Old 08-25-2013, 03:43 PM   #1
2004 19' Bambi
Summerland Key , Florida
Newbies in towing
Just got our 19ft Bambi on the road for a test drive before heading West. Concerned about the fishtailing over 60 mph. Concerned about weight distribution. Water tank full, Honda 2kw generator about 45 lbs on rack on back attached to frame. We need some feed back. What do we need to be concerned about. Grey and black water tanks empty! Thank you to anyone who can shed some light on our first time out!!!!
Bambilicious is offline   Reply With Quote
Old 08-25-2013, 03:56 PM   #2
1994 30' Excella
Mississauga , Ontario
About 10 to 15% of trailer weight should be tongue weight. Do you have sway control?
You are on holiday. Not in a hurry. Don't drive over 60mph if that's what it takes.
Al
Al and Jean
TAC ON-3
Old 08-25-2013, 04:42 PM   #3
Road Ruler's Avatar
Images: 38
What is your TV?
Can you post some images of your set up?
Are you currently using a WDH?
Old 08-25-2013, 06:07 PM   #4
Try towing without the Honda Generator. The weight on the back possibly lightens the tongue weight enough to cause sway. A bike rack on the back of an Airstream is not recommended because of possible frame damage. The generator is heavier than most bikes and would raise the same issue.
You need a weight distributing hitch with any Airstream. Most of the newer hitches have sway control integrated into the hitch.
What is your tow vehicle? If it is overloaded in the back without a wd hitch, that could help cause your sway problem.
Sway is not a normal condition, especially with an Airstream. Something is amiss with your rig.
handn is offline   Reply With Quote
Old 08-25-2013, 09:34 PM   #5
1971 23' Safari
Arlington Hts , Illinois
Unless your tires are better than ours (new 65 PSI max Goodyear Marathons), you shouldn't BE going over 60 MPH. I've been assured very bad things will happen if we exceed 65 MPH!
Our dual axle '71 Safari weighs a bit less than a new Bambi, and has an Equil-I-Zer hitch on our Honda Pilot tow vehicle (rated to tow 4500#.) We tow the trailer with all water tanks empty and nothing hanging off the back, and haven't had any fishtailing or other issues so far.
MrJim is offline   Reply With Quote
Old 08-25-2013, 10:00 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Wecome to the forum.
Hi, not enough information, but having a generator on the back of the trailer is not a good idea.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-26-2013, 12:30 AM   #7
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Listen to what Bob said....
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 08-26-2013, 09:23 AM   #8
2004 19' Bambi
Thank you all for your input. Taking the unit to be weighed. Checking tongue wt etc. Removing the generator and he promised to keep it under 60 mph. Can't wait to get on the road on our new adventure.
Old 09-01-2013, 07:03 PM   #9
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Towing with tanks full can make for a more stable towing experience
Because the tanks are so low, adding weight to them lowers the centre of gravity of the entire trailer, making it more stable. I always tow with fresh water full, when possible. I haven't found an increase in fuel consumption either.
Of course, we also use a Hensley Hitch, which makes for a very stable rig.
andreasduess is offline   Reply With Quote
Old 09-03-2013, 08:18 AM   #10
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Yep, we carry 1/2 or 3/4 full fresh water all the time. Makes stopping "anywhere" comfortable to have water on board, along with better towing experience, at least with our set up.
Linda Heuer. Past President Shen. Valley Unit
Greg Heuer, 1st VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 09-05-2013, 04:27 PM   #11
1971 23' Safari
55 MPH was a great speed for our recent cross-country drive with a 3530# empty Safari being towed by a Honda Pilot with an Equil-I-Zer hitch. No bad behavior by the trailer at all during the 2,000 mile journey. We sometimes had water in the fresh water tank, and sometimes didn't, but didn't notice any handling difference either way.
Since sometimes the water was better where we stopped, and sometimes worse, I now favor filling the tank whenever the water is good, just in case it isn't so good at the next stop.
