Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 08-08-2009, 12:43 AM   #1
Airstream Pilot
Profile:  Seattle , Washington
Opinions wanted: Audi Q7 3.6 for AS Intl CCD 23'
What do you all think about an Audi Q7 3.6L to tow a AS Intl CCD 23'?
Audi Q7 3.6 Specs
280 hp @ 6200 rpm
266 ft-lbs. @ 2750 rpm
Tow cap. 6,600 lbs
Curb Weight: 5170 lbs.
Gross Weight: 6713 lbs.
2009 AS Intl. CCD 23' Specs
Hitch Weight w/o options or variable weight 700
UBW 4,695
NCC w/o options fluids or cargo 1,305
GVWR 6,000
Thanks!
airstreampilot is offline   Reply With Quote
Old 08-08-2009, 01:18 AM   #2
vinstream's Avatar
Profile:  1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Dennx,
I have used and pulled many trailers with both the VW Touareg V-8, and Porsche Cayenne (Both built on the same basic platform as the Q7) and I am trully amazed! The vehical will handle it very well! In fact Airstream used the Porsche Cayenne it a high speed course to show off how good the Airstream is, but infact it is both the vehical and the trailer in a pair that can only do such a course at such speed! I would say that I would not go over 30' with a new airstream and could go up to a 36' with a vintage trailer! The Q7 will be a great choice! I would spend the extra $$ for the air leveling suspention!!! There is nothing like it from any other TV on the market! Good luck and safe travels....
Vin... Home of the "NO FLOOR ROT TRAILER"
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
vinstream is offline   Reply With Quote
Old 08-08-2009, 09:19 AM   #3
Airstream Pilot
We only have the v6 version, but it's a lease so we can go for the v8 with air suspension in 2 years. Is the v6 adequate for the CCD 23'?
Old 08-08-2009, 09:30 AM   #4
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
Welcome from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
The Q7 will probably do an adequate job of pulling an AS23 if properly set up.
Since you are leasing your Audi, you should carefully review the terms of your lease. Many passenger vehicle leases prohibit towing entirely or limit it to light weight towing. Violating these terms can end up costing you a bundle.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 08-08-2009, 09:38 AM   #5
vinstream's Avatar
The v-6 will work for the next two years! I feel it maybe little under powered for the hill or the mountains we have here in Colorado! The lease company (VW leasing) is ok to pull with! You may have to up the coverage you are have....
Vin...
www.VINSTREAM.com
WBCCI # 1962
Old 08-08-2009, 10:42 AM   #6
Airstream Pilot
Thanks for the info! Yep we have the towing package on our Q7. Now I'm even more excited about shopping for our CCD 23!!
Old 08-08-2009, 11:09 PM   #7
Airstream Pilot
OK, so the Audi V8 and the V6 are rated the same towing cap. of 6600#... now I'm wondering if the V8 is worth the upgrade at end of lease? Maybe switch to a VW Toureg V6 or V8 which is both rated 7700#?
Old 08-09-2009, 02:07 AM   #8
Airstream Pilot
I'm also reading on here that Audi does not recommend a WD hitch on the Q7. Correct? What is the best way to set up the Q7 hitch?
Old 08-09-2009, 07:29 AM   #9
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
VW also does not recommend a WD hitch on the T-Reg, but there are several happy T-Reg owners towing Airstreams. Xray on the forums here tows with one, and even though he is not very active on the forum, I'm sure he would be willing to chat with you about his experiences towing with one.
(No Longer at Inland RV)
Old 08-09-2009, 09:05 AM   #10
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
There is one problem.... The rear end ratio... They are made for speed no towing. Once you head up to the mountains out of seattle it will be a slow go... There was someone on here who had the cayenne and said it was great on the flats but a dog on the hills.
It will work, but it will be a push to maintain the speed limit up the pass out of seattle.
Also I wouldn't go any longer the wheel base is pretty short. And even if you don't put an equalizer on it you will differently want sway control with that short wheel base..
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-09-2009, 09:12 AM   #11
Airstream Pilot
So 118" wheelbase for the Q7 is too short?
Old 08-09-2009, 09:45 AM   #12
Profile:  1965 26' Overlander
Renton , Washington
dennx, as a mechanic and speaking from years of experience, the Q7 will do well enough pulling a 23 footer. Yes, it may be a bit of a dog climbing hills but I am of the mindset that when I'm towing my airstream I'm not expecting to be setting any land speed records. I like to take my time even if I can climb Snoqualmie pass at 65 with my current tow rig I don't. There is really no need to put your tow vehicle under that much stress just to get somewhere a little quicker. Go purchase your airstream and start enjoying what we all here enjoy!
nate3172 is offline   Reply With Quote
Old 08-09-2009, 12:15 PM   #13
"CLOUDSPLITTER"
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
Airstream Registry
Wink
If your basing your AS purchase on your tow vehicles capability you don't want it bad enough, get the Stream, if your not happy, you'll work it out.
You've been bit, now it's time to SCRATCH.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 08-09-2009, 03:38 PM   #14
Pop Rivet's Avatar
Profile:  Salt Springs , Florida
Power?
[QUOTE=purman;732632]There is one problem.... The rear end ratio... They are made for speed no towing. Once you head up to the mountains out of seattle it will be a slow go... There was someone on here who had the cayenne and said it was great on the flats but a dog on the hills.
Hmmm, I have a Cayenne S and belive me , power is not a issue when pulling - just drop it down to 5th - or 4th - or 3rd and keep on truck'en.
Pop Rivet is offline   Reply With Quote
Is the bed in a 22' ccd Intl too small? amathis50 2005 International CCD 25 07-08-2008 06:54 AM
Babe in 2005 Intl CCD JMP Intn'l Member Introductions 9 03-03-2007 10:11 PM
Cleaning the interior tables/appliances 05 28' Intl CCD amathis55 2005 International CCD 0 03-10-2006 05:22 AM
Opinions wanted till Tow Vehicles 9 07-15-2004 06:24 AM
Tundra 22' INTL CCD temcotom On The Road... 2 03-09-2004 10:41 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
