Tom T
Tom_T's Avatar
Orange , California
Tom, it's becoming harder to be optimistic about this thread, but as I said in the beginning, I'm gonna appreciate the good, the bad and the ugly advices because to me, it just means they care.
When you said everyone does some sort of balance to counterweight the balance, why is my attempt any different. When we load our AS or TV we keep in our mind how the weight is distributed, I'm doing the same thing. My weight is gonna be heavier in the back, so I will put more weight in the front, and advices from other add an equipment to help if not enough, hench swaybar, cutting the bike shank to bring it closer, tie down sway control.
Hey Caz,
Don't lose faith/optimism. Some here take different approaches, & many are belt & suspenders + + + types, while others limit to reasonable suggestions. So take in what works in your case.
A while back on another topic, I had one fellow tell me I was crazy if I didn't have all of: the Hensley WD/SC hitch, electronic sway control in BOTH the TV & trailer, change out our "too old 1960" Avion's axles & wheels for "modern" torsion bar axles with disc brakes & shock absorbers, etc., etc., etc., & some other stuff I can't even recall. Sometimes it just goes too far with some folks.
I was saying that what you are attempting, is no different than others packing their trailers to balance them fore-&-aft for ride & hitch weight.
However, I was also saying that you may not even have a HW problem being too low - even with 3-4 bikes on the back, until & unless it is weighed with & without bikes. So that may be unnecessary, & you can place generators anywhere else inside that works best for you & closer to the axle - so long as the total weight of the trailer as loaded doesn't exceed either the Traverse's GCTW & GTW & HW or the AS's GVWR.
One concern I have with bikes, chairs, etc. carried inside the trailer, is that they could break loose & fly around & damage stuff inside a nice trailer - or even just sliding &/or vibration scratching the finishes &/or floor. I'd be concerned that the bike carrier set-up designed for a pick-up truck bed would possibly scratch up the floor & side cabinets, as well as adding weight, when proper tie-downs & straps/bungees to the bikes will do the same job without the added weight of the carrier unit.
AFAIK, only the AS Eddie Bauer toy carrier models (& whatever the new version is called) have the necessary tie-downs for ratcheting or elastic (bungie) tie-downs. So folks would have to add those into their other trailers, & they do make some nice AS & other maker flip-up/fold-down chrome & other finish hold-downs which can be flush mounted into floors or cabinets/walls (attachment done properly of course).
I think that your shortened shank on the Swagman bike rack & the added stabilization tie-downs/connectors will put you into the same or similar situation as an AS/Fiamma bike rack set-up allowed by the AS manual.
You now have your SC back & working on your WD hitch, so you have that safety matter set - which is needed with or without the bike rack/bikes issue. IMHO, the biggest part of your original sway problem, was that you had the SC disconnected & ergo had zero SC up to Big Bear that 1st time from the OP. The bikes on the rack exacerbated the problem, so I & others advised you to take them off until the hitch & balls/mount was repaired or replaced.
I would not try lengthening the tongue nor any of the other extensive mod suggestions of that sort. For far less money - assuming that your current WD/SC hitch isn't satisfactory in your &/or an AS dealer's or trailer shop's opinion - then you could always step up to the Hensley Cub for far less cost than trailer structural mods.
Hensley says there is no problem with using bike/cargo racks & sway with their hitch - in part due to the fact that they replace a half-cup with a tension coupler connection to the TV, with a solid connection of 2" square bars into both the TV hitch receiver & at the hitch head "box."
So my last advice now it to just have a fun vacation, stay away from this forum while there with your family so you enjoy your time with them, then pick it up again later when home.
Cheers!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner)
Tom_T is offline   Reply With Quote
Old 07-24-2016, 11:32 PM   #190
Stay CazuaL
cazual6's Avatar
Reseda , California
Originally Posted by Tom_T View Post
Hey Caz,
Cheers!
Tom
Thank you.
I've got some homework to do when I get from my cruise.
WBCCI 9164
Old 07-24-2016, 11:37 PM   #191
Stay CazuaL
cazual6's Avatar
Reseda , California
How did you secure the bike rack inside so it won't slide around or damage the floor?
Are you able to send me pictures how you did it? My wife would be thrilled about this.
WBCCI 9164
Old 07-25-2016, 05:32 AM   #192
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I made one for my insanely expensive merlyn road bike. I too have a 19' Bambi. I took table off and traved with that on the bed. I took a 2x4 the width of the floor under the table by front window. I got the same type little screw type bracket to hold front fork in place. I used two screws to keep on the 2x4. That's it. I am female, age 62, with the best, yet most unhandy husband in the world. It was so simple and effective and quick.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 07-25-2016, 06:25 AM   #193
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I don't have a photo. I will not be home until the weekend.
What I do:
My 25' has the gaucho across the front and the dinette on the road side. (Floor plan C six sleeper) The bike rack fits in between the back of the dinette and the gaucho, so that the bikes are facing side to side, not down the center of the trailer. I use a movers quilt/pad over the front edge of the gaucho that drapes down onto the floor. I set the bike rack on top of the portion of the quilt that's on the floor. After I load and bungee them together and into the rack, I cover them with a second quilt then slide them tight against the gaucho. At first I would use more bungees to fasten them to the furniture, but I've found that I do not need to. Normally the bikes will stay in place unless I have to brake hard. I suppose that is because of my slow and smooth driving style
Since your trailer floor plan is different and has one axle instead of 2, so it rides different than mine, all I can advise is to experiment with it.
I've seen some of the Eddie Bauer models that have tie downs in the floor. You might add a few of them to secure your bikes.
Sbb's method might be better for your size trailer, (and would allow for more bikes inside, even better)
Alan
Old 07-25-2016, 09:47 AM   #194
1974 25' Tradewind
Calgary , Alberta
Get a couple of these fork mounts and either mount them to a 2x piece of lumber or onto a 2x2 square of 1/2" or thicker plywood (with rubber feet on the bottom if you like). Then you can set your bikes anywhere inside the trailer that there is floor space. An alternative would be to mount the fork mounts permanently to the wall or floor of the trailer in a place where they won't interfere with other uses.
Most bike oriented sports shops will have stuff like this available, and you can also get adapters for 15mm or other size through-axles that are common on newer mountain bikes.
Alumineer is offline   Reply With Quote
Old 07-25-2016, 05:33 PM   #195
Stay CazuaL
cazual6's Avatar
Reseda , California
Would it be too much to ask for a photo? I will be going on my next trip towards mid September.
WBCCI 9164
Old 07-25-2016, 05:34 PM   #196
Stay CazuaL
cazual6's Avatar
Reseda , California
Would it be too much to ask for a photo? (if you have one setup of course) I will be going on my next trip towards mid September.
WBCCI 9164
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 05:34 AM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
