Old 07-29-2012, 06:07 PM   #1
1979 Argosy 27
Fort Fairfield , Maine
Opinions Please?
My restore is nearly done! Now I need a hitch system. I have found an Eaz Lift Weight Distribution w/ sway control on the web for about half of what the local dealer wants for a hitch. Has anyone used this brand? Any and all comments appreciated.
Stumpjumper
Stumpjumper is offline   Reply With Quote
Old 07-29-2012, 06:24 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Eaz lift is a known good brand. When I was working as a transporter there were more drivers using eaz lift than Reese. I suspect based on cost, but obviously they worked or drivers towing large trailers many miles a year would not have kept using them.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-29-2012, 06:48 PM   #3
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
I have never heard of eaz lift, so I cannot say yea or nay, but the best and safest hitch I ever used was the Hensley Arrow.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 07-29-2012, 06:55 PM   #4
SteveH's Avatar
Common Sense , Texas
Stumpjumper
In my opinion, it is more important to get a hitch with the proper weight rating bars for your trailer's tongue weight, than what brand of hitch it is. Meaning, you don't want to use a hitch with 1400 pound bars with a trailer that has an 800 pound tongue weight. Something like 1000 pound bars with an 800 pound tongue would be doable, but 800/800 is better.
Old 07-29-2012, 07:09 PM   #5
KeithC's Avatar
1994 34' Excella
1978 31' Sovereign
Mansfield , Georgia
I used an eaz lift hitch system for years. They make a good quality WD system that is easy to hitch up and tows straight and level. The only reason I am not using it now is that I bought a 34 ft excella that came with a different brand hitch.
Tac GA-20
Air Forums 20320
KeithC is offline   Reply With Quote
Old 07-29-2012, 07:32 PM   #6
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I bought an Andersen WD with built in sway. The sway control is a hundreds times better than my old friction one. Plus its on and off in a few minutes with nothing heavy to lift and no messy grease. I have 1500 miles on it in a week and love it. solid as a rock.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-29-2012, 08:18 PM   #7
1979 Argosy 27
All,
Thanks for the replies. I too often buy stuff without doing due diligence. Much appreciated everyone.
Old 07-29-2012, 09:51 PM   #8
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Our hitch was set up by our dealer and he kitted us out with an Eaz Lift system, including a pair of friction anti-sway bars; indeed, he uses Eaz Lift by default for most of his installations. It's basic stuff compared to Hensley or Propride but it works for us; we've not had a single problem and the Airstream follows us straight and true.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
