Old 05-01-2017, 06:43 AM   #1
1981 31' Excella II
Alpharetta , Georgia
Newbies renting a tow vehicle
Does anyone have experience renting a truck to get an Airstream from the place it was purchased? (We are looking to tow one from the Florida panhandle to North of Atlanta - 5+ hours.)
What is a good rental service?
What do we need to know?
Thanks!
britta315 is offline   Reply With Quote
Old 05-01-2017, 07:03 AM   #2
Llando88's Avatar
2016 30' Flying Cloud
Probably depends on the company you contact. Here are a few things to think about...
What are the specifics (Gross weight, tongue weight) of the Airstream?
Does it have a weight distribution hitch?
Do you intend to drive over interstates or roads over 6% grade?
For the Rental Company:
What is the Tow Capacity of this truck?
Does it have a hitch rated above the AS requirements?
What is the GCWR of the truck when towing?
Does this truck have tow mirrors?
Does the truck have a 7-way trailer jack?
Does the truck support electric trailer brakes with a proportional brake controller?
Is insurance available in the event of loss or damage to the truck or TT while towing?
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 05-01-2017, 07:15 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I recently spotted a Uhaul pickup hauling an about 30 ft SOB on the interstate. Looked stable and level. I could not tell if any WD was used or what the truck model was.
MICHAEL
Old 05-01-2017, 07:18 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I have learned in attempts to do this in the past that any of the conventional car rental companies (ie., Hertz, Budget, Enterprise, even Uhaul, etc.) strictly forbid you to tow anything with their vehicles, even if they ar renting you a Suburban with all of the hardware installed you would need. You will likely need to go with a commercial vehicle rental company that rents 3/4 ton trucks. You will find that these typically only do business 5 days a week, and are a lot less tolerant of one way rentals than a typical car rental place, and are a lot more expensive than a typical car rental place.
You might also check the cost of having someone deliver the trailer for you.
good luck!
Old 05-01-2017, 10:09 AM   #5
2007 27' Classic FB
Ridgefield , Washington
There was a recent thread were someone was towing their Airstream from Tampa to Portland OR with a Uhaul. You may want to look at the post.
John
Woosch is offline   Reply With Quote
Old 05-01-2017, 10:20 AM   #6
Llando88's Avatar
http://www.airforums.com/forums/f42/...nd-164946.html
Old 05-01-2017, 11:10 AM   #7
Rivet Polisher
1973 31' Sovereign
Mt Pleasant , North Carolina
We rented a Dodge 2500 from Enterprise TRUCK Rental last year to tow our old camper from Charlotte, NC to Oshkosh, WI and back. It was the smallest truck they rent that has towing capacity and they encourage towing with it. Very inexpensive, rented it for 2 weeks and it was less than $1000.
wildhorses is offline   Reply With Quote
Old 05-01-2017, 11:25 AM   #8
Tom T
Tom_T's Avatar
Orange , California
good luck!
This is absolutely correct on the no tow with regular car rental companies.
Also for those recommending UHaul - their truck are usually only 1/2 ton truck with the base level 5000" & 500# HW ratings - PLUS & more importantly - they almost exclusively only have a 4-pin electrical connector, so you can't run trailer brakes off of them (UHaul's rental trailers have surge brakes). Moreover, since UHaul charges a daily rate + per mile - they quickly become more expensive than other commercial rentals.
Penske, Ryder, Budget Commercial divisions (not the car rental at airports & neighborhoods noted above) sometimes have trucks with 7-pin electrical connectors & 2", 2.5" or 3" receivers (you'll need an adapter for 2.5 & 3" to 2") - but these are more often than not a big box truck for moving, & more expensive than just a pick-up - which these 3 rarely have in their fleets. They do usually allow one-way & out-of-state towing.
Also, some few Toyota dealerships have Toyota's TRAC Rental System & may have pick-up &/or SUV tow vehicles in their rental fleet, but they usually don't allow one-way & out-of-state towing. So you have to call around to find one with TVs, that will allow you to go to GA, but expect a round trip to return it to the renting dealership - or better yet, just do it locally in GA & leave off the air flight to go get the trailer.
We've been using Enterprise Commercial since 2014 & get their 3/4 ton crew cab trucks, which will be new 2017 F250 or RAM 2500 (sometimes GMC/Chevy & a few 1/2 ton here & there) in the current fleet & all equipped with 7+4 pin & 2.5 or 3" receivers (they supply the adapter if you ask). They run us about $100/day or $800/week + tax & their full insurance coverage you'll need (unless your a business & can add them as named insured on your biz auto policy), & which includes 150 miles/day & 850 mi/week IIRC (we usually tow less in SoCal & Central Coast for vintage rallies, so never max out) - but they usually don't allow one-way & out-of-state towing. So you'll need a waiver to go out-of-state, & would probably rent in GA, go get the trailer & return.
Note that the Dodge/RAM pick-ups have hitch receivers mounted higher on the trucks than the Ford & Chevy/GMC trucks, so you may want to request the Fords, & also ask for back-up camera to aid your hitching.
Otherwise, you may find someone to deliver it for you as noted above, but make sure that they're fully qualified, insured & bonded for any damage.
PS - We also during 2013 had rented Nissan Pathfinder V6 from TRAC from a dual Toyota/Nissan dealerships, until they sold off the Toyota side & no longer had TVs in their fleet. They also had Nissan Armada & Titan V8s, but we don't need that for our 3000# Avion, plus they were 45 mins away from us in Orange to Long Beach, while Ent. Comml. is 5 mins away.
Good Luck!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
Old 05-01-2017, 12:00 PM   #9
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
For tax savings purposes, it was vital for me to take delivery of our new AS, purchased in CA, in NV, which has no sales tax. I asked the AS dealer how that could be arranged, & they gave me the name of a commercial trucker they used for deliveries. He had an F-350 duelly & delivered the AS from Los Banos, CA (Toscano RV), to Reno, NV for $600 & then acted as the dealer's agent to formally transfer the AS to us.
Yes, I eventually paid sales tax in WA, my resident state, whose sales tax rate is comparable to that of CA, but WA calculates sales tax on the difference between purchase price & the value of any like-kind trade-in, while CA calculates sales tax only on the purchase price alone. My trade-in value, for a 5th wheel, was approx. $30K, so by paying the trucker $600, I saved almost $2,400 in sales tax that I would have otherwise had to pay had I taken delivery of the AS in CA.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Newbies! Best vehicle to tow 31ft 1974 Sovereign? 74yachtpnw Tow Vehicles 17 08-18-2011 08:21 PM
Renting a tow vehicle for very occasional use packrat561 Tow Vehicles 18 04-14-2008 01:03 AM
Renting a tow vehicle? SilverToy Off Topic Forum 8 06-04-2007 03:31 PM
Renting a tow trailer/truck? pinkflamingoes Tow Vehicles 13 05-15-2004 06:10 PM
having difficulty renting an Airstream lloyd cicetti Our Community 6 03-25-2004 03:00 PM
