Old 04-06-2014, 06:55 PM   #1
1975 25' Tradewind
dallas , Texas
Question Original Weight Distribution
Can someone please tell me what the hitch looks like for this set up, or should i just replace the whole thing. I have seen some on craigslist and ebay for 20 bucks...and new sets as low as 200...
https://www.dropbox.com/sc/vc3ennunuww4vmq/IRTOyr_4WC
hippygypsy is offline   Reply With Quote
Old 04-06-2014, 07:02 PM   #2
sandlapper's Avatar
1993 34' Excella
York , South Carolina
That is the Reese Dual Cam sway/wd set up, 1st generation. It has been around a long time and works quite well. It requires a Reese ball mount hitch head that accepts the trunnion ends of the lift bars. Very common, very good.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 04-06-2014, 08:01 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Use gen 1 on both my 34's love them work very well. No sway ever, keeps everything level and tight. I use 800# bars tight. I tow both with a ford excursion 4x4.
I have upgraded all components to the ultra frame spec components. Early ball mounts were prone to weld failures, new design is a cast frame
AtomicNo13 is online now   Reply With Quote
Old 04-06-2014, 09:37 PM   #4
1975 25' Tradewind
dallas , Texas
Fantastic...
What does the hitch(the one on the truck) look like....i need to find one
Old 04-06-2014, 09:40 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Here you go
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 11:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 01:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 09:13 PM
weight distribution Craig Hitches, Couplers & Balls 2 04-14-2003 07:57 PM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 03:48 PM
