10-14-2011, 04:01 PM
2008 25' Safari FB SE
Formerly Austin/Bastrop..now escapees
OK! I've had it
with my equalizer hitch........just have had it....had it....
what to replace it with........
Kingfisher24
and the three P's(Paula, Phoenix and Peabody)
2004 GMC SIERRA DENALI Quadrasteer, AWD
WBCCI 2541
Texas Highland Lakes
4CU
10-14-2011, 04:11 PM
Spokane
And the reason would be.........?
10-14-2011, 04:26 PM
hard to articulate....other than it being a piece of sh......t that is continually breaking something.......one or another of its parts,,,,,not to mention it, i believe, the major reason for the receiver hitch being ripped off my truck.....
today it was a sway control bracket...that ripped in half..not the first time/....
it will twist grade 8 bolts in two ....
the head where the ball attaches has cracked......
you name it.....
brackets broke once and nearly destroyed my propane line
i have had it.......had it/......had it.......
Kingfisher24
WBCCI 2541
4CU
10-14-2011, 04:31 PM
Spokane
Wow, that sounds like some serious S.........T going on, as you would say. I can't blame you for running in a new direction but I can be of no use in the way of advice because all I know is the Equalizer.
I have had one for about 4 years now, 2 on my Airstream and they have been good to me. I have never heard of the problems that you are having but the information is good to know.
Best wishes. I am sure you will get a ton of suggestions in short order.
Dick
10-14-2011, 05:23 PM
Time for a Hensley or Propride. Ive heard prices are low each company trying to get the sale. Ive got a Hensley but like the Propride as well. Have seen several Proprides on friends trailers and like some aspects of them and like other aspects of the Hensley better so flip a coin and see who will make You the best deal.
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
10-14-2011, 05:25 PM
2007 20' Safari SE
Cuddebackville
, NY
Reese Dual Cam.
10-14-2011, 05:33 PM
2006 19' Safari SE
Tucson
Hey Kingfisher...I hear your frustration. It doesn't sound like a good situation.
We use an Equal-i-zer and have never had an issue. Have you discussed this with the Equal-i-zer people? They are very much into customer service and I am sure they will help you figure out what's going on. I am certainly no hitch expert, and I would certainly not blame you for changing your hitch set-up...but it really sounds to me like something is not set up properly it you are having that kind of stress on your hitch mechanism. The only complaint we've had (and it's minor, really) are the creaks and goans and I think that increases when the bar brackets get a little loose and lose their proper angle. I'd talk to Equal-i-zer and see what they say.
10-14-2011, 05:46 PM
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County
, Ohio
ProPride
Call and talk to Sean Woodruff at ProPride. We have one and love it. He is #1 in customer service in our book!
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
10-14-2011, 05:59 PM
2012 25' Flying Cloud
Battle Lake
We use the Equal-i-zer, although I would rather have a Propride. It works well, keeps the trailer steady and have not had any problems since getting it properly adjusted.
Sounds like it is adjusted way to tight, but someone who knows hitches would have to adjust it in person. You may have a similar problem with a replacement hitch if it's adjusted the same way as this one, I suspect.
doug k
10-14-2011, 06:44 PM
2000 27' Safari
Berkeley
The geometrics of the Hensley/Propride seem the same. I prefer heavy welds over bolts, but the Hensley paint treatment is pure trash. Even so, the rig is overbuilt and in the Mojave crosswinds never a incident of sway/failure.
I was a newbie when I purchased my AS and Hensley and have never had a moment of concern about control using the HA. Going 25k miles strong...
Piece of mind is priceless...
'00 Safari 27' Rear Twin
'03 Ford F-250 7.3TD/CC/LB 4x2 Bio-Diesel
"Hmmm... Smells like French Fries!"
Prodigy/Enkay/Hensley/Solar/LED lighting
AIR 4598 / WBCCI FCU 8579/
EAA 872814
10-14-2011, 08:26 PM
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
, Alabama
Motorhome
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator
1972 Argosy 24'
1954 Feathercraft Vagabond
10-14-2011, 09:03 PM
Santa Rosa Beach
We have a Hensley, and dearly love its performance. There is no sway or an anxious moment, EVER. If we were buying today, we would seriously consider ProPride. Are they both expensive? Yes. Do they both work? yes.
Brian
SuEllyn & Brian McCabe
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2011 Silverado 3500 (Fred) with Outfitter Truck Camper (Ethel)
10-14-2011, 09:06 PM
1994 34' Excella
1978 31' Sovereign
Mansfield
, Georgia
I am not a trailer hitch engineer, but there are some sever sheer and tinsel strength forces being applied to this hitch combination to cause such a series of failers.
If I had this series of equipment failures happen to me, I would look at the set up to ensure that the system was rated for the applied load and that the system was installed correctly, as it is unlikly so many different hitch system componets would fail at the same time, or in a recent time period, because of faulty materials.
The componet failures are a warning that the hitch system is not capabile of handling the loads applied. Again, I'm not a hitch engineer...but if any one of these failures had occurred at Internet speeds, there could be tons of force, on different tangents, at 65+ MPH, seperating, and you would only be an observer in the tow vehicle, long for the ride to the final destination.
10-14-2011, 09:49 PM
2009 23' FB Flying Cloud
The Woodlands
Propride.......nuff said.
| Thread Tools |
| Display Modes |
